I have a long time problem.System speed is very slow. I checked with the "free -m" and saw this: root@mini6410:~# free -m total used free shared buffers cached Mem: 70 67 2 0 8 37 -/+ buffers/cache: 21 48 Swap: 0 0 0 total memory is 70 with real memory is 128.
Memory loss at mini6410
at start time i see this: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Kernel command line: console=ttySAC0,115200 rootfstype=ext3 root=/dev/mmcblk0 PID hash table entries: 512 (order: 9, 2048 bytes) Console: colour dummy device 80x30 s3c24xx_serial_init_ports: initialising ports=4... console [ttySAC0] enabled Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory: 128MB = 128MB total Memory: 70428KB available (3436K code, 460K data, 1144K init) Calibrating delay loop... 530.84 BogoMIPS (lpj=1327104) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok total memory is 128 but memory available is 70428KB You know why?!!!
Can you provide us a link to the kernel sources you are using? Please be aware most of the time our magic glass bead does not work. :)
"Please be aware most of the time our magic glass bead does not work." What? pardon me? I don't understand meaning of your comment!! how ever i resoled problem.problem was in the kernel.
