Hello there, I've created a simple application with Qt Creator, and it's running in PC, but when I try to run in tiny6410, it doesn't work as suppose to be, Is it because of different qmake at Tool->option->Qt4 ? What should I do to make it work ? thanks
Qt Creator and tiny6410
Hello, do you install QT for pc AND for ARM on your pc? Than you can build your application for both cpus.
Yes I have installed QT for PC and for ARM x86-qtopia and arm-qtopia, I have tried to use trolltech qmake, but gave me error when I uploaded it into Tiny6410 board =============== QWS Display::Data::init : "Invalid argument" Client can't attach to main ram memory Aborted ================== What should I fix ? Thanks
this is the parameter : qmake /root/Documents/HelloWorld/HelloWorld.pro -spec /usr/local/Trolltech/QtEmbedded-4.7.0-arm/mkspecs/qws/linux-arm-g++ -r is it right ? thanks
I get : Starting /root/Documents/HelloWorld/HelloWorld... /root/Documents/HelloWorld/HelloWorld exited with code 255
When I uploaded to board, I got error : QWSDisplay::Data::Init: Invalid Argument Client can't attach to main ram memory. Aborted, I'm using Tiny6410 What shoud I do to fix it ?
When I run it from GUI, I got : Application was terminated due to application error (11) How can I fix it ? thanks
I would first make a test if the toolchain works correct. Compile a "hello world" in pure C or C++ for the ARM and check if that works.
do you have example of "hello world" in pure c ? and how to compile it ?
just
<include stdio.h>
printf("Hello world");
I have : =========== [root@localhost ~]# arm-linux-gcc -v Using built-in specs. COLLECT_GCC=arm-linux-gcc COLLECT_LTO_WRAPPER=/opt/FriendlyARM/toolschain/4.5.1/libexec/gcc/arm-none-linux -gnueabi/4.5.1/lto-wrapper Target: arm-none-linux-gnueabi Configured with: /work/toolchain/build/src/gcc-4.5.1/configure --build=i686-build_pc-linux-gnu --host=i686-build_pc-linux-gnu --target=arm-none-linux-gnueabi --prefix=/opt/FriendlyARM/toolschain/4.5.1 --with-sysroot=/opt/FriendlyARM/toolschain/4.5.1/arm-none-linux-gnueabi/sys-root --enable-languages=c,c++ --disable-multilib --with-cpu=arm1176jzf-s --with-tune=arm1176jzf-s --with-fpu=vfp --with-float=softfp --with-pkgversion=ctng-1.8.1-FA --with-bugurl=http://www.arm9.net/ --disable-sjlj-exceptions --enable-__cxa_atexit --disable-libmudflap --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-gmp=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-mpfr=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-ppl=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-cloog=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-mpc=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-libelf=/work/toolchain/build/arm-none-linux-gnueabi/build/static --enable-threads=posix --with-local-prefix=/opt/FriendlyARM/toolschain/4.5.1/arm-none-linux-gnueabi/sys -root --disable-nls --enable-symvers=gnu --enable-c99 --enable-long-long Thread model: posix gcc version 4.5.1 (ctng-1.8.1-FA) [root@localhost ~]# =================
Look at this thread: http://www.friendlyarm.net/forum/topic/4260 There I wrote the example and how to test the toolchain:-)
I must compile two Qt creator or arm-qtopia and x86-qtopia ?? from the statement : ============== Then compile Qt twice. First for your host and second for the mini =========
No, you must compile the qt libs for arm and for x86 to produce executables with this libs for arm and for x86. Then you can select in the Qt Creator the target (after you have add both in options-> qt).
No, you must compile the qt libs for arm and for x86 to produce executables with this libs for arm and for x86. Then you can select in the Qt Creator the target (after you have add both in options-> qt). ========================== You mean these ones : I have at /usr/local/Trolltech : /QtEmbedded-4.7.0-arm and /QtEmbedded-4.6.1-i386 I tried to compile using them first for debug and the arm version for release ? thanks
I have Tiny 6410 board. i NEED TO DEVELOP APPLICATION IN qt .I have done steps for qt cross compilation http://www.sereno-labs.com/Qt_4.8.3_installation_procedure_FriendlyARM_m... after this how to set environment variables as mentioned in site.Also mine is fedora electronics lab version QT was already there qt creator and qt linguist. After this process both were removed i think.Now how to write applIcation and compile
