Hi, I would like to try out the newest release of Qt on mini2440. (4.8.2) But I have two problems. 1. The g++.conf file went into different files. As I know well I should switch of the optimization in this file. Where should I do it exactly? (Both of two file contains optimization) 2. I can’t configure it. I used until yet this: ./configure -embedded arm -xplatform qws/linux-arm-g++ -prefix /usr/local/Qt -qt-mouse-tslib -little-endian -no-webkit -no-qt3support -no-cups -no-largefile -optimized-qmake -no-openssl -nomake tools -qt-sql-sqlite -no-3dnow -system-zlib -qt-gif -qt-libtiff -qt-libpng -qt-libmng -qt-libjpeg -no-opengl -gtkstyle -no-openvg -no-xshape -no-xsync -no-xrandr -qt-freetype -qt-gfx-linuxfb -qt-kbd-tty -qt-kbd-linuxinput -qt-mouse-tslib -qt-mouse-linuxinput But I got the following error message: qt-gif: invalid command-line switch -qt-gfx-linuxfb: unknown argument -qt-kbd-tty: unknown argument -qt-kbd-linuxinput: unknown argument -qt-mouse-tslib: unknown argument -qt-mouse-linuxinput: unknown argument You have not explicitly asked to use pkg-config and are cross-compiling. pkg-config will not be used to automatically query cflag/lib parameters for dependencies How should I configure it? Any kind of tutorial would be really good too. Thank you, David
Compiling Qt 4.8.2
BTW I would like to reach the fastest version of Qt. Because I would like to use it in critical circumstances.
Hello, > But I got the following error message: > qt-gif: invalid command-line switch > -qt-gfx-linuxfb: unknown argument > -qt-kbd-tty: unknown argument > -qt-kbd-linuxinput: unknown argument > -qt-mouse-tslib: unknown argument > -qt-mouse-linuxinput: unknown argument Take a look at ./configure --help. These are invalid options:-) In a qmake.conf was the optimization I hardly remeber:-) Yes a tutorial.... if I had the time, I would do so.... :-)
Hi, I haven't noticed it until yet, The files have been changed a bit, but I did manage to find them. thanks a lot, David (I am new in this :-) )
Hi David, Any luck on this? I managed to successfully compile Qt 4.6.2 with arm-linux-gcc-4.3.2, however this time, I'd like to use Qt 4.8.2 with arm-linux-gcc-4.4.3 and I'm stuck in this same position :(. Any help is appreciated :) -Daniel
