I'm using the host side USB interface and USB gadgets on my Mini2440. I'm having problems with them and would like to debug them. In the kernel I've enabled the following to debug the USB gadgets: CONFIG_USB_GADGET_DEBUG=y CONFIG_USB_GADGET_DEBUG_FILES=y CONFIG_USB_GADGET_DEBUG_FS=y and to debug the host interface I've enabled: CONFIG_USB_MON=y But, when I try and cat /var/log/dmesages i get a messages: cat: can't open '/var/log/dmesg': No such file or directory
Debugging USB gadgets and USB interface
Did you read the "Documentation/usb/usbmon.txt" in the kernel source tree how to make use of the USB_MON feature?
Hi Juergen, I'm not at usbmon yet. I first want to debug the usb gadgets then I will try the host side. But when I try debug the usb gadgets using: cat /var/log/dmesg I get: cat: can't open '/var/log/dmesg': No such file or directory
If you are using PTXdist there is no file called that in /var/log Either just type dmesg or /var/log/messages and use an editor to look at it.
As Dave already said: the "dmesg" tool shows you the kernel messages. They are also visible on the kernel console (add 'debug' to your kernel command line or run 'dmesg -n8' to see the debug as well). Or enable/start the 'syslogd' and 'klogd' to get the log-files in '/var/log'
