Error building root file system using PTXdist
Vishad
I am following Pengutronix Mini2440 Quickstart guide and getting following
error while building root file system. I will appreciate your guidance.
*** No rule to make target `(copy)', needed by `barebox_default_env'.
Stop.
Following is more detail about when it occurs.
target: barebox.compile
cd
/home/vishad/OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/platform-mini2440/build-t
arget/barebox-2011.05.0
PATH=/home/vishad/OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/platform-mini2440/sy
sroot-cross/bin:/home/vishad/OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/platform-
mini2440/sysroot-cross/sbin:$PATH
make HOSTCC=gcc ARCH=arm CROSS_COMPILE=arm-v4t-linux-gnueabi-
make[1]: Entering directory
`/home/vishad/OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/platform-mini2440/build-
target/barebox-2011.05.0'
make[2]: `include/generated/mach-types.h' is up to date.
  CHK     include/generated/version.h
  CHK     include/generated/utsrelease.h
  SYMLINK include/config.h -> arch/arm/boards/mini2440//config.h
make[2]: *** No rule to make target `(copy)', needed by
`barebox_default_env'.  Stop.
make[1]: *** [common] Error 2
make: ***
[/home/vishad/OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/platform-mini2440/state/
barebox.compile]
Error 2
make[1]: Leaving directory
Which toolchain?
$ tar xf OSELAS.Toolchain-2011.11.0.tar.bz2
$ cd OSELAS.Toolchain-2011.11.0
$ ptxdist select ptxconfigs/¿
arm-v4t-linux-gnueabi_gcc-4.6.2_glibc-2.14.1_binutils-2.21.1a_kernel-2.6.39-sani
tized.ptxconfig
$ ptxdist go
Or are you using an older toolchain?
Which platformconfig?
$ ptxdist platform
configs/platform-friendlyarm-mini2440/platformconfig-NAND-64M
info: selected platformconfig:
’configs/platform-friendlyarm-mini2440/platformconfig-NAND-64M’
Or are you running a non-64M machine?
The expert will be back soon, but this might help to work out what the
problem is.
Juergen Beisert
Vishad,
the quickstart also mentions a mailing list for such kind of failures. Can
you send the currently selected user land config (one of the
'configs/ptxconfig' or 'configs/ptxconfig.qt'), the selected platform
config (one of the
'configs/platform-friendlyarm-mini2440/platformconfig-NAND-[128|64]M') and
the logfile up to this point of failure ('platform-mini2440/logfile') to
this mailing list?
Vishad
Thank you for your response and help.
Issue is resolved.
I deleted BSP. Download it again and follow the step. It compilled OK.
