Hello all, I have been generated a filesystem with buildroot for my Micro2440 board. I have run mkyaffs2Image-128M on my buildroots's output/target directory. I have uploaded the image with usbpush. The factory default kernel boots up, but it cannot load the busybox: yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem) on device 31:2. Freeing init memory: 128K and nothing happends. Any help would be appericated.
How to make a yaffs filesystem
Have you checked you have the libraries included for BusyBox if you set it up for dynamic linking? I had problems on my 64M system until I linked it statically. Now, that I have a working system I must go back and try dynamic linking. Good luck!
Try adding this parameter to the kernel command line init=/bin/sh This will cause the kernel to load a shell right away and skip the regular init process. If this works, look at the /etc/inittab file and work through that line at a time to find the culprit. Failure here means that the system in question: 1- Does not have a /bin/sh symlink 2- Cannot load busybox You can look at your file system image to determine #1, but #2 will require you get a running board first. If you're creating a new root file system, try to mount it via NFS before creating a JFFS2 image, because it's easier/faster to make changes to the RFS. Visiting the University of Google will turn-up lots of articles about using NFS to remotely mount a root file system via NFS. Regards, gene
I had the same problem when I compiled busybox the the Coudesourcery toolchain. I changed to buildroot - that generates it's own toolchan - and the problem went away :-)
Thank you very much for the answers. davef: I have built the busybox to be linked dynamically. (This is the buildroot's default option.) gene.sally: I have modified the init kernel parameter to /bin/sh, and now I got: yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem) on device 31:2. Freeing init memory: 128K Kernel panic - not syncing: Attempted to kill init! I have checked there is bin/sh symlink to bin/busybox on my target directory. The default linuxrc is the symlink too to same file: bin/busybox. I do not understand why the result is different if both files point to the same file. sam: I have been used the buildroot's toolchain.
>> Kernel panic - not syncing: Attempted to kill init! This is a good hint. What is the kernel command-line? What parameters were used to build the file system? What version of yaffs was used? How was this file system written into flash -- did you use uboot or something else? Can you mount this same file system over the network (with a running file system) to ensure that this file system works? You need to isolate this as a yaffs, busybox or library problem so attention can be concentrated in the right area. You can turn-on debugging by changing some flags in the yaffs source? >>point to the same file Busybox inspects argc[0] to figure out what "applet" to run. Regards, gene
I am using a stock micro2440 board with the default supervivi. The kernel parameters are: noinitrd root=/dev/mtdblock2 init=/bin/bash console=ttySAC0 I have made my image with the mkyaffs2image-128M tool, what I have downloaded from this site. mkyaffs2image: image building tool for YAFFS2 built Jul 9 2009 I have configured, and built the buildroot, and I have run mkyaffs2image-128M /opt/buildroot-2009.11/output/target/ /home/mm/rootfs.bin I will try out the NFS filesystem as rootfs.
@Miklós Márton: > I have run mkyaffs2Image-128M on my buildroots's output/target > directory. Oh, that I overlooked. Make "ls -l output/target/dev". You'll see, all major/minor are 0. The correct major/minor are created when buildroot creates the actual image, but not the target directory (at least with the latest stable buildroot). The way to this correct is: - create a *.ext2 rootimage - mount it - run mkyaffs giving the mountpoint. Make ext2, 'cause you'll probably want to modify the contents befor building the yaffs image. You might want to remove all devices except /dev/console from the rootimage if you intend to use busybox mdev (which I found to be a great advantage)
I have created the ext2 image mounted with: sudo mount -t ext2 -o loop -o rw output/images/rootfs.arm.ext2 /tmp/fs/ I have run mkyaffs2image-128M /tmp/fs/ /home/mm/out.bin I have uploaded it, and now it reboots without any messages after the bootup. I have removed all the /dev/ files expect the console. (I have compiled the busybox with mdev.) The result is the same. I have tried bot /linuxrc and /bin/sh as kernel parameter. Currently I'm using the factory default 2.6.29 kernel. I have built the buildroot with 2.6.29 too, but I could not upload the generated zImage, because it is too large.
And decompressing the kernel hangs for ever? I'd suggest you recompile your kernel. Kick out anything you do not need for the first steps - you can add stuff later - do not make loadable modules and keep it small. Then try again.
No. IMHO the kernel loads, and boots up fine, but when it starts the busybox it hangs. I will try to compile and load a smaller kernel.
In your micro2440out.txt it looks like you are trying to uncompress the kernel twice. Haven't seen that one yet!
I noticed this about the output 1- kernel command line is missing rootfstype=yaffs2 2- Problems with the flash mtd: partition "root" extends beyond the end of device "NAND 128MiB 3,3V 8-bit" -- size truncated to 0x7da0000 0x000000000000-0x000040000000 : "nand" mtd: partition "nand" extends beyond the end of device "NAND 128MiB 3,3V 8-bit" -- size truncated to 0x8000000 This should match your flash device. Not sure if this made any difference with the result. I thought that the rootfstype was required nowadays. Also, when programming the nand memory, are you doing an "erase" first, or does the bootloader do an erase automatically? So it seems like we still don't know if the kernel RFS has mounted, but it could be in limbo somewhere before init ever runs (this is what I suspect...); there are a few ways to debug this. 1- Write a simple "hello world" program, statically link it, run that for init That will eliminate issues with the file system itself. This program should be linked with -static so it has no dependencies. 2- Up the YAFFS debugging You can do this at compile time by or-ing some things to debugMask (the default tracemask is in yaffs_fs.c and is set to YAFFS_TRACE_BAD_BLOCKS | YAFFS_TRACE_ALWAYS, I think the rest are in yportenv.h. 3- Create an NFS file system, boot into that, then inspect file system This will take a while, but you can mount the file system you created and mount that remotely. Once you're running, you can then mount the YAFFS file system and see what happens in a more forgiving environment than system boot-up. When you build your root file system, include "strace", this lets you see the system calls a program invokes, which is very handy for debugging. In all, this is a fairly difficult thing to debug... Regards, gene
I've placed my kernel here: http://www.friendlyarm.net/forum/topic/434?lang=en#1934 You could give it a try, maybe it'll work.
Hmm. I have placed back the default qtopia image. I have copyed to the sd card the /usr/bin/ts_* binaries from my root fs, and I have tried to run them, and I got: [root@FriendlyARM /sdcard]# ./ts_print -/bin/sh: ./ts_print: not found Is it normal? If these binaries have dependencies it should be reported. Now I am not sure about, that I am using the right buildroot config: I have selected: Target architecture: arm '' variant: arm920t target ABI: EABI
The binaries are not exchangeable between uClibc buildroots (that's stated somewhere on the buldroot bomepage).
Davef, quick question; could you explain how you linked BusyBox statically with Buildroot? Thanks, PJvG
Thanks anyway, I was able to do it now with Buildroot. ;) Hopefully my rootfs image will load now since I was having problems with that..
I am new to the mini6410 ,i have problem install in linux below this error ll come usbcore: registered new interface driver iuu_phoenix iuu_phoenix: v0.12:Infinity USB Unlimited Phoenix driver USB Serial support registered for Keyspan - (without firmware) USB Serial support registered for Keyspan 1 port adapter USB Serial support registered for Keyspan 2 port adapter USB Serial support registered for Keyspan 4 port adapter usbcore: registered new interface driver keyspan keyspan: v1.1.5:Keyspan USB to Serial Converter Driver USB Serial support registered for Keyspan PDA usb 1-1: new full speed USB device using s3c2410-ohci and address 2 USB Serial support registered for Keyspan PDA - (prerenumeration) USB Serial support registered for Xircom / Entregra PGS - (prerenumeration) usbcore: registered new interface driver keyspan_pda keyspan_pda: v1.1:USB Keyspan PDA Converter driver USB Serial support registered for KL5KUSB105D / PalmConnect usbcore: registered new interface driver kl5kusb105d kl5kusb105: v0.4:KLSI KL5KUSB105 chipset USB->Serial Converter driver USB Serial support registered for KOBIL USB smart card terminal usbcore: registered new interface driver kobil kobil_sct: 21/05/2004:KOBIL USB Smart Card Terminal Driver (experimental) USB Serial support registered for MCT U232 usbcore: registered new interface driver mct_u232 mct_u232: z2.1:Magic Control Technology USB-RS232 converter driver USB Serial support registered for Moschip 2 port adapter mos7720: 2.1:Moschip USB Serial Driver usbcore: registered new interface driver moschip7720 USB Serial support registered for Moschip 7840/7820 USB Serial Driver mos7840: 1.3.2:Moschip 7840/7820 USB Serial Driver usbcore: registered new interface driver mos7840 USB Serial support registered for moto-modem usbcore: registered new interface driver moto-modem USB Serial support registered for navman usbcore: registered new interface driver navman USB Serial support registered for ZyXEL - omni.net lcd plus usb usbcore: registered new interface driver omninet omninet: v1.1:USB ZyXEL omni.net LCD PLUS Driver USB Serial support registered for opticon usbcore: registered new interface driver opticon USB Serial support registered for GSM modem (1-port) usbcore: registered new interface driver option option: v0.7.2:USB Driver for GSM modems USB Serial support registered for oti6858 usbcore: registered new interface driver oti6858 USB Serial support registered for pl2303 usbcore: registered new interface driver pl2303 pl2303: Prolific PL2303 USB to serial adaptor driver USB Serial support registered for qcaux usbcore: registered new interface driver qcaux USB Serial support registered for Qualcomm USB modem usbcore: registered new interface driver qcserial safe_serial: v0.1:USB Safe Encapsulated Serial USB Serial support registered for safe_serial usb 1-1: New USB device found, idVendor=05e3, idProduct=0606 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usbcore: registered new interface driver safe_serial USB Serial support registered for sam-ba usb 1-1: Product: USB Hub 2.0 usbcore: registered new interface driver sam-ba sam_ba: v1.0: Atmel SAM Boot Assistant (SAM-BA) driver hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected USB Serial support registered for siemens_mpi usbcore: registered new interface driver siemens_mpi Driver for Siemens USB/MPI adapter Version 0.1 09/26/2005 Thomas Hergenhahn@web.de http://libnodave.sf.net USB Serial support registered for Sierra USB modem usbcore: registered new interface driver sierra sierra: v.1.7.16:USB Driver for Sierra Wireless USB modems USB Serial support registered for SPCP8x5 usbcore: registered new interface driver spcp8x5 spcp8x5: v0.10:SPCP8x5 USB to serial adaptor driver USB Serial support registered for Quatech SSU-100 USB to Serial Driver usbcore: registered new interface driver ssu100 ssu100: v0.1:Quatech SSU-100 USB to Serial Driver USB Serial support registered for symbol usbcore: registered new interface driver symbol USB Serial support registered for TI USB 3410 1 port adapter USB Serial support registered for TI USB 5052 2 port adapter usbcore: registered new interface driver ti_usb_3410_5052 ti_usb_3410_5052: v0.10:TI USB 3410/5052 Serial Driver USB Serial support registered for Handspring Visor / Palm OS USB Serial support registered for Sony Clie 3.5 USB Serial support registered for Sony Clie 5.0 usbcore: registered new interface driver visor visor: USB HandSpring Visor / Palm OS driver USB Serial support registered for Connect Tech - WhiteHEAT - (prerenumeration) USB Serial support registered for Connect Tech - WhiteHEAT usbcore: registered new interface driver whiteheat whiteheat: v2.0:USB ConnectTech WhiteHEAT driver USB Serial support registered for vivopay-serial usbcore: registered new interface driver vivopay-serial vivopay_serial: v1.0:ViVOpay USB Serial Driver USB Serial support registered for zio usbcore: registered new interface driver zio Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. s3c-hsotg s3c-hsotg: regs c8840000, irq 90 s3c-hsotg s3c-hsotg: s3c_hsotg_corereset: reset failed, GRSTCTL=80000001 s3c-hsotg s3c-hsotg: GRXFSIZ=0x00001800, GNPTXFSIZ=0x18001800 s3c-hsotg s3c-hsotg: shared fifos s3c-hsotg s3c-hsotg: cannot create debug root s3c-hsotg s3c-hsotg: DCFG=0x00200000, DCTL=0x00000002, DIEPMSK=0000000f s3c-hsotg s3c-hsotg: GAHBCFG=0x00000000, 0x44=0x00000000 s3c-hsotg s3c-hsotg: GRXFSIZ=0x00000800, GNPTXFSIZ=0x04000800 s3c-hsotg s3c-hsotg: DPTx[1] FSize=768, StAddr=0x00000f00 s3c-hsotg s3c-hsotg: DPTx[2] FSize=768, StAddr=0x00001200 s3c-hsotg s3c-hsotg: DPTx[3] FSize=768, StAddr=0x00001500 s3c-hsotg s3c-hsotg: DPTx[4] FSize=768, StAddr=0x00001800 s3c-hsotg s3c-hsotg: DPTx[5] FSize=768, StAddr=0x00001b00 s3c-hsotg s3c-hsotg: DPTx[6] FSize=768, StAddr=0x00001e00 s3c-hsotg s3c-hsotg: DPTx[7] FSize=768, StAddr=0x00002100 s3c-hsotg s3c-hsotg: DPTx[8] FSize=768, StAddr=0x00002400 s3c-hsotg s3c-hsotg: DPTx[9] FSize=768, StAddr=0x00002700 s3c-hsotg s3c-hsotg: DPTx[10] FSize=768, StAddr=0x00002a00 s3c-hsotg s3c-hsotg: DPTx[11] FSize=768, StAddr=0x00002d00 s3c-hsotg s3c-hsotg: DPTx[12] FSize=768, StAddr=0x00003000 s3c-hsotg s3c-hsotg: DPTx[13] FSize=768, StAddr=0x00003300 s3c-hsotg s3c-hsotg: DPTx[14] FSize=768, StAddr=0x00003600 s3c-hsotg s3c-hsotg: DPTx[15] FSize=768, StAddr=0x00003900 s3c-hsotg s3c-hsotg: ep0-in: EPCTL=0x00008000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep0-out: EPCTL=0x00008000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep1-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep1-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep2-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep2-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep3-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep3-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep4-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep4-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep5-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep5-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep6-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep6-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep7-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep7-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep8-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep8-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep9-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep9-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep10-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep10-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep11-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep11-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep12-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep12-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep13-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep13-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep14-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: ep14-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000 s3c-hsotg s3c-hsotg: DVBUSDIS=0x000017d7, DVBUSPULSE=000005b8 mousedev: PS/2 mouse device common for all mice S3C Touchscreen driver, (c) 2010 FriendlyARM touchscreen got loaded successfully : 12 bits touchscreen-1wire initialized backlight-1wire initialized input: TouchScreen Pipe as /devices/virtual/input/input0 ts-if initialized S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c-rtc s3c64xx-rtc: rtc disabled, re-enabling one_wire_status: 4 s3c-rtc s3c64xx-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 i2c-core: driver [tuner] using legacy suspend method i2c-core: driver [tuner] using legacy resume method i2c-core: driver [msp3400] using legacy suspend method i2c-core: driver [msp3400] using legacy resume method usbcore: registered new interface driver usbvision USBVision USB Video Device Driver for Linux : 0.9.10 one_wire_status: 5 usbcore: registered new interface driver pvrusb2 pvrusb2: V4L in-tree version:Hauppauge WinTV-P...stripped-down
