Dear all, Good morning. I have a Mini6410 board with LCD. I have also a QT application ready compiled and already running on Ubuntu system on PC. Now I want to port this application on the Mini6410 board. Now since this board already has Ubuntu support, will I be able to directly run this application? or do I do some changes in it? Kindly guide or provide some tutorials. I am looking onto putting Ubuntu OS on this board. Later I will put the application. Kindly guide accordingly. Regards, blueshift
Porting QT Application on Mini6410
Hello, the Ubuntu is very fat and slow on the Mini. I tried it and get back to the qtopia. I do not need the qtopia environment because I only run a standalone qt application. You must recompile your application for the ARM CPU on the mini. For this you have to install the (Friendlyarm-) toolchain on your host pc. I develop my application with the Qtcreator and it works very well. The same code for pc or the mini. Hope that helps:-)
Dear holger, thanks for the reply. I will try it. What my requirement is I have to run a QT application on Tini6410/Mini6410. You mean after compiling the QT application using the toolchain, I will be able to run the application on the default Friendly ARM OS?
No, you need the toolchain to compile the application for the mini. The toolchain is the gcc, linker and so on to get an executable for the ARM processor on the mini. If you compile it with the standard compiler for example on and amd64 pc you get an executable for this cpu. This does not run on the mini. You can see this with the "file" command on Linux. An application compiled for the amd64 (my pc) looks like this: TestExe: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.9, not stripped The same code compiled with the toolchain for the ARM cpu on the mini: TestExe: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.27, not stripped For QT you may need to compile QT for host and target that the application runs on the mini. I installed the latest QT on host and mini. But first of all, you need a working toolchain on your host pc.
Dear holger, I have QT SDK with QT Creator(2.4.1) with QT 4.7.4 32-bit installed on my Windows XP. I have a Tiny6410 board with DVD. DVD has 1) arm-linux-gcc-4.5.1-v6-vfp-20101103.tgz 2) S3C6410X Tool Chain 4.2.2 - EABI V0.0 - cross-4.2.2-eabi.tar I believe 1st file is for the Linux environment and not Windows. File 2 is corrupted. After searching, I learned there is this Sourcery G++ Toolchain. Holger, isn't it that QT applications can run on multi-platform. Our QT application is already running on Ubuntu Minimal version on PC platform. Could you kindly guide regarding your complete development environment? You said your application developed using QT Creator runs on PC and Mini too. Are you running the default Friendly ARM OS on Mini? Please guide me accordingly.
I am using Linux. I am not able to help you developing under Windows. I think it's easier on Linux to get all running:-) .. But not a "one-click-and-run-setup"! I think I need two weeks to get all runing:-( Someone should write a step my step howto:-) I downloaded all 3 dvd images from the FriendlyARM ftp server (the 2. I never use:-) ) : Mini6410A-20111022.iso Mini6410B-20110326.iso Mini6410B-20111022.iso From the first dvd I use the toolchain: arm-linux-gcc-4.5.1-v6-vfp-20101103.tgz Copy it to /usr (as root) and extract it (tar -xvzf arm-linux......) From the 3. dvd I installed the mini described in the docu (User's Guide to Mini6410 System Installation_040211.pdf) with the following system: rootfs_qtopia_qt4-slc.ubi From the Nokia website I get the latest Qt: qt-everywhere-opensource-src-4.8.1.tar.gz Also I get tslib 1.0.0 First you must compile tslib: ./configure --host=arm-none-linux-gnueabi --prefix=/usr/local/tslib --enable-static --enable-shared make make install Copy the folder /usr/local/tslib to the same folder on the mini. Then compile Qt twice. First for your host and second for the mini. You need both versions on your host to compile for the mini (and for your pc, to test the application on the pc). I have my exact configure options not here but you need the --host like above for the mini. For you pc you can omit this option, than the configure script takes the correct one for your cpu. Than you need the --prefix. Different for host and mini. The option with-tslib and what else you need. Try ./configure --help to get all options. After both versions are installed on your pc, copy the ARM-version also to the mini. For example to: /usr/local/Trolltech/QtEmbedded-4.8.1-arm On the mini edit the file: /etc/init.d/rcS I have added: LD_LIBRARY_PATH=/usr/local/Trolltech/QtEmbedded-4.8.1-arm/lib:/usr/local/lib: QPEDIR=/usr/local/Trolltech/QtEmbedded-4.8.1-arm QTDIR=/usr/local/Trolltech/QtEmbedded-4.8.1-arm export PATH runlevel prevlevel LD_LIBRARY_PATH QPEDIR QTDIR > Holger, isn't it that QT applications can run on multi-platform. Our QT > application is already running on Ubuntu Minimal version on PC platform. You have to compile the application with the qt-libs for pc to run it on pc and you have to compile it with the qt-libs for the mini to run it on the mini. It's both the same sourcecode that you wrote, but build with different compiler and therefor with the according libs for the compiler. Greetings
Dear holger, You are so much helpful. since the default OS preloaded with Mini/Tiny6410 has QT installed as default sample QT applications are running. I have the ARM-Linux GCC v4.5.1 installed in /opt/FriendlyARM/toolschain folder of Ubuntu Desktop PC(v11.10) I downloaded the qt_everywhere_src file from QT website and compiled. I have also downloaded ARM-Qtopia-2.2.0 file from the FriendlyARM Downloads website. I am following this tutorial: http://www.youtube.com/watch?v=ghzRuwEAWdo&feature=related I updated the path in the BASHRC file for the toolchain. I checked the ARM-GCC-Linux version for confirmation and it was ok. At one point, I did all this installation of toolchain and Qtopia on my Ubuntu Desktop machine. While building a sample 'Hello World' QT application, I got make: arm-linux-g++ not found error. I also got error 127:Permission Denied after that. May be I was close to compiling a simple application but may be some mismatch in the PATH or permission problems. I cant seem to resolve this as i followed exactly in tutorial. Your valuable help required. PS: I did followed the System Installation method as described for installation of OS using SD-Card. But somehow this is also not working. So I want to compile the application for default preloaded OS in the board as QT applications are already running in the same.
For the "arm-linux-g++ not found error": Go to /opt/FriendlyARM/toolschain/4.5.1/bin > ls -l I think there you will NOT find the arm-linux-g++ instead you will find the arm-none-linux-gnueabi-g++. make for EACH entry in this directory a symbolic link. For example: > ln -s arm-none-linux-gnueabi-g++ arm-linux-g++ After you did it like this for all in this directory you should have some like this: arm-linux-addr2line -> arm-none-linux-gnueabi-addr2line arm-linux-ar -> arm-none-linux-gnueabi-ar arm-linux-as -> arm-none-linux-gnueabi-as . . . In your PATH should be: /opt/FriendlyARM/toolschain/4.5.1/bin AND: /opt/FriendlyARM/toolschain/4.5.1/libexec/gcc/arm-none-gnueabi/4.5.1 For testing if the toolchain is working compile first a pure C or C++ application like (hello.cpp): #include <iostream> using namespace std; int main() { cout << "Hello World!" << endl; return 0; } Compile it with: > arm-linux-g++ -o hello hello.cpp and you should get the "hello" file. With the command: > file hello hello: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.27, not stripped You can see, that this is an executable for the ARM cpu. Upload this file to the mini (maybe chmod +x hello) and it should work. (On your pc this executable will not work:-) ) Is all of the above working? Then go to the next and test the qt installation. I use QT Creator (2.4.1). Make a new QT Console application ("qttest"). Source: #include <QtCore/QCoreApplication> #include <iostream> using namespace std; int main(int argc, char *argv[]) { QCoreApplication a(argc, argv); cout << "Hello QT" << endl; return a.exec(); } Press run in the Creator and it should work (if you have the correct target selected. It will only work if you have selected the QT for pc). If this works, select the QT version for the mini and build it again (make project, the icon with the hammer). In the directory of the projekt (for example "qtprogrammieng") there are now 3 subdirectorys: qttest qttest-build-desktop-Qt_4_8_1__Qt-4_8_1__Release qttest-build-desktop-Qt_4_8_1__QtEmbedded-4_8_1-arm__Release (The names could be different) In the first directory you will find the sourcecode and all projectfile from the Creator. In the other two directories you will find the file for building for the individual targets and the executables. So in the third directory is the executable for the mini. After uploading (maybe chmod) it should work on the mini. Then you should test a simple qt gui application. Don't forget to run the gui applications with the "qws" parameter on the mini: > ./mygui -qws Your install problem: "But somehow this is also not working." Is not very helpful:-) Do you connect a serial cable to the mini? If yes, you should get some error messages there. Post this here:-) If no, do so! :-) And post then the errors here. Do you prepare the SD card properly?
I can read from ./build-all at : x86-qte-4.6.1-20100201.tar.gz so I have installed qt-everywhere-opensource-src-4.6.1.tar.gz in PC, I need to install it too in tiny6410 ? Thanks ===== #/bin/bash rm -fr /opt/qtsdk-2010.01* rm -fr qt-everywhere-opensource-src-4.6.1 rm -fr /usr/local/Trolltech/QtEmbedded-4.6.1-x86 ./qt-sdk-linux-x86-opensource-2010.01.bin cd /opt/qtsdk-2010.01/qt/tools/qvfb/ /opt/qtsdk-2010.01/qt/bin/qmake "QT_SOURCE_TREE=/opt/qtsdk-2010.01/qt" make cd - tar xfvz qt-everywhere-opensource-src-4.6.1.tar.gz cd qt-everywhere-opensource-src-4.6.1 echo yes | ./configure -opensource -embedded x86 -xplatform qws/linux-generic-g++ -qt-libtiff -qt-libmng -qvfb make && make install cd /usr/local/Trolltech/QtEmbedded-4.6.1-i386
it's for touchscreen, isn't it ? I downloaded tslib-1.0.tar.bz2, can not do configure, where did you get your tslib ? thanks ============= Also I get tslib 1.0.0 First you must compile tslib: ./configure --host=arm-none-linux-gnueabi --prefix=/usr/local/tslib --enable-static --enable-shared
I have at /usr/local/Trolltech : /QtEmbedded-4.7.0-arm and /QtEmbedded-4.6.1-i386 I don't have to compile again then ? I need to copy QtEmbedded-4.7.0-arm to tiny6410 board ? Let me check, may be already there...
I use : /usr/local/Trolltech/QtEmbedded-4.7.0-arm/bin/qmake for tiny6410 and /usr/local/Trolltech/QtEmbedded-4.6.1-i386/bin/qmake for PC on Qt Creator 1.4.1 Tools->Option->Qt4.... am I right ? thanks
I used this code : #include <QtCore/QCoreApplication> #include <iostream> using namespace std; int main(int argc, char *argv[]) { QCoreApplication a(argc, argv); cout << "Hello QT" << endl; return a.exec(); } I got error when I copy qttest to tiny6410 board : ./qttest: line1: syntax error: unexpected "(" Why is that ? thanks
Dear holger, I gone through your last post and did exactly as instructed. I am able to compile a simple CPP code using arm-linux-g++ and able to run a QT console application on PC.(tested using Qt Creator 2.4.1). While running in Qt Creator, it gives me following window. 'Cannot connect creator comm socket /tmp/qt_temp.Jw3622/stub-socket: No such file or directory Press <RETURN> to close this window...' I can, however, run the application directly through the terminal. All the compiled QT files are in '/usr/local/Qt/' folder. I dont understand how you select QT version for mini. I guess it has something to do with the Toolchain setting in QT Creator; however i am unsure what needs to be put in those. I am seeing the 'linux-arm-g++' folder under Qt/mkspecs/qws/ location. Help me proceed further.
Holger, See the attached screenshot for QT version setting in QT Creator. Its pointing to x86 PC based version. Has it something to do with this? My bashrc has this path: PATH=$PATH:/opt/FriendlyARM/toolschain/4.4.3/bin After this I make and make install the QT source and it got installed in /usr/local/Qt folder. Do I need to configure the Qt Versions in Tools>Options of Qt Creator? Help.
Dear holger, I have set the Toolchains and Qt versions in Qt Creator under Tools>Options. Under Qt Version, I added the path to my Qt 'qmake': qmake location:/usr/local/Qt/bin/qmake ABI: arm-linux-generic-elf Under Toolchains, I added with GCC Compiler path: /opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi/bin/g++ With this setting, I open an example Qt project but while building it gives me error that arm-linux-g++: Command not found. In your previous post, there is arm-linux-g++ link script file in the bin folder. It points to arm-none-linux-gnueabi-g++ script file in the same location. Also you mentioned:In your PATH should be: /opt/FriendlyARM/toolschain/4.5.1/bin AND: /opt/FriendlyARM/toolschain/4.5.1/libexec/gcc/arm-none-gnueabi/4.5.1 Are you talking about the PATH in .bashrc file?
Dear holger, I am following the instructions from another thread to compile QT app for Tiny6410 board. I could compile it successfully. Just a simple hello word QT application you gave. But when i run in the board in terminal (./testQT -qws), it gives me following error: testQT: Error while loading shared libraries: libQtGui.so.4: cannot open shared object file: No such file or directory How do i proceed with resolving this error? Regards, Girish Thavai
Dear all, I was able to compile Qt application for ARM under Qt Creator in Ubuntu. I installed Xubuntu image on FriendlyARM board. Qt application was running but no touchscreen interface is working. Also when I move the mouse, the screen gets transparent meaning the background screen gets visible in the moving areas. seems I have to build tslib first and then compile Qt against the tslib. I am also trying to build application for Qtopia interface. Regards, blueshift
hey holger, thanks for these notes. they are really helpful i am stuck at point. i was compiling tslib but i this error got error --host=arm-none-linux-gnueabi: invalid command-line switch please tell me what should i do.. thanks in advance.
I configured tslib with the following command line: $ ./configure --host=arm-none-linux-gnueabi --prefix=/usr/local/tslib --enable-static --enable-shared I use the FriendlyARM toolchain (gcc-4.5.1).
I have the same compiler (gcc4.5.1), I have ommited --host=arm-none-linux-gnueabi and it started compiling tslib without any error. what does the parameter --host=arm-none-linux-gnueabi stands for?
Dear Holger! I want to create photo frame type application which should be standalone, which can change its picture by sending any command via UART from any PC. Can you tell me what things I need to do? I want to demonstrate it by this Friday.
Without the --host parameter, the tslib will be compiled for your PC and not for the Mini. But you need the tslib on the mini to get a working touchscreen. So if you don't want the touchscreen, you don't need the tslib:-) In other case.... is the arm-linux-gcc in your $PATH? Check it: $ echo $PATH I think the application you want is not the big problem:-)
hello again, i want to compile hello program i am following this tutorial http://www.youtube.com/watch?v=ghzRuwEAWdo&feature=related and now i am at final point to create a .bin file but i got the error at last stape *************************************************************** swamiz@Virtual-Ubuntu:~/arm-qtopia/hello$ ./build rm -f .obj/release-shared/moc_hello_base.o rm -f .moc/release-shared/moc_hello_base.cpp rm -f .ui/release-shared/hello_base.cpp .ui/release-shared/hello_base.h rm -f .obj/release-shared/hello.o .obj/release-shared/main.o .obj/release-shared/hello_base.o rm -f *~ core *.core /home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qt2/bin/uic hello_base.ui -o .ui/release-shared/hello_base.h arm--none-linux-gnueabi-g++ -c -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -Os -DQT_NO_QWS_VFB -DQTOPIA_DATA_LINKING -DQCONFIG=\"qconfig-qpe.h\" -DQTOPIA_TARGET=\"hello\" -DQTOPIA_TRTARGET=\"hello\" -DQT_NO_DEBUG -I/home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/mkspecs/qws/linux-arm- g++ -I. -I../qtopia-2.2.0-FriendlyARM/qtopia/include -I../qtopia-2.2.0-FriendlyARM/qt2/include -I.ui/release-shared/ -I.moc/release-shared/ -o .obj/release-shared/hello.o hello.cpp make: arm--none-linux-gnueabi-g++: Command not found make: *** [.obj/release-shared/hello.o] Error 127 **************************************************************** please tell me what should i do ? thank you.
There is a typo. Second last line you posted: make: arm--none-linux-gnueabi-g++: Command not found should be "arm-none-linux-gnueabi-g++" Greetings
I did the changes but still it gives error, this is my screen dump swamiz@Virtual-Ubuntu:~/arm-qtopia/hello$ ./build rm -f .obj/release-shared/moc_hello_base.o rm -f .moc/release-shared/moc_hello_base.cpp rm -f .ui/release-shared/hello_base.cpp .ui/release-shared/hello_base.h rm -f .obj/release-shared/hello.o .obj/release-shared/main.o .obj/release-shared/hello_base.o rm -f *~ core *.core /home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qt2/bin/uic hello_base.ui -o .ui/release-shared/hello_base.h arm-linux-g++ -c -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -Os -DQT_NO_QWS_VFB -DQTOPIA_DATA_LINKING -DQCONFIG=\"qconfig-qpe.h\" -DQTOPIA_TARGET=\"hello\" -DQTOPIA_TRTARGET=\"hello\" -DQT_NO_DEBUG -I/home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/mkspecs/qws/linux-arm- g++ -I. -I../qtopia-2.2.0-FriendlyARM/qtopia/include -I../qtopia-2.2.0-FriendlyARM/qt2/include -I.ui/release-shared/ -I.moc/release-shared/ -o .obj/release-shared/hello.o hello.cpp arm-linux-g++ -c -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -Os -DQT_NO_QWS_VFB -DQTOPIA_DATA_LINKING -DQCONFIG=\"qconfig-qpe.h\" -DQTOPIA_TARGET=\"hello\" -DQTOPIA_TRTARGET=\"hello\" -DQT_NO_DEBUG -I/home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/mkspecs/qws/linux-arm- g++ -I. -I../qtopia-2.2.0-FriendlyARM/qtopia/include -I../qtopia-2.2.0-FriendlyARM/qt2/include -I.ui/release-shared/ -I.moc/release-shared/ -o .obj/release-shared/main.o main.cpp /home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qt2/bin/uic hello_base.ui -i hello_base.h -o .ui/release-shared/hello_base.cpp arm-linux-g++ -c -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -Os -DQT_NO_QWS_VFB -DQTOPIA_DATA_LINKING -DQCONFIG=\"qconfig-qpe.h\" -DQTOPIA_TARGET=\"hello\" -DQTOPIA_TRTARGET=\"hello\" -DQT_NO_DEBUG -I/home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/mkspecs/qws/linux-arm- g++ -I. -I../qtopia-2.2.0-FriendlyARM/qtopia/include -I../qtopia-2.2.0-FriendlyARM/qt2/include -I.ui/release-shared/ -I.moc/release-shared/ -o .obj/release-shared/hello_base.o .ui/release-shared/hello_base.cpp /home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qt2/bin/moc .ui/release-shared/hello_base.h -o .moc/release-shared/moc_hello_base.cpp arm-linux-g++ -c -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -Os -DQT_NO_QWS_VFB -DQTOPIA_DATA_LINKING -DQCONFIG=\"qconfig-qpe.h\" -DQTOPIA_TARGET=\"hello\" -DQTOPIA_TRTARGET=\"hello\" -DQT_NO_DEBUG -I/home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/mkspecs/qws/linux-arm- g++ -I. -I../qtopia-2.2.0-FriendlyARM/qtopia/include -I../qtopia-2.2.0-FriendlyARM/qt2/include -I.ui/release-shared/ -I.moc/release-shared/ -o .obj/release-shared/moc_hello_base.o .moc/release-shared/moc_hello_base.cpp arm-linux-g++ -o hello .obj/release-shared/hello.o .obj/release-shared/main.o .obj/release-shared/hello_base.o .obj/release-shared/moc_hello_base.o -luuid -lqtopia2 -lqtopia -lqpe -L/home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/lib -L/home/swamiz/arm-qtopia/qtopia-2.2.0-FriendlyARM/qt2/lib -lqte /opt/FriendlyARM/toolschain/4.5.1/lib/gcc/arm-none-linux-gnueabi/4.5.1/../../../ ../arm-none-linux-gnueabi/bin/ld: cannot find -lqtopia2 collect2: ld returned 1 exit status make: *** [hello] Error 1
I was able to use "make" but when I try make install it gives error commandline: swamiz@Virtual-Ubuntu:~/qt-everywhere-opensource-src-4.6.2$ make install and some the last lines of the error: g++ -Wl,-rpath-link,/home/swamiz/qt-everywhere-opensource-src-4.6.2/lib -fno-exceptions -Wl,-O1 -Wl,-rpath,/usr/local/Qt/lib -Wl,-rpath,/usr/local/Qt/lib -o ../../../bin/moc release-shared/moc.o release-shared/preprocessor.o release-shared/generator.o release-shared/parser.o release-shared/token.o release-shared/main.o -L/home/swamiz/qt-everywhere-opensource-src-4.6.2/src/tools/bootstrap -lbootstrap -lz mkdir: cannot create directory `/usr/local/Qt': Permission denied make[1]: *** [install_target] Error 1 make[1]: Leaving directory `/home/swamiz/qt-everywhere-opensource-src-4.6.2/src/tools/moc' make: *** [sub-moc-install_subtargets-ordered] Error 2 I have also tried "make clean" I even made the Qt directory in usr/local still I get the same error can you help me out ...
Good morning holger! I have succeeded doing make install. It ended without error but I can't find hello executable in the folder. which files should I port in 2440 and how?
Can anyone help? I cannot make the Cross compiler working/ in the terminal, arm-linux-g++ -v showing the arm-linux-gcc is installed but in qt4, (ubuntu environment) When compile, it complains arm-linux-g++: command not found? How do we choose the toolchain? Because, the Qt Version i choose the Qt Embedded but initially there is a problem saying there is no toolchain can provide code. After i use add GCCE path: /opt/FriendlyArm/.../g++ it just has a waraning says no xml installed. But what is wrong with the toolchain then?
m using windows 7/ ubantu both i am created my program in both plz say me that "how to compile & run my tiny 6410" thanx........
hi all, i have a problem (or problems :)) my mini6410 board's touch screen does't work with qt app. It works with qtopia but it doesn't with qt app. "cat /dev/touchscreen-1wire | hexdump" command best work. please help me. thank you.
Sir, I am trieng to port Qt 4.8.3 and run application in tiny6410. What i have done is 1. Cross compiled qt-everywhere-opensource-src-4.8.3.tar.gz a) Extracted b) ./configure -opensource -embedded arm -xplatform qws/linux-arm-g++ -no-webkit -qt-libtiff -qt-libmng -qt-mouse-tslib -qt-mouse-pc -no-mouse-linuxtp -no-qt3support -nomake examples -prefix /usr/local c) make and make install 2. Removed existing Qt in board (/usr/local/Troltech/Qt4-embedded) 3. I copied the qt-4.8.3 (crosscompiled) lib file in tiny/mini6410 /usr/local/Troltech/Qt4-embedded 4. Crosscompiled simple helloworld application in hostpc and copied to pendrive and insertd in Tiny6410. 5. I put board terminal server shutdown and run "./hello -qws" it is saying libqtgui.so.4 not found:no permission to run shared library. " I didnt understand one thing setting encironment variables as per http://www.sereno-labs.com/Qt_4.8.3_installation_procedure_FriendlyARM_m... (because it is written for mini2440) environment variables on the mini2440 board: export TSLIB_TSEVENTTYPE=INPUT export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_TSDEVICE=/usr/input/ts export TSLIB_CALIBFILE=/usr/etc/pointercal export TSLIB_CONFFILE=/usr/etc/ts.conf export TSLIB_PLUGINDIR=/usr/lib/ts export LD_LIBRARY_PATH=/usr/local/Qt/lib export QTDIR=/usr/local/Qt export QWS_MOUSE_PROTO=tslib:/dev/input/event0 export QWS_DISPLAY=LinuxFB:mmWidth=310:mmHeight=190 The Qt library binary (and fonts subdir) shall be placed on a user defined directory of the mini 6410 board and then it is necessary to set LD_LIBRARY_PATH to this directory. Kindly help me . please give a understandable document because i am a beginner
hi every one I have a solution for the problem arm-none-linux-gnu......... command not found .. if you are using qt creator just go in kits (found in option) then go in environment variables in that u will find PATH......double click on that and in last add":/....../..../"(ur path where u extracted ur arm-none-linux........... /bin/) recompiled it will I'll be solved for sure
