ADC pins for 2440
julie
I have enabled S3C24xx/S3C64xx Inbuilt ADC in Device Driver--> Hardware
monitoring support from the linux 2.6.32.2 kernel
But i cannot see /sys/devices/platform/s3c24xx-adc/s3c-hwmon/ on my
mini2440.
Am I doing something wrong?
Have a look in /arch/arm/mach-s3c2440/mach-mini2440.c and see if ADC is
registered.
If you are using an non-FriendlyArm 2.6.32.2 kernel then ADC support might
be built-in.
Have you got any /sys/. . . entries?
Any reason for not using a more recent kernel?
I see Pengutronix have a patch for their kernel to add hw-mon and I have
only used the ADC on their kernels.
Good luck!
S3C_ADC=y in kernelconfig?
julie
Hello ,
Can you guide me how to see if ADC is registered in
/arch/arm/mach-s3c2440/mach-mini2440.c ?
Also tell me from where should I get latest kernel for mini2440
I have downloaded this kernel from this site only.
The site has 2.6.32.2 kernel available.
julie
No entry for S3C_ADC in kernel config
Had to boot up my old Linux dev box as I haven't used 2.6.32.2 for over a
year.
No ADC stuff in mach-mini2440.c
I would suggest you head over to this site:
http://www.oselas.org/oselas/bsp/pengutronix/mini2440_bsp_en.html
and download their toolchain and BSP for the mini2440 AND read their
QuickStart guide.
This is the only kernel that is in active development for the mini2440.
Unless you are wanting to learn how to build a kernel and root filesystem
from scratch I would make use of all the work that has gone into their BSP
. . . and start developing applications!
And excellent support.
Should have read:
NOT be built-in.
julie
I tried the pengutronix bsp and followed the quickstart guide.
I am stuck at "mini2440:/ update -t barebox -d nand" (page 27 of the doc).
It seems endless. How much time does this step takes?
All the previous steps work smooth.
Juergen Beisert
This step should end in about a few seconds. What kind of Mini2440 do you
have (SDRAM size, Flash type and size)?
julie
SDRAM 64MB
NAND flash 128MB
Juergen Beisert
Hmm, should work out of the box. Can you show us the whole log of your
terminal session with all your input and Mini244's output? It would help us
to understand what is different on your system.
julie
Till the "mini2440:/ update -t barebox -d nand" step , I got the same
outputs as given in the quickstart guide.
Any other way than tftp?
