I have a Mini2440 with a custom expansion board containing a GSM engine. I've been using the GSM engine for basic GPRS communications via AT commands. I would like to take it a step further and create a "transparent" internet connection by creating a dailup connection with the GSM engine. This way the Mini is internet enabled. I'm using ptxdist and would like to accomplish the following two things: 1.) Create a dailup connection with the GSM engine through a serial port. I've made the expansion board such that it have two SIMs. If I dont get connectibity on one network I switch over to the other SIM and try the network on the second SIM. I've been doing this from my Qt app by manipulating the IO ports to control the SIM switch. 2.) But if I'm going to use the built in linux dailup connection how will I switch between these SIMs?
Dailup connection on linux
Ok, what I've done so far is set PTXCONF_PPP=y in ptxconfig and re-compiled ptxdist. I now have /dev/ppp I'm working through /Documentation/networking/ppp_generic.txt Am I on the right track?
Sounds reasonable. I was looking at controlling a USB Mobile broadband modem (Sierra Wireless Compass 850) and I got as far as enabling PPP and the next step was the use of CHAT scripts. Maybe, you have to enable those as well?? Good luck!
The "Documentation/networking/ppp_generic.txt" represents more the kernel part of the required PPP connection. But when creating connections this is the job of a user-land tool. What you need is the PPP-package with its 'chat' tool and some config files in "/etc/init.d/pppd" and "/etc/ppp/*" to describe and establish the connection. It should be possible to catch the error if the 'chat' tool fails to make a connection on one SIM and then switch to the other one and try again.
Hi Juergen, If I make changes to ptxconfig, do I need to drop both the roofs and kernel compile? Or what do I need to drop to make sure the changes made in ptxconfig takes effect?
It depends ;) PTXdist works with packages. And if you make a change _inside_ one of these packages, you must force PTXdist to recreate/rebuild this package and move the results into your root filesystem. But you must do it manually, because PTXdist cannot auto-detect it. It only can detect changes in its own config files. So, if you make changes within the 'menuconfig' settings, PTXdist will automatically rebuild the corresponding package and at the end the root filesystem as well. The fastest way to ensure all your new/changed files inside a package are part of the root filesystem is the "ptxdist clean root; ptxdist go" (note the difference between 'ptxdist clean' and 'ptxdist clean root'!). You see, there is no easy answer possible. It really depends on what you are doing.
In my console output I get the following: Starting pppd... /usr/sbin/pppd: In file /etc/ppp/options: unrecognized option 'plugin' failed Inside the /etc/ppp/options file its using the following plugin. # # Use the PPPoE plugin # plugin rp-pppoe.so Any ideas on how to resolve this?
The rp-pppoe.so file is where its supposed to be /root/usr/lib/pppd/2.4.4 but it seems like the ppp driver does not recognize plugin option??
Please try the 'ppp.make' and 'ppp.in' from the current PTXdist git in your project local rules/ directory. I just did a look into my own selfmade router and it seems I also work with the 2.4.5 revision of the ppp package (there was some trouble with the 2.4.4 revision). And in PTXdist the 2.4.5 revision was introduced in May 4.
I've enabled everything ppp related and I now get: Starting pppd... Plugin rp-pppoe.so loaded. RP-PPPoE plugin version 3.3 compiled against pppd 2.4.4 I'm not sure if this is good or bad?
ok, my chat script is working but it does not seem like ppp is dailing. When I test the chat script I get the following: root@mini2440:~ export GSM_DEVICE=/dev/ttySAC1 root@mini2440:~ chat -v -t 5 -f /etc/chatscripts/provider > $GSM_DEVICE < $GSM_D EVICE AT OK AT+CGDCONT=1,"IP","vpn.rdc.co.za" OK ATD*99# CONNECT But when I execute ppp nothing happens: root@mini2440:~ export GSM_DEVICE=/dev/ttySAC1 root@mini2440:~ pppd $GSM_DEVICE 115200 call provider Plugin rp-pppoe.so loaded. RP-PPPoE plugin version 3.3 compiled against pppd 2.4.4 root@mini2440:~ I would have expected some output informing me its connected or something. So either it is working but it does not give any output or it is not working. Is there some way (log file or something) to check if the connection was successful?
http://oreilly.com/catalog/umppp/chapter/ch06.html Syslog is a Linux system resource responsible for recording messages pertaining to application and system activities. By default, the directory /var/log maintains the message files. Syslog categorizes messages by facility name and priority. The configuration file, /etc/syslog.conf, determines where and what the syslogd process does with incoming messages. PPP-2.3 sends PPP debugging traces, conversational activity with remote systems, and other information, to Linux syslog. To view these messages, users must arrange syslogd to record them. The pppd and chat programs produce facility daemon and facility local2 messages, respectively, at various priorities. Capturing these require the following lines in /etc/syslog.conf : daemon.debug /var/log/daemon local2.debug /var/log/local2 A kill -1 to the syslogd process is necessary for /etc/syslog.conf changes to become effective. Recording PPP-2.3 syslog messages is highly recommended, particularly for troubleshooting and for monitoring PPP activity. **** 1999! Must be a newer copy somewhere.
We have a copy of: PPP design, implementation, and debugging - 2nd ed. (2000) by Carson at least it is a year newer, if you want me to have a look for some other hints.
So, now you have /var/log/daemon and /var/log/local2 running or is the above information out of date or ?
Damn, those guys on the ptxdist mailing list is a bunch of grumpy old men (Sorry Juergen). They kicked me of their mailing list. Dave, I'm working on a new compilation of the latest ptx and oselas tools but with no support and little knowledge the going is tough.
bluscape, You still didn't answer my question. I would like to know if it was a solution (I assume not) as I will have to face similar issues shortly. Dave
Hi Dave, Sorry, after our last discussion I decided to first get the latest tools and then take off from where we last stopped. Once I've compiled all the tools and have my setup working as before I will re-visit what you have posted. I will DEFINITELY still look at what you have posted. Sorry. Will get back to you asap. Cheers
No rush. The issue was that you followed my comments with a request for help. If you have any problems with setting up the new tools I am sure there will be plenty of support.
Bluscape, > Damn, those guys on the ptxdist mailing list is a bunch of grumpy old > men (Sorry Juergen). They kicked me of their mailing list. ??? I had to asked a translation program to get the german correspondent for "grumpy old men". What do you mean? What is going wrong?
bluscape, I have had a few times when postings didn't make the list. There was no indication of what went wrong. Dave
I'm busy compiling a file system using ptxdist 2012.02.0 and bsp 2012.02.0 but its stops at this error (I did manually download the archive and placed it in the src directory but it still givea this error): ---------------------- target: strace.extract ---------------------- extract: pkg_src=OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/src/strace-4.6.tar.xz extract: pkg_extract_dir=OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/platform-mini2440/buil d-target/strace-4.6 tar: xz: Cannot exec: No such file or directory tar: Error is not recoverable: exiting now tar: Child returned status 2 tar: Exiting with failure status due to previous errors error: extracting '/home/mc/local/OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/src/strace-4.6.tar.xz' failed ptxdist: error: failed to extract '/home/mc/local/OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/src/strace-4.6.tar.xz' . make: *** [/home/mc/local/OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/platform-mini2440/stat e/strace.extract] Error 1 1.) Should I rather download strace-4.6.tar.gz? 2.) Where can I edit the source list to force ptxdist to rather use the gz instead of the xz?
I've compiled my new tools but I'm having a problem booting the rootfs from the SD card. My SD card is partitioned into three parts /dev/sdd1 = boot (vfat) /dev/sdd2 = START_HERE(ext3) /dev/sdd3 = rootfs (ext3) In barebox I've set the following: # can be either 'net', 'nand', 'initrd' or 'mmc' rootfs_loc=mmc # can be either 'jffs2' or 'ubifs' for flash or 'ext3' for mmc rootfs_type=ext3 # MMC/SD boot settings # partition number to read the kernel from # (starting with # 0, Barebox's counting scheme) kernel_mmc_part=0 # rootfs's partition number # (starting with # 1, Kernel's counting scheme) rootfs_mmc_part=3 # used when manually booting with "boot mmc" command rootfs_mmc_type=ext3 but I'm getting the following error: mmc0: new SD card at address b368 mmcblk0: mmc0:b368 SD02G 1.78 GiB mmcblk0: p1 p2 p3 usb 1-1: cp210x converter now attached to ttyUSB0 VFS: Cannot open root device "mmcblk0p3" or unknown-block(179,3) Please append a correct "root=" boot option; here are the available partitions: 1f00 512 mtdblock0 (driver?) 1f01 384 mtdblock1 (driver?) 1f02 2048 mtdblock2 (driver?) 1f03 128128 mtdblock3 (driver?) b300 1872896 mmcblk0 driver: mmcblk b301 72261 mmcblk0p1 00000000-0000-0000-0000-000000000mmcblk0p1 b302 923737 mmcblk0p2 00000000-0000-0000-0000-000000000mmcblk0p2 b303 859477 mmcblk0p3 00000000-0000-0000-0000-000000000mmcblk0p3 Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3) Function entered at [<c000e4e0>] from [<c02b524c>] Function entered at [<c02b524c>] from [<c0354b8c>] Function entered at [<c0354b8c>] from [<c0354cb4>] Function entered at [<c0354cb4>] from [<c0354df4>] Function entered at [<c0354df4>] from [<c03547fc>] Function entered at [<c03547fc>] from [<c0009fa4>]
Did you dd the kernel into its partition? I guess you must have or you wouldn't have got so far. Attached are my notes for setting up the SD card to use with Pengutronix. (rename it .doc) Dave
I forgot to enable ext3 file system in the kernel config. I've selected it as a module and not built-in. Now that it is built-in it can load the file system but I get a different error: mmc0: new SD card at address b368 mmcblk0: mmc0:b368 SD02G 1.78 GiB mmcblk0: p1 p2 p3 usb 1-1: cp210x converter now attached to ttyUSB0 kjournald starting. Commit interval 5 seconds EXT3-fs (mmcblk0p3): using internal journal EXT3-fs (mmcblk0p3): recovery complete EXT3-fs (mmcblk0p3): mounted filesystem with ordered data mode VFS: Mounted root (ext3 filesystem) on device 179:3. devtmpfs: error mounting -2 Freeing init memory: 196K Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. Function entered at [<c000e4e0>] from [<c02ce88c>] Function entered at [<c02ce88c>] from [<c02ce0fc>] Function entered at [<c02ce0fc>] from [<c0373800>]
I forgot to enable ext3 file system in the kernel config. You are not the only one. I should put a note in my document. devtmpfs: error mounting -2 Try searching on the two Pengutronix gmane sites. I hear a faint bell in the background. Is devtmpfs have to be enabled in the kernel?
Yes, it seems to be. Device Drivers ---> Generic Driver Options ---> [*] Maintain a devtmpfs filesystem to mount at /dev
Found it, platform-mini2440/sysroot-target/logfile The rootfs compiled without any errors. I've had this "Kernel panic - not syncing: No init found" error before but that was before I used ptxdist. At that stage I copied the wrong rootfs into the SD card. But now I dont know what is wrong.
Mine was very large because I haven't cleaned it out in months. I don't have a logfile in platform-mini2440/sysroot-target/logfile I have one in platform-mini2440/build-target/platform which looks like a copy of the other one. However, I doubt this is going to help in your case! Just an observation: I noticed that devtmpfs is used when booting with an SD cards and tmpfs is used when booting with NFS. Good night and good luck.
Its working!. Stupido me, I wasnt sure about the kernel counting scheme for the partitions on the SD card. I thought the rootfs is at part 3. Set it to part 2 and now its booting. Awesome. Lets proceed..
After a few seconds I get the following error in the console output: JFFS2 notice: (379) check_node_data: wrong data CRC in data node at 0x02f02874: read 0x62172e1a, calculated 0xf8c060b3. JFFS2 notice: (379) check_node_data: wrong data CRC in data node at 0x02f01b9c: read 0x62172e1a, calculated 0x41370bbf.
> I thought the rootfs is at part 3. Set it to part 2 and now its booting. That is was my comment in the Barebox's config means: > # rootfs's partition number > # (starting with # 1, Kernel's counting scheme) Did you erase the NAND completely prior using it? Sometimes old data can confuse JFFS2, bus these messages will disappear after JFFS2 has cleaned up all NAND blocks. Only if your NAND is worn out, these kind of messages will continue to appear.
Juergen, Thanks, I will try and format the NAND again. I'm sure I did format it before loading my new barebox. I compiled the latest BSP with the latest matching ptx (2012.02) but just realized that ppp is still version 2.4.4. I understand ppp-2.4.5 is only available in ptx 2012.05. But I cant compile BSP 2012.02 with ptx 2012.05 so how do I get to use ppp-2.4.5 with BSP 2012.02?
But you can partially update on a per package base. Just copy the rule file (ppp.make) from the current PTXdist GIT repository into your BSP directory into "rules/". Any local rule file with the same name has a higher priority than the one from the PTXdist installation.
I copied ppp.make from home/mc/local/ptxdist-2012.05.0/rules to /home/mc/local/OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/rules then I did ./ptxdist-2012.02.0 clean ppp and then ./ptxdist-2012.02.0 go But its still using ppp-2.4.4
I looked into the ppp.make from ptx 2012.05.0 and it also uses ppp-2.4.4 I've edited the ppp.make file and changed the version to 2.4.5 and updated the the MD5 checksum to macth. Now it compiled the latest ppp. Hope this will work.
> How can I drop ppp only without having to > re-compile the entire ptx? ptxdist drop ppp or ptxdist clean ppp? For my spi driver, which is in local_src, I just have to say: ptxdist clean spi-write as a ptxdist drop spi-write says that it is not built.
Before I can continue with the ppp I first want to get everything working
like it used to but I have two problems:
1.) My boot logo does not display. I'm selecting the correct display driver
in barebox and the boot logo is enabled in the kernel. There is a
difference between the old (2.6.38) and new (3.2) kernelconfig. In the old
kernelconfig the following which is not available in the new kernelconfig:
Device Drivers --->
Graphics support --->
Console display driver support --->
This graphics driver should not have any effect on the boot logo or does
it?
2.) I'm running a startup script that bypasses the login screen. But when
the startup script is executed I get the following error:
loading modules
/home/startup: line 3: /etc/./profile.environment: Permission denied
starting pid 463, tty '/dev/console': '/sbin/getty -L 115200 ttySAC0 vt100'
mini2440 login:
I used the method from Juergen to generate the startup scripts which
basically puts a S99startup file in /etc/rc.d which in effect calls the
start script in /home
The penguin/logo at startup is only visible if you enable the framebuffer console "FRAMEBUFFER_CONSOLE=y" in the kernel config. > /etc/./profile.environment: Permission denied Seems your "/etc/profile.environment" has some curious permission flags settings.
But that is bothering me because the kernelconfig-3.2 does not have such a setting. Inside OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/configs/platform-friendlyarm-mini2440 I there are several kernel configs (kernelconfig-2.6.38, kernelconfig-2.6.39, kernelconfig-3.1, kernelconfig-3.2). Why is that? Should I just add the line CONFIG_FRAMEBUFFER_CONSOLE=y to the kernelconfig-3.2?
Yes, in the BSP this kernel feature is disabled: For a LCD less system you do not need it and for a graphical system you also do not need it. If you really need it, just enable it. The BSP is only a base to work with. You can adapt it to your needs by changing all settings. And there are more than one kernel config file, due to the fact, this BSP supports more than one kernel for the Mini2440. Or to be more precise: I keep the old kernels in the BSP when I add the new ones. This week the kernel 3.4 will be added for example.
I'm about to give up on this ppp. I'm back at the original message: In my console output I get the following: Starting pppd... /usr/sbin/pppd: In file /etc/ppp/options: unrecognized option 'plugin' failed Inside the /etc/ppp/options file its using the following plugin. # # Use the PPPoE plugin # plugin rp-pppoe.so And I dont know how to resolve this. I've tried ppp-2.4.4 and ppp-2.4.5. ppp-2.4.5 does not even have the the rp-pppoe.so plugin so I copy it from ppp-2.4.4
I got rid of the "unrecognized option 'plugin'" but only with ppp-2.4.4
When I run my chatscript I can see my GSM engine creates a GPRS connection
(In my case the LED flash fasst) but when I launch pppd with "pppd
/dev/ttySAC1 115200 call provider" I get a message:
But I can see the GSM engine does not dial a GPRS connection (In my case
the LED flash idle).
When I run strace using "strace pppd /dev/ttySAC1 115200 call provider"
I get the following
root@mini2440:~ strace pppd /dev/ttySAC1 115200 /etc/ppp/peers/provider
execve("/usr/sbin/pppd", ["pppd", "/dev/ttySAC1", "115200",
"/etc/ppp/peers/provider"], [/* 18 vars */]) = 0
brk(0) = 0x1b4000
uname({sys="Linux", node="mini2440", ...}) = 0
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or
directory)
open("/etc/ld.so.cache", O_RDONLY) = -1 ENOENT (No such file or
directory)
open("/lib/tls/v4l/libcrypt.so.1", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib/tls/v4l", 0xbec63368) = -1 ENOENT (No such file or
directory)
open("/lib/tls/libcrypt.so.1", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib/tls", 0xbec63368) = -1 ENOENT (No such file or
directory)
open("/lib/v4l/libcrypt.so.1", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib/v4l", 0xbec63368) = -1 ENOENT (No such file or
directory)
open("/lib/libcrypt.so.1", O_RDONLY) = 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0(\7\0\0004\0\0\0"..., 512) =
512
fstat64(3, {st_mode=S_IFREG|0755, st_size=34232, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) =
0x4008d000
mmap2(NULL, 225604, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0x400e6000
mprotect(0x400ee000, 28672, PROT_NONE) = 0
mmap2(0x400f5000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7) = 0x400f5000
mmap2(0x400f7000, 155972, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x400f7000
close(3) = 0
open("/lib/libdl.so.2", O_RDONLY) = 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\0\t\0\0004\0\0\0"..., 512)
= 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=9672, ...}) = 0
mmap2(NULL, 41136, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0x4002d000
mprotect(0x4002f000, 28672, PROT_NONE) = 0
mmap2(0x40036000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1) = 0x40036000
close(3) = 0
open("/lib/libpcap.so.1", O_RDONLY) = -1 ENOENT (No such file or
directory)
open("/usr/lib/tls/v4l/libpcap.so.1", O_RDONLY) = -1 ENOENT (No such file
or directory)
stat64("/usr/lib/tls/v4l", 0xbec63338) = -1 ENOENT (No such file or
directory)
open("/usr/lib/tls/libpcap.so.1", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/usr/lib/tls", 0xbec63338) = -1 ENOENT (No such file or
directory)
open("/usr/lib/v4l/libpcap.so.1", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/usr/lib/v4l", 0xbec63338) = -1 ENOENT (No such file or
directory)
open("/usr/lib/libpcap.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0HG\0\0004\0\0\0"...,
512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=198640, ...}) = 0
mmap2(NULL, 232344, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0x4011e000
mprotect(0x4014e000, 28672, PROT_NONE) = 0
mmap2(0x40155000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2f) = 0x40155000
close(3) = 0
open("/lib/libc.so.6", O_RDONLY) = 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\230X\1\0004\0\0\0"..., 512)
= 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1209460, ...}) = 0
mmap2(NULL, 1246440, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0)
= 0x40157000
mprotect(0x4027a000, 32768, PROT_NONE) = 0
mmap2(0x40282000, 12288, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x123) = 0x40282000
mmap2(0x40285000, 9448, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40285000
close(3) = 0
open("/lib/libnl.so.1", O_RDONLY) = -1 ENOENT (No such file or
directory)
open("/usr/lib/libnl.so.1", O_RDONLY) = 3
\334\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=253568, ...}) = 0
mmap2(NULL, 285256, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0x40288000
mprotect(0x402c3000, 32768, PROT_NONE) = 0
mmap2(0x402cb000, 12288, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3b) = 0x402cb000
close(3) = 0
open("/lib/libgcc_s.so.1", O_RDONLY) = 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\210'\0\0004\0\0\0"..., 512)
= 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=45192, ...}) = 0
mmap2(NULL, 76708, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0x40038000
mprotect(0x40043000, 28672, PROT_NONE) = 0
mmap2(0x4004a000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa) = 0x4004a000
close(3) = 0
open("/lib/libm.so.6", O_RDONLY) = 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\3301\0\0004\0\0\0"..., 512)
= 512
0x400c1000
fstat64(3, {st_mode=S_IFREG|0755, st_size=656872, ...}) = 0
mmap2(NULL, 688296, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) =
0x402ce000
mprotect(0x4036e000, 28672, PROT_NONE) = 0
mmap2(0x40375000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9f) = 0x40375000
close(3) = 0
0x4009f000
set_tls(0x4009f4c0, 0x4009fb98, 0x4007c048, 0x4009f4c0, 0x4007c000) = 0
mprotect(0x40375000, 4096, PROT_READ) = 0
mprotect(0x40282000, 8192, PROT_READ) = 0
mprotect(0x40036000, 4096, PROT_READ) = 0
mprotect(0x400f5000, 4096, PROT_READ) = 0
mprotect(0x4007b000, 4096, PROT_READ) = 0
brk(0) = 0x1b4000
brk(0x1d5000) = 0x1d5000
open("/proc/net/psched", O_RDONLY) = -1 ENOENT (No such file or
directory)
socket(PF_FILE, SOCK_DGRAM|SOCK_CLOEXEC, 0) = 3
connect(3, {sa_family=AF_FILE, path="/dev/log"}, 110) = -1 ENOENT (No such
file or directory)
close(3) = 0
umask(0777) = 022
umask(022) = 0777
getuid32() = 0
getgroups32(65536, [0]) = 1
gettimeofday({1426216782, 798988}, NULL) = 0
getpid() = 647
geteuid32() = 0
open("/etc/ppp/options
I have little strace experience but was told that: -1 ENOENT (No such file or directory) at least during the initial stages were safe to be ignored. Staring at the top, are those libraries really on the platform?
Got it working!!!!!! I'm not sure what it does but executing this command before pppd does the trick: route del default 2>/dev/null
Hi Dave, I'm busy typing a solution. The reason for the call to all the libraries was due to incorrect entries in the options and providers scripts. Will post the solution once I've completed writing it.
The solution: When ppp is enabled in ptxdist its creates a startup script /etc/rc.d/S09ppp. This script is responsible for launching the ppp interface. For some reason even if the ppp is selected as a module in the kernel, the S09ppp script is still executed causing the ppp to be launched but it does not really matter. I've edited my S09ppp script to look like this: $DAEMON_OPTS="call provider" and in between "echo Starting pppd..." and "$DAEMON" I've added the following line. route del default 2>/dev/null In my case for the ppp to work I need to execute this line before launching pppd. I don't use the /etc/ppp/options script and therefore commented everything inside it. I deleted the entire contents of /etc/ppp/peers/provider and re-wrote it to look like this (consult the ppp manual for more options). noauth ttySAC1 115200 defaultroute noipdefault usepeerdns connect "/usr/sbin/chat -v -s -t 5 -f /etc/chatscripts/provider" Lastly I replaced the contents of /etc/chatscripts/provider to look like this (Consult your GSM engine AT command set for additional AT commands): TIMEOUT 60 ABORT 'BUSY' ABORT 'NO CARRIER' ABORT 'ERROR' '' 'AT' 'OK' 'AT+COPS?' '+COPS: 0,0' 'AT+CSQ' 'OK' 'AT+CGDCONT=1,"IP","internet"' Because my GSM engine takes a while to register on the network I'm trying to wait for it in the chatscript until I've received the correct response but it is nit working. When the engine is not registered it will reply with +COPS: 0 when requesting network status and +COPS: 0,0,"Network operator name" when it is registered. I'm trying to wait for the +COPS: 0,0 response to indicate the engine is registered. There is a timeout value that can be used to make chat wait until the correct response is found or a timeout. When I call chat I've set this timeout to 60 (1 minute) but it does not wait. I've even tried to set the TIMEOUT in the chatscript itself but that does not work either. Maybe you can find a way to make chat wait until the correct response is found.
Good work, someone actually writing up how they sorted a problem. I'll assume that my comment about -1 ENOENT (No such file or directory) was correct. Haven't used chat. The only examples I have were found on the Sierra Wireless site for running a Compass 850 from a Linux-based system. Good luck.
