ptxdist path corruption
strgezer
using ptxdist to setup builds for some i2c code i'm writing.   i created a
new project, and now when i type 'ptxdist go', i get this error:
ptxdist: error: failed to source lib:
/usr/lib/ptxdist-2012.05.0/scripts//lib/ptxd_make_00-init.sh
the make script it is trying to reference exists in the path, only without
the double forward slashes.   i am assuming i somehow corrupted the path to
the script file.   problem is, i can't find this path in any of the ptxdist
config files i can see.
can anyone tell me how i can correct this?
Juergen Beisert
The path seems all right. Only PTXdist is somehow confused. PTXdist is
project centric. So, you must start it always in a project context, which
means a directory with some important configure files in it
("selected_platformconfig" for example and "selected_ptxconfig"). Did you?
strgezer
i re-ran all the config tasks suggested in the quickstart document.   i
even did a fresh download of the oselas BSp for the 6410, along with a
fresh download of ptxdist installation files.   i still get the error
message shown in the original post.   the file it's looking for exists, but
not with the double-slash 'scripts//lib'   in the path.   this path seems
to be defined elsewhere, but i don't know where.
Juergen Beisert
Can you access this file as a regular user?
strgezer
as either user or root, i can access this path:
/usr/lib/ptxdist-2012.05.0/scripts/lib/ptxd_make_00-init.sh
but not not this one(the one ptxdist is trying to access)
strgezer
this is driving me insane.   okay, i figured out that the double-slash
doesn't mean anything, this is just another brain-damaged linux quirk. i
read on the ptxdist developer web archives not to use version 2012.05.0, so
i backtracked to ptxdist-2011.11.0.
i get the same error.
what gives?????
Juergen Beisert
The "ptxd_make_00-init.sh" script is responsible for the toolchain
interaction. Is it possible that your own new project is incomplete?
PTXdist depends on some config files. What does "ptxdist toolchain" outputs
in your project?
