I need to run my mini2440 linux device 24x7. Is there any way I can save power during idle time? I cannot shutdown because it takes lot time to boot again
Power saving mode
I assume you are using a kernel that will shut the touchscreen off after a period of inactivity. That's the big power load. Have you read chapter 7 in S3C2440.pdf? There are lots of options in the kernel config to do with power management. Whether they work or on this platform I can't confirm.
