hi, I tried to install tiny6410 usb driver in my lap(windows xp 32 bit), its getting installed but when i try to connect my tiny6410 kit via USB that time the USB is not detecting and its not there in device manager list also.. i opened dnw software thr usb=X(not detected)..PLS help me..
USB installation problem(tiny6410)
First, are the drivers for DNW installed? You should see in your C:\WINDOWS\SYSTEM\drivers two files called SECBULK.sys and SECBELK.inf They are found on the downloads page. Second, I found that I needed DNW running on the PC, the mini2440 in NOR mode and running (you'll see the user menu in DNW) AND then plug in the USB cable.
Hi, I checked in C:\WINDOWS\SYSTEM\drivers but the two files(SECBULK.sys and SECBELK.inf) are not there..so i downloaded that files from frienly arm web site,then i extract that zip file,in that extracted folder i found those two files and i copied those files into that "system" location. previously in DNW software shows both COM=X and USB=X but now its shows like this(COM:1,115200 and USB=X) i think COM is displaying something. Still usb is not working..the think is after i installed the usb driver file i connect usb cable to the system..that time it should detect and ask for installing and finishing driver software but its not doing anything... what may i do... if i connected serial cable then its gives this following commands, OK U-Boot 1.1.6 (Jul 21 2011 - 12:49:00) for FriendlyARM MINI6410 CPU: S3C6410@532MHz Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC Mode) Board: MINI6410 DRAM: 256 MB Flash: 0 kB NAND: 2048 MB *** Warning - bad CRC or NAND, using default environment In: serial Out: serial Err: serial data abort pc : [<c7e11714>] lr : [<c7e11490>] sp : c7ffff24 ip : 00000000 fp : c8000000 r10: c7ffffff r9 : 00000003 r8 : be73eff6 r7 : c7e608d4 r6 : c7e26b0e r5 : c7e608d5 r4 : c7ffff5c r3 : 000000ff r2 : 00000001 r1 : 00000000 r0 : ffffffff Flags: nzCv IRQs off FIQs off Mode SVC_32 Resetting CPU ... data abort pc : [<c7e13034>] lr : [<c7e1a1f8>] sp : c7fffeac ip : 00000000 fp : c8000000 r10: c7ffffff r9 : 00000003 r8 : be73eff6 r7 : c7e608d4 r6 : c7e26b0e r5 : c7ffff10 r4 : c7ffff5c r3 : e1a0b80b r2 : c7e14a64 r1 : 0000000a r0 : 0000000a Flags: Nzcv IRQs on FIQs on Mode SVC_32 Resetting CPU ... data abort pc : [<c7e13034>] lr : [<c7e1a1f8>] sp : c7fffe34 ip : 00000000 fp : c8000000 r10: c7ffffff r9 : 00000003 r8 : be73eff6 r7 : c7e608d4 r6 : c7e26b0e r5 : c7fffe98 r4 : c7ffff5c r3 : e1a0b80b r2 : c7e14a64 r1 : 0000000a r0 : 0000000a Flags: Nzcv IRQs on FIQs on Mode SVC_32 Resetting CPU ... data abort pc : [<c7e13034>] lr : [<c7e1a1f8>] sp : c7fffdbc ip : 00000000 fp : c8000000 r10: c7ffffff r9 : 00000003 r8 : be73eff6 r7 : c7e608d4 r6 : c7e26b0e r5 : c7fffe20 r4 : c7ffff5c r3 : e1a0b80b r2 : c7e14a64 r1 : 0000000a r0 : 0000000a Flags: Nzcv IRQs on FIQs on Mode SVC_32 Resetting CPU ... data abort pc : [<c7e13034>] lr : [<c7e1a1f8>] sp : c7fffd44 ip : 00000000 fp : c8000000 r10: c7ffffff r9 : 00000003 r8 : be73eff6 r7 : c7e608d4 r6 : c7e26b0e r5 : c7fffda8 r4 : c7ffff5c r3 : e1a0b80b r2 : c7e14a64 r1 : 0000000a r0 : 0000000a Flags: Nzcv IRQs on FIQs on Mode SVC_32 Resetting CPU ... data abort pc : [<c7e13034>] lr : [<c7e1a1f8>] sp : c7fffccc ip : 00000000 fp : c8000000 r10: c7ffffff r9 : 00000003 r8 : be73eff6 r7 : c7e608d4 r6 : c7e26b0e r5 : c7fffd30 r4 : c7ffff5c r3 : e1a0b80b r2 : c7e14a64 r1 : 0000000a r0 : 0000000a Flags: Nzcv IRQs on FIQs on Mode SVC_32 Resetting CPU ...
I would check that you can use DNW on the 6410 series. I have seen quite a few postings on here about getting this model to boot. Try searching <superboot> and <mini6410 boot> Good luck!
hi, I checked in C:\WINDOWS\SYSTEM\drivers but the two files(SECBULK.sys and SECBELK.inf) are not there..so i downloaded that files from frienly arm web site,then i extract that zip file,in that extracted folder i found those two files and i copied those files into that "system" location. previously in DNW software shows both COM=X and USB=X but now its shows like this(COM:1,115200 and USB=X) i think COM is displaying something. Still usb is not working..the think is after i installed the usb driver file i connect usb cable to the system.the dnw is opening but when i pressed any key na its not proceeding for further step.that time it should detect and ask for installing and finishing driver software but its not doing anything...
In addition to the Two Recommendation of Mr Davef you must empty the SD ram from any "Images" directory Or Rename It to ant other names.Then the PC will recognize the USB driver simply. 84
