Cross compiling PJSIP for ARM 6410
Eng Halim
hi , all
i`m trying to cross compile pjsip for my kit running embedded linux
when i try with the following commands
i only use the kit cross compiler
./configure --host=arm-linux
make dep
make
at make step some error appears to me
arm-linux-ar: creating ../lib/libpjlib-util-arm-unknown-linux-gnu.a
a - output/pjlib-util-arm-unknown-linux-gnu/base64.o
a - output/pjlib-util-arm-unknown-linux-gnu/crc32.o
a - output/pjlib-util-arm-unknown-linux-gnu/errno.o
a - output/pjlib-util-arm-unknown-linux-gnu/dns.o
a - output/pjlib-util-arm-unknown-linux-gnu/dns_dump.o
a - output/pjlib-util-arm-unknown-linux-gnu/dns_server.o
a - output/pjlib-util-arm-unknown-linux-gnu/getopt.o
a - output/pjlib-util-arm-unknown-linux-gnu/hmac_md5.o
a - output/pjlib-util-arm-unknown-linux-gnu/hmac_sha1.o
a - output/pjlib-util-arm-unknown-linux-gnu/http_client.o
a - output/pjlib-util-arm-unknown-linux-gnu/md5.o
a - output/pjlib-util-arm-unknown-linux-gnu/pcap.o
a - output/pjlib-util-arm-unknown-linux-gnu/resolver.o
a - output/pjlib-util-arm-unknown-linux-gnu/scanner.o
a - output/pjlib-util-arm-unknown-linux-gnu/sha1.o
a - output/pjlib-util-arm-unknown-linux-gnu/srv_resolver.o
a - output/pjlib-util-arm-unknown-linux-gnu/string.o
a - output/pjlib-util-arm-unknown-linux-gnu/stun_simple.o
a - output/pjlib-util-arm-unknown-linux-gnu/stun_simple_client.o
a - output/pjlib-util-arm-unknown-linux-gnu/xml.o
arm-linux-ranlib ../lib/libpjlib-util-arm-unknown-linux-gnu.a
make[2]: Leaving directory
`/home/trojan/Desktop/pjproject-2.0-rc/pjlib-util/build'
make[1]: Leaving directory
make: *** [all] Error 1
so any one can help me :)
Jaymin D
Its seems to be error with your toolchain which appears here incorrect or
not valid.
For that you should pass the correct toolchain name "--host=your toolchain
name without gcc" to ./configure
i.e "./configure --host=arm-linux-gnueabihf [other flags,libs and features
if you want to add]"
Here in this case my toolchain is arm-linux-gnueabihf.
This will help you.
If still have a problem then provide toolchain name and complete error
logs.
Regards
Jaymin D
