Tiny210
BBBB
Has anyone had success in building an Nk.bin from the mini210 BSP and
having this boot all the way up to loading explorer/desktop?
My build gets stuck with the following output on the console:
DEVICE!DevloadInit
DEVICE!InitDevices:  Root  Key  is  Drivers\BuiltIn.
DEVICE!RegReadActivationValues  RegQueryValueEx(Drivers\BuiltIn\Prefix)
returned  2
DEVICE!RegReadActivationValues  RegQueryValueEx(Drivers\BuiltIn\BusPrefix)
returned  2
RegQueryValueEx(Drivers\BuiltIn\NANDFLASH\BusPrefix)  return  ed  2
DeviceFolder::LoadDevice(Drivers\BuiltIn\NANDFLASH)  last  8
TicksDEVICE!RegReadActivationVa  lues
RegQueryValueEx(Drivers\BuiltIn\Drvlib\Prefix)  returned  2
RegQueryValueEx(Drivers\BuiltIn\Drvlib\BusPrefix)  returned  2
DMSG:  DrvWAITInitialize
+  NKKernelLibIoControl
-  NKKernelLibIoControl
Kernel  DLL  'drvlib.dll'  needs  thread  creation/deletion  notification
DEVICE!CreateDevice:  illegal  entry  point  combination  in  driver  DLL
'drvlib.dll'
CreateDevice:  creation  of  type  '<unnamed>',  index  0,  lib
'drvlib.dll'  returning  0x00000000  ,  error  code  1
DEVICE!I_ActivateDeviceEx:  couldn't  activate:  prefix  <nil>,  index  0,
dll  drvlib.dll,  conte  xt  0x1
DeviceFolder::LoadDevice(Drivers\BuiltIn\Drvlib)  last  55  TicksFILESYS:
Waiting  for  bootabl  e  file  system  to  be  mounted.
FILESYS:  Waiting  for  bootable  file  system  to  be  mounted.
As you can see something goes wrong with the mounting of a bootable drive
through drvlib in which to store the registry and so it cannot proceed any
further.
I see from Chinese forums that there is a more recent BSP release in early
May but cannot test if this one works as I can't find any download link at
this stage.  (I'm using the 26th of March version).
Any ideas would be appreciated.
GOPI
I am also getting same error
execution stops after this..
Any help appreciated..
dezso
Is this same with the armdevs.com BSP ? What is the different anyway?
Tiny210V2-S5PV210 Samsung Series
Tiny210V2SDK | S5PV210 ARM Cortex-A8 Stamp Module
I'm just about buying 2 from them and a rep responded to my mail that their
BSP work 100% with all advertised module on wince6r3
Gopi
BSP is not matured yet.. Eboot + Stepldr source code not available, but
they advertise they have it. USB driver not available, and moreover if you
have 64 bit OS, then it will not work. Ethernet Bootloader not available.
Just Check with them first
kuhdav
I believe to have the same problems.
I bought a couple of samples from CoreWind and I built the NK.BIN.
I dodn't change anything; building is successful but the NK.BIN doesn't get
loaded.
I thought to build a debug image but I saw it's useless because i'g give
the same results as BBBB.
Anyway the NK.BIN I found on the DVD (included with board) get loaded and
work properly. So SOMEONE succeeds to have a working image.
