I have a mini210 running Android and I am now able to build the Linux Android kernel for it and also the Android OS on Ubuntu. I am working on the Kernel to add in GPIO functionality and I want to be able to just update the Kernel from SD card and not the Android OS. Is this possible by just setting the kernel only in the ini file? I don't want to have to flash the complete Android OS each time with the kernel as it takes quite some time and no changes are required to the Android part for now. Thanks Dave...
Updating Kernel only on mini210
Hello, I'm interested in this too... However, building kernel takes much more time than flashing Android, it would be nice if it was possible to load only kernel. If you (or someone else) have found the solution, I would be very thankful if you posted it here
comment out the parts that you don't want to update with a # at the beginning of the lines in FriendlyARM.ini
