Hello, My current mini2440 is starting to fail so I want to replace it but how can I write the current filesystem to my memory card for reinstallation on the other device? My best guess would be: nand read.jffs2 0x31000000 fatwrite mmc 0:1 0x31000000 myimage.jffs2 Is this correct? (before I screw something up)
copying flash
OK, that's a good reason! How about usbpush then. I know it will load files into flash, so I imagine it can do the reverse. Your commands look sensible, however I can't confirm if it is right. Good luck!
