Hello Everyone, So I've just bought this little beast, installed wince6 via uSD card, booted up, and getting ready for software deployment. I also installed two files: Mini210-CE6-SDK and Mini210-CE6-Suite-1217. However, Windows Mobile Center will not connect to the device. When I plug the board into my computer using the provided usb cable, it says Unidentified Device. It goes to search for drivers via windows update, gets to the install stage, and ends up with Device Unplugged. I also have a Mini2440, and it works great. I can program and upload software via VS2008 just fine. Does anyone know what I've done wrong here? Thanks!
Mini210S WINCE6 Win7 64b USB
Hi, At this point in time the BSP does not support USB Function and so Active Sync will not work. Friendly Arm are aware of this but have not given a commitment for when this feature will be added to the BSP. The same issue has been mentioned several times now in recent posts...
Hi, because the miniUSB driver is not available in WindowsCE 6.0, the Samsung don't provide it. it will take a long time to develop. please wait. PS: Android is better on Mini210S, you can play it first. mindee
@BBBB. Oh, so that what the other posts were about. I thought it was for another issue since I have 210S and not a 210. Is it safe to assume that people with mini210 are facing the same issue? This is really weird because the included DVD contains CE6-SDK for Visual Studio, but I can't connect because of a usb driver. Why even make the SDK in the first place? @mindee. I tried Android, but it felt sluggish for some reason. Plus, the application that I've written uses wince...so this is a bummer. Do you happen to know how long it will take to develop this driver? Why isn't this mentioned in the webpage?
They use the same processor so they are almost the same system. By the way the SDK has nothing to do with drivers for connecting the board to the computer. My understanding is that it's for Visual Studio to know what components you installed in your NK.bin OS file so that when you write an application it can check (at least to some extent) if your application uses something that is not present in the OS. I too was suprised by the driver not working but when I went back to the webpages about it (Tiny210 and mini210) it does actually not claim to have this driver supported for WinCE. It says the hardware has the ability and the driver for for Android but not WinCE. But - if you wish to write and deploy apps you can get an activecync like connection over Ethernet and do it this way. I've been doing this and it works fine. http://msdn.microsoft.com/en-us/library/ms228708%28VS.80%29.aspx But you may need to rebuild the OS with activesync components added. http://www.friendlyarm.net/forum/topic/1663
@BBBB. I don't have the platform builder on my computer, so I can't rebuild the NK.bin file. Could you send me a copy of the NK.bin with the activesync component? You could upload it or ftp or something that you're comfortable with. I didn't even know that you could upload programs via ethernet... interesting. Thanks for the explanation!
@NothinRandom. I'm sorry but my NK.bin has been heavily modified for a commercial project so I'm unable to do this. Have you tried to get it to work with Ethernet? Perhaps the ActiveSync components are already present or maybe you don't actually need them. It's probably a good opportunity for you to try installing Platform Builder and build your image. It builds almost straight away without too much modifications. You'll learn so more more about the plaform once you know how to build the OS.
@BBBB Yeah, I went through the steps: Tools->Options->Device Tools->Devices->Properties->Configure->Use specific IP Address, but no dice. I didn't check the use fixed port number, but I don't think it matters. So, with this in mind, I don't think the NK files that came with the DVD has active sync on it. By the way, where can I get platform builder? Should I install xp since I'm running on win7?
@BBBB, it works! The speed is so much faster than using USB for some reason. When I click on connect to device, it connects immediately vs the USB...take a while to talk. Anyways, thanks for the help. For others with the same issue, just follow the first link BBBB posted, then go through the steps I've posted. Finally, I can get some development done.
@TheRegnirps: This is taken directly from the link posted by BBBB Follow this page: http://msdn.microsoft.com/en-us/library/ms228708%28VS.80%29.aspx. To prepare the device for connecting Using whatever connection with the device you have, copy the following files to the \Windows\ folder on the device. These files are located on the development computer by default at \Program Files\Common Files\Microsoft Shared\CoreCon\1.0\Target\wce400\<CPU>. Clientshutdown.exe ConmanClient2.exe CMaccept.exe eDbgTL.dll TcpConnectionA.dll From the command prompt on the device, run conmanclient2.exe. Determine the IP address of the device. To prepare Visual Studio for connecting On the Visual Studio Tools menu, click Options, then click Device Tools, and then click Devices. Select Windows CE Device, and then click Properties. To the right of the Transport box, click Configure. In the Configure TCP/IP Transport dialog box, select Use specific IP address, and then type the device IP address. Close the dialog boxes. A message box might appear prompting you to reset your device. If so, a soft reset is sufficient.
The FriendlyARM engineers jumped on this and it is on the ARMWorks downloads page at andahammer.com. Check the July Updates section where it has a name lime WinCE6Ether210 or something like that.
@TheRegnirps: They put the wrong version of Conman Client on there. I think they put the ARMV4 instead of the ARMV4I because it says "The version of Conman Client running on the device is incompatible with the desktop."
I've fixed the USB OTG driver for Windows CE 6. I've submitted it to FriendlyArm to test and they should release it with their next BSP update. Hopefully this will be soon.
Is it me or did they released the .nk files that don't have CAB installer and HIVE-based memory? I can't install anything. Also, the board resets every time I boot up; I lose everything.
Hi, I guess you have difference expectations about the supplied nk.bin then FriendlyArm. They are just as a proof that the BSP source works when building - but then it's up to you to set it up and build the version you actually need. It's very simple process to add CAB installer support, Hive registry is fairly straightforward too but I'd admit a fraction harder. But to do these things you need to install platform builder into VS2005. You can freely download Platform Builder as a 6 month trial from Microsoft. And there are easily discovered websites showing how to install it on a 64 machine as I had to do. I'd suggest installing it and it will help with your understanding of the WinCE platform no end but of course you will need to devote a little time to learn how to use the tools. But then you will be able to add the capabilities you need to your nk.bin image.
Hi, the MiniUSB driver is available now, and the new ISO file will be available next week, just wait. mindee
Hi Mindee, Has this issue been address? I went on the ftp last night and saw the new iso dvd that contains the nk file for mini210 dated 07/25/12. Is this the latest one?
Do I need the device hooked up in order to build the bsp? I have one error, and I can't figure out how to fix it to save my life!
Why not just add Eboot Support on Ethernet instead of USB RNDIS. As most of the developers (Hobbyist) like me have laptop with Windows 7 64 bit OS. Laptop is normally is connected to home network using Wifi and Ethernet port is ways free. so We can just hook up to MINI210 to this free Ethernet port and use fro WinCE KITL intefrace instead of USB RNDIS Driver. I was using Mini2440 from 2009, there also I had the same issue 64 bit OS driver is not available. and Friendly arm is not willing to develop USB driver, the Best reason they provide SAMSUNG is not providing 64 bit driver. We dont need USB OTG driver for our development(hobby) purpose, JUST add the ethernet support for download and debugging (kernel debugging ).
FA have shipped pre-built driver for the USB OTG named "fa_usbfn.dll" and included it as additional file. The source code still not functioning but I have fixed the OTG driver. The source code is very badly written and there are too many bugs. I think it is Samsung's engineer fault when they try to develop SMDKV210 BSP.
