Still can't gry Huawei E1550 to work
Dave McLaughlin
Hi all,
I am running Android on the Mini210 and I have plugged in a Huawei E1550
modem and even after configuring it for MODEM only with AT command it gets
detected by Android but won't dial out.
Here is the debug output
[ 1540.467431] usb 2-1: new full speed USB device using s5p-ohci and
address 2
[ 1540.635840] usb 2-1: New USB device found, idVendor=12d1, idProduct=1001
[ 1540.635900] usb 2-1: New USB device strings: Mfr=2, Product=1,
SerialNumber=0
[ 1540.635962] usb 2-1: Product: HUAWEI Mobile
[ 1540.636000] usb 2-1: Manufacturer: HUAWEI Technology
[ 1540.642239] option 2-1:1.0: GSM modem (1-port) converter detected
[ 1540.642849] usb 2-1: GSM modem (1-port) converter now attached to
ttyUSB0
[ 1540.654551] option 2-1:1.1: GSM modem (1-port) converter detected
[ 1540.663140] usb 2-1: GSM modem (1-port) converter now attached to
ttyUSB1
[ 1540.665221] option 2-1:1.2: GSM modem (1-port) converter detected
[ 1540.673471] usb 2-1: GSM modem (1-port) converter now attached to
ttyUSB2
It has a valid working SIM and I have updated apns-conf.xml to include the
correct APN settings etc.
It just does not dial out when I choose the dialup 3G application.
Anyone for this working and if so, what did you do?
Cheers,
Dave...
TheRegnirps
Dave, the MODEMs I'm using set themselves up as 4 or 5 USB ports. Check
/dev and see if you get ttyUSB0 ttyUSB1 etc. when you plug in the MODEM. I
have had to do fiddle around to find which one (usually 4 if there are no
other devices) will dial out with an AT command.
The other problem has been getting attached to a tower successfully, and
one embarrassing lost day because I didn't have quotes around the phone
number in the AT command.
Dave McLaughlin
Thanks Charles,
I will have a go at it today and see if I can get it working.
It seems a bit strange that it appears as 3 USB ports as I would have
expected it to only appear as 1.
I have a simple terminal app I can run to send AT commands and see which on
responds to them.
Cheers
Dave...
TheRegnirps
I think one of the ports registers as a storage device and has driver info,
and some others are like partitions and one might not use AT commands but a
proprietary protocol. I'll have to research and write up the details. I'm
just getting into it with Python code to send SMS with data from monitoring
equipment.
Dave McLaughlin
I disabled the storage device with an AT command on the PC so that it now
only appears as a modem.
I would like it work work with the standard Android phone interface if
possible otherwise I will have to do similar to what you are doing and
write my own Android app to do AT commands.
ashok
1540.467431
Dave McLaughlin
@Ashok.
Sorry, I must be missing something in your post but what are you referring
me too?
