For the application I am programming on the 6410, I dont need touchscreen support. Therefore a USB mouse and keyboard will be used. Because of this, I didnt configure Qt with the option of "qt-mouse-tslib". Is that OK? Also, I know that there are configurations needed for tslib. How do I change the configurations below in /etc/profile so as to enable the USB mouse and keyboard? export LD_LIBRARY_PATH=/usr/local/tslib/lib export QTDIR=/usr/local/Qt export QWS_MOUSE_PROTO=tslib:/dev/input/event0 export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/usr/local/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts export TSLIB_TSDEVICE=/usr/local/tslib/lib/ts export TSLIB_TSEVENTTYPE=INPUT export QWS_DISPLAY=LinuxFB:mmWidth=105:mmHeight=140
