DNW not showing anything
Sumeet Thakre
Hello all,
I have purchased new mini6410 few days ago. It comes with linux installed.
I want to install Wince in that. but when I connect it with the DNW (With
boot select switch at SDBOOT, bootable SD card inserted) I did not get
anything on DNW screen. ie no bootloader menu on screen.
please guide me.
where I am doing wrong?
Sumeet Thakre
I Changed the USB cable and got mootloader menu on screen.
But now when I press F to format NAND It is not receiving my input.
why this is so?
Sumeet Thakre
Tried everything but no success.
DNW shows for WinCE [COM1,115200bps][USB:OK][ADDR:0x32000000]
##### FriendlyARM Superboot for 6410 #####
[f] Format the nand flash
[v] Download uboot.bin
[k] Download Linux/Android kernel
[y] Download root yaffs2 image
[u] Download root ubifs image
[a] Download Absolute User Application
[n] Download Nboot.nb0 for WinCE
[l] Download WinCE bootlogo
[w] Download WinCE NK.bin
[b] Boot the system
[s] Set the boot parameter of Linux
[d] Download and Run an Absolute User Application
[i] Version: 1051, RAM 256 MiB, NAND 1024 MiB
Enter your Selection:|
BUT WHEN TRYING TO PRESS ANY OF THE COMMAND ( f, n, b ....) NOTHING
HAPPENS.
NOT GETTING ANY RESPONSE FROM TARGET BOARD.
usb download driver is also installed but no success.
VERY STRANGE PROBLEM.
please suggest any solution.
Sumeet Thakre
Hello all,
Problem got solved.
USB Downloader setup was faulty.
kalki
hi summet
i got same problem with mini2440
i can get a bootloader menu ..but couldnt select any command as u
mentioned..
please suggest the solution
