I'm trying to get ptxdist setup and running on a new computer, but can't get past this error when running 'ptxdist go' I'm using the 12.02.0 build of ptxdist and the BSP, and the 2011.11.1 toolchain. I haven't changed any settings in menuconfig, kernelconfig etc. The host machine is 32 bit ubuntu 12.04. libfakeroot.so exists in platform-mini2440/sysroot-host/lib I've tried 'ptxdist clean', but it has no effect. What do I try next?
fakeroot: preload library `libfakeroot.so' not found, aborting.
New Computer? Did you copy the already built BSP to the new computer? Many libraries compile in static paths, so if you change the path via move or copy it does not work anymore. Until you rebuild everything, which also creates new paths.
davef: I was assuming it was the fakeroot in the BSP it was looking for. If it's the host's fakeroot, that might be the reason. It's installed, but /usr/lib/libfakeroot/ contains libfakeroot-sysv.so and libfakeroot-tcp.so. Not libfakeroot.so. I assume this is a ubuntu thing. Juergen: I built the BSP on the new machine.
