hi, I succeed to have Android on my mini 2440, but I can't have ADB... I used linux kernel v2.6.27 and enabled USB gadget drivers, but it's still not working. Does anyone succeed to have ADB working and send an .apk on his mini 2440?? Thanks,
ADB mini 2440
Have you enabled USB debugging on the device in system settings? Does your device show up if you type ADB devices? Have you installed the Google USB drivers? (Assuming you are on Windows)
Thanks Dave for your reply Yes I have enabled USB debugging on the device. No the device doesn't show up when I type ADB devices. I used linux and window, and on my windows machine the Google USB drivers are installed.
What do you see in Device Manager when you plug in the USB? Does windows dectect the device? Do you get any errors? Dave...
There is nothing which appears in the device Manager when I plug the usb cable. Windows don't detect the device it's like if the USB is not enabled in the kernel of the mini2440. But I checked and the USB is enabled. Dave do you use android on mini2440? Thanks,
Hi Jean, No, I use it on the Mini6410 and now the Mini210. I never tried the Mini2440 with Android but I believe it works if a little slower. If you monitor the debug output on the Mini2440 what do you see? I get this on my Mini210 when I plug in the USB cable to the PC. [ 169.857022] android_usb gadget: high speed config #1: Android Composite
Hi, You mean that I should monitor the Jtag interface?? I checked the message from the RS 232 ouput during the boot and I can see my mouse connected of the USB host connector, but nothnig about the USB device connector and the ADB.
I mean the RS232 output. JTAG will show nothing. Strange that you don't see the system detecting the USB. Possibly USB fault maybe? If you run another OS on it, does it work? Dave...
About Jtag: That's what I am thinking. That why I checked the RS232. Yes I tried WCE6.0 and the USB works correctly, I can see my device and use the USB. I think the problem is located in the kernel, I mean that I certainly do not enable (or disable) something in the kernel, but I do not have any clue to find what I am missing. Jean
If you have an Ethernet connection, you can put adb in tcp/ip mode with the following commands: setprop service.adb.tcp.port 5555 stop adbd start adbd In ms-dos you must enter “adb connect ipadress-of-mini” to connect to the board With “adb devices” you can see if the board is connected
Unfortunatly I don't have Ethernet connection, even if in my kernel it seems to be enabled, I do have a big problem with this one. To those who have Android on mini2440, I got a question Which is kernel version are you using for your mini2440? Personnaly I use that one : http://www.friendlyarm.net/dl.php?file=android-kernel_20090825.tgz I only have changed some things to have the compatibility with the W35 screen.
Hi Jean, I spotted this tonight. I have downloaded the kernel you posted and had a look at the config and came across this website. https://groups.google.com/forum/?fromgroups#!topic/android-porting/bpUqC... Have you enabled everything they indicate here? Dave...
Hi, Thank you Dave. Now, after enabled USB_MUSB_PERIPHERAL symbol (and some other under this one...), I succeed to have in the Windows Device manager my mini2440 as Android ADB Interface, I have added the following lines in the android_winusb.inf file. %SingleAdbInterface% = USB_Install, USB\VID_5345&PID_1234 %CompositeAdbInterface% = USB_Install, USB\VID_5345&PID_1234&MI_01 With VID and PID found in the inf file downloaded right here : http://www.friendlyarm.net/dl.php?file=usb-downloaddr_20090421.zip in the inf file. And I have inserted those lines just below [Google.NTx86] and [Google.NTamd64] of the android_winusb.inf file. But when I try the "adb devices" cmd, I have nothing in the liste of devices. Thanks,
Hi, I am stucked.. In my device manager in fact I have my board as an Unknown device. Here some symbols of my config: CONFIG_USB_OTG=y CONFIG_USB=y CONFIG_USB_SUPPORT=y CONFIG_USB_MUSB_OTG=y CONFIG_USB_GADGET=y CONFIG_USB_ANDROID=m I have some questions: Do I need to define myself the VID and the PID in the kernel? They are different from those provided by Friendly (USB\VID_5345&PID_1234). If yes, in which file I have to set them? Someone uses the kernel provided by friendly arm?? Someone uses adb with mini 2440? Thanks,
Hi, For those which are also stucked as me and the others, I found something very interesting in the following link : http://groups.google.com/group/android-kernel/tree/browse_frm/month/2009...? So it seems that the android kernel provided by friendly arm can't be used to use adb, and that it is necessary to made a kind of merge with the kernel 2.6.29 or one other more recent. Jean
