Hi, i compile my kernel for a mini2440 with buildroot. I flashed uboot (download from friendly arm), as own generated with buildroot is not running. (Any Ideas why?) wrote kernel and jffs2 file system to nand. Kernel is booting, but with filesystem something is wrong: I get many errors like this: ----------------- jffscan2_scan_eraseblock(): Magic Bitmask ... not found... ... Node at ... would run over the end of the erase block Perhaps the file system was created with wrong erase block size? --------------- Whats wrong here? Where can I set erase block size in buildroot / uboot ? and what's the right erase block size? any ideas?
jffs2 eraseblock size
From here: http://code.google.com/p/friendlyarm/wiki/Linux_Tutorial For the older 64M mini2440 . . . -e 16 sets the erase block size used by mkfs. mkfs.jffs2 –lqnp –e 16 –r target –o output/my_rootfs.jffs2 I believe all the other machines use the same erase block size but I'd have to search for it.
Make that: I believe all the other machines use the same BUT different erase block size to the 64M machine, but I'd have to search for it.
The erase block size of the 64 MiB NAND part is 16 kiB, all other known to work NANDs use 128 kiB erase block size.
