Hardware (?) problem
thom
I've got some problem with my mini2440 board. I guess it must have been
caused by some short circuit.
It's not possible to boot the board from both NOR and NAND flashes, I could
see only empty console (it's not a problem with serial cable for sure).
I tried to do flashing using JTAG but altough NOR flashing is successful it
doesn't help. I tried also to flash NAND flash but flashing tool says
"Can't halt target and make it enter into debug state. Please try again
with lower CLK speed. For MCU with multiple JTAG controllers, please also
check the TAP configuration and make sure it has been set properly". When
this message appears I could hear also some crash from inboard buzzer.
Do You've got any other ideas ?
Regards,
Tomasz
