Hello I'm trying to use the libjpeg to read a jpeg file and extract the image bitmap for showing in the display using the framebuffer. When I write 'sh configure' in the jpeglid source code diretory it show me the following: ---- [plg@friendlyARM 2.6.32.2-FriendlyARM jpeg-6b]# sh configure : not foundline 2: : not foundline 9: : not foundline 22: : not foundline 56: : not foundline 62: configure: line 64: syntasyx error: bad for loop variable ---- How someone explain me what is the problem? I only need extract the image from jpg if you know other way to do that please let me to know. If someone already has got the libjpeg compiled for micro2440 could you send me?
Using libjpeg for micro2440
My suggestion is unless that person has used the same compiler and library versions as you do then you are likely to get into a "muddle". Here is my compile script for libjpeg, just change the path to your compiler and the directories as required.
