Hello, I wanted to share my success, I was trying to build a simple hello world application from windows host for tiny210 with linux running. The main problem was finding suitable toolchain, at this website (http://www.acmesystems.it/foxg20_eclipse_windows_c) they referred to codesourcery eabi toolchains. I downloaded and unpacked the bzipped toolchain (https://sourcery.mentor.com/sgpp/lite/arm/portal/release2029) and also unpacked the "DVD:/Linux/arm-linux-gcc-4.5.1-v6-vfp-20120301.tgz" archive that is on the DVD that comes with tiny210 board. By placing these commands to a run.bat file, I was able to successfully build the buttons_test application (DVD:/Linux/examples-mini210-20111119.tgz) ------------------------- @echo off set path=%path%;C:\Programs\Devel\Gcc\arm-2011.09\bin\ set sysroot=G:/Data/Tiny210-20120326/Linux/x/arm-none-linux-gnueabi/sys-root arm-none-linux-gnueabi-gcc.exe --sysroot=%sysroot% -O2 -c buttons_test.c arm-none-linux-gnueabi-gcc.exe --sysroot=%sysroot% -L%sysroot%/usr/lib buttons_test.o -lc -o buttons_test ------------------------- Next problem is copying the executable to the device. At first you need some serial terminal (for example "Putty"), then using the wget command I downloaded the file using wifi, made it executable and running: -------------- [root@FriendlyARM gabo]# wget http://192.168.1.2/upl/a.out Connecting to 192.168.1.2 (192.168.1.2:80) a.out 100% |*******************************| 6726 --:--:-- ETA [root@FriendlyARM gabo]# chmod +x a.out [root@FriendlyARM gabo]# ./a.out [ 2422.896231] KEY 4: 00000001 key 5 is down [ 2423.056379] KEY 4: 00000000 key 5 is up [ 2423.907949] KEY 5: 00000001 key 6 is down [ 2424.025134] KEY 5: 00000000 key 6 is up
Building apps from windows host
I forgot to mention one important thing: If you will be decompressing the "arm-linux-gcc-4.5.1-v6-vfp-20120301.tgz" file with Winrar, it will fail and will not create all files, there are some symbolic links and some files are only pointing to different files (I am not sure about this). I used FAR manager to decompress the contents ot this tgz archive. When compiling with eabi toolchain it showed errors like "libc.so.6: file format not recognized; treating as linker script" When you look inside the libc.so.6 file, you will see this: "libc-2.11.so" So I tried deleting the libc.so.6 file and copying the libc-2.11.so as libc.so.6 and it worked fine. You will have to overwrite also the "ld-linux.so.3" file with "ld-2.11.so" to get it working. Gabriel
