I'm using ptxdist. I've enabled the gadget hid driver and it is working great. Only problem is that the maximum packet size is 8 bytes. I would like to increase the packet size to the maximum (which is 64 bytes for hid). I've defined a custom device and report descriptor (see below) and they are working fine. I've also created two custom endpoints and I am able to communicate over them. I have two questions: 1.) To increase the packet size I still need to change the configuration descriptor but I cant find the file/location where I can change this. Which file contains the configuration descriptor for gadget hid? 2.) The labels used in the descriptors below (for example: .bLength), where are they defined? *** device descriptor (drivers/usb/gadget/hid.c): static struct usb_device_descriptor device_desc = { .bLength = sizeof device_desc, .bDescriptorType = USB_DT_DEVICE, .bcdUSB = cpu_to_le16(0x0200), .bDeviceClass = 0x00, .bDeviceSubClass = 0x00, .bDeviceProtocol = 0x00, .wMaxPacketSize = 0x40, .idVendor = cpu_to_le16(HIDG_VENDOR_NUM), .idProduct = cpu_to_le16(HIDG_PRODUCT_NUM), .bcdDevice = cpu_to_le16(0x0200), .iManufacturer = 1, .iProduct = 2, .iSerial = 3, .bNumConfigurations = 0x01 }; *** report descriptor (arch/arm/mach-s3c2440/mach-mini2440.c): static struct hidg_func_descriptor my_hid_data = { .subclass = 0, .protocol = 1, .report_length = 8, .report_desc_length = 37, .report_desc = { 0x05, 0x8C, 0x09, 0x01, 0xa1, 0x01, 0x85, IN_DATA, 0x95, IN_DATA_SIZE, 0x75, 0x08, 0x26, 0xff, 0x00, 0x15, 0x00, 0x09, 0x01, 0x81, 0x02, 0x85, OUT_DATA, 0x95, OUT_DATA_SIZE, 0x75, 0x08, 0x26, 0xff, 0x00, 0x15, 0x00, 0x09, 0x01, 0x91, 0x02, 0xC0 } };
ptxdist gadget hid change packet size
My descriptors are fine. The only thing I still needed to do was to set the report_length in the my_hid_data descriptor to 64. Now I'm able to transfer 64 bytes over HID!!
