Has anyone come up with an error like that when making Qt? I'm remaking Qt, and the only difference I can think of is that QtCreator is now installed on the same system. I had an error with an undefined reference of "get_time" and I got around that by adding -lrt to the qmake.conf file. The total description of the error is as follows, [CODE] make[3]: Leaving directory `/usr/local/qt-everywhere-opensource-src-4.8.2/examples/ipc/sharedmemory' make[3]: Entering directory `/usr/local/qt-everywhere-opensource-src-4.8.2/examples/ipc/sharedmemory' uic dialog.ui compiling main.cpp In file included from main.cpp:42: dialog.h:65: error: 'QSharedMemory' does not name a type make[3]: *** [.obj/release-shared-emb-arm/main.o] Error 1 make[3]: Leaving directory `/usr/local/qt-everywhere-opensource-src-4.8.2/examples/ipc/sharedmemory' make[2]: *** [sub-sharedmemory-make_default] Error 2 make[2]: Leaving directory `/usr/local/qt-everywhere-opensource-src-4.8.2/examples/ipc' make[1]: *** [sub-ipc-make_default] Error 2 make[1]: Leaving directory `/usr/local/qt-everywhere-opensource-src-4.8.2/examples' make: *** [sub-examples-make_default-ordered] Error 2 [/CODE]
