I'm using prxdist 2011.05 with Mini2440 BSP 2011.05 I would like to update my CP2102 USB Serial Driver. I've downloaded the latest driver from : http://www.silabs.com/products/mcu/pages/usbtouartbridgevcpdrivers.aspx Looking at the /build-target/linux-2.6.38/drivers/usb/serial It does not seem like the CP2102 has any dependencies other than the cp2102.c source file. What I've done is I made a backup of the old driver source file and copied the new one. I've dropped the kernel compilation ptxdist drop kernel.compile and then re-compiled it but it does not seem like the new cp2102 drivers source was compiled. 1.) Is this the correct way to update the driver? 2.) How can I ensure that the new source is compiled when compiling the kernel? Thank you
CP2102 driver update
I've deleted the cp2102.o file, dropped the kernel and now its compiling the new driver source but it does not succeed. I know I'm not doing it the correct way so please advice. Thank you.
Have you done: ptxdist newpackage src-linux-driver Try making their example then go back and substitute the source code and re-build. I don't know if it will then write over your original driver or ? I have only used the ptxdist src-make-prog option. Also, the [*] and [m] options appear to mean something slightly different when using PTXdist menuconfig then when using PTXdist kernelconfig. Good luck
Hi Dave, I'm not sure how to use this command. I get a feeling I need to specify the driver package somewhere. I execute "ptxdist newpackage src-linux-driver" but I get a response: usage: 'ptxdist newpackage <type>', where type is: ......
Ok, its supposed to create a new directory with a driver template. But it doesn't. Unless I'm looking in the wrong place.
?? Try ptxdist newpackage --help Try ptxdist newpackage src-make-prog Also, you have to type the whole command in as driver is inputted as dirver instead of driver!
After adding the package, is it configurable? From menuconfig or kernelconfig? If it is, where in the menu shall I find it? Thanks!
In menuconfig you can choose it and evidently say how you want it built. Note my previous comment re my uncertainty about [*] [m}
