Hi, I have a general question concerning development on embedded linux systems. I have my mini2440 compiled kernel and rootfs with buildroot. Now the question, what's the right way and how to do it? I mean after creating rootfs with buildroot I have a jffs2 file system, which is flashed in the NAND. The system still isn't complete, I will have to do some additonal things, for example configur ip adreess, load websites on it, configure user, passwords, addional self compiled software etc..... this is all stored on the flash file system in the nand. The question is now, how make an image of this ready configured system, for deploying it to other mini2440 board, or only in order to have a backup copy, in case of any problem. Or do I have to integrate all this things already in the buildprocess of buildroot? What's the rigth way and how do you generate your images ready for shipping and deployment? How do you make it reproducable? Thanks a lot
rootfs image/recovery?
At the moment I write it with linux pc to a sd card and load it with uboot in the ram and write it with uboot to the nand. why is this of interest? I think this is a general question, concerning all embedded systems running linux, therefore this should be independent of the method of flashing the jffs2? what is the method? - integrating everything in buildroot? so every time a complete image including all settings is generated. this maybe would be the best reproducable process? - creating with buildroot, customising the file system on the linux pc, and then flashing - creating with buildroot, flashing, customizing the file system on the target, and then making a backup image of the file system. Would mean booting with uboot, reading fs into ram and store it to disk? For projects in industry, this seems to be an essential question for me, to have reproducable "firmware" from sources, but how can this achieved here including kernel, rootfs, custom software which is not in buildroot, own software and any sort of configuration. Anyway, how do you save/backup your buildroot environment, sources and toolchain on your working pc, in order to reproduce this, on another pc or your own in case of system crash. Is it sufficient to make a tarball of the buildroot directory and store this?
> Anyway, how do you save/backup your buildroot environment, sources and > toolchain on your working pc, in order to reproduce this, on another pc > or your own in case of system crash. We'll wait for people with real industry experience to answer these. But, my 2 cents worth . . . From an non-professional point of view I just make copies of my root directory, root config file (I am using a BSP) and kernel config files. A copy of the toolchain saved to a backup disc MARKED for a specific host machine. I believe that you should not copy toolchains across to another brand or model of PC. Evidently, a specific toolchain can behave differently on another machine. I am not smart enough to know when you can get away with it! > Is it sufficient to make a tarball of the buildroot directory and store > this? I understand that you need to keep everything associated with a particular build. The toolchain, with its libraries, the kernel source and how you built everything. In my case the version of the BSP.
"For projects in industry, this seems to be an essential question for me, to have reproducable "firmware" from sources, but how can this achieved here including kernel, rootfs, custom software which is not in buildroot, own software and any sort of configuration." The programming from SD card has tremendous advantages in production. You make as many SD cards as you need to keep up with production, depending on loading time. When the first one finishes you put the SD card in the next one to be programmed. In the Chinese plants you will see a long row of PCs set to program embedded boards. The Mini6410/210 do this automatically. The bottleneck is testing. You could have 3 or 30 in process. The bottleneck is testing, if it is needed.
