I'm trying to enumerate my Mini as a HID USB device. In the kernel I've enabled all possible HID related drivers: Device Drivers->HID Devices->/dev/hidraw Device Drivers->HID Devices->full HID support Device Drivers->HID Devices->/dev/hiddev Device Drivers->USB Support->/dev/hidraw->USB Gadget Support->USB Gadget Driver->HID Gadget But there is NO HID files in my /dev folder. I'm looking to read() and write() /dev/hidgX but it does not exist. What should I do? I'm using the hid_gadget_test example to start with but my HID interface is not available.
Mini2440 USB gadget_hid
You need CONFIG_USB_GADGET, CONFIG_USB_S3C2410, CONFIG_USB_G_HID. I run my Mini2440 as a serial and printer gadget and it works without any problem.
Ok, I now understand which files to edit but still have a few questions: 1.) Do I edit Kconfig in build-target? 2.) What do I need to edit. Do you have an example please?
A link for future reference: https://www.ridgerun.com/developer/wiki/index.php/How_to_configure_DM365... I don't if this will solve my problem but it has good info.
I only saw this now. All the time assumed the kernel compilation was fine. make[1]: Entering directory `/home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440-2011.05.0/platform-mini2440/bu ild-target/linux-2.6.38' CHK include/linux/version.h CHK include/generated/utsrelease.h make[2]: `include/generated/mach-types.h' is up to date. CALL scripts/checksyscalls.sh CHK include/generated/compile.h CC drivers/usb/musb/musb_core.o In file included from drivers/usb/musb/musb_core.c:102:0: drivers/usb/musb/musb_core.h:103:2: error: #error bogus Kconfig output ... select CONFIG_USB_GADGET_MUSB_HDRC make[3]: *** [drivers/usb/musb/musb_core.o] Error 1 make[2]: *** [drivers/usb/musb] Error 2 make[1]: *** [drivers] Error 2 make[1]: *** Waiting for unfinished jobs.... make[1]: Leaving directory `/home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440-2011.05.0/platform-mini2440/bu ild-target/linux-2.6.38' make: *** [/home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440-2011.05.0/platform-mini2440/st ate/kernel.compile] Error 2
Just run "make menuconfig" in the kernel source tree and hit the enter '/' key and then enter the symbol names without the leading CONFIG_. Kconfig will then show you, where in the menu these symbols can be changed. Change to this menu and enable them. Do it for all symbols I listed in my answer. Then re-build your kernel
I go to: /home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440-2011.05.0/platform-mini2440/bui ld-target/linux-2.6.38 type "make menuconfig" and then hit enter but I only get the kernel config menu?
Sorry, my fault. "make menuconfig" only work with the plain kernel. But you are using PTXdist. In this case just run "ptxdist kernelconfig" in the project directory and PTXdist will present you the kernel's configuration.
Then I'm back to the original problem. In the kernel I've enabled all possible HID related drivers: Device Drivers->HID Devices->/dev/hidraw Device Drivers->HID Devices->full HID support Device Drivers->HID Devices->/dev/hiddev Device Drivers->USB Support->/dev/hidraw->USB Gadget Support->USB Gadget Driver->HID Gadget But there is NO HID files in my /dev folder. I'm looking to read() and write() /dev/hidgX but it does not exist. What should I do?
You mostly enabled host side HID drivers. But you need the device (e.g. gadget) side. Once again: Did you enable CONFIG_USB_GADGET, CONFIG_USB_S3C2410, CONFIG_USB_G_HID in your kernel? BTW: OSELAS.BSP-Pengutronix-Mini2440-2011.05.0 and linux-2.6.38 is very old ;) 2012.02.0 with kernel 3.2.7 is available since february. And in the git repository you can find kernel 3.3.3.
It seems like I should enable the Inventra High Speed Dual Role Controller USB Support->Inventra High Speed Dual Role Controller->Driver Mode->Both host and peripheral but whenever I enable this driver I get the following error: #error bogus Kconfig output ... select CONFIG_USB_GADGET_MUSB_HDRC
Hi Juergen, In the mini2440 defconfig file I have the following: CONFIG_USB_GADGET=y CONFIG_USB_GADGET_S3C2410=y I do not have an option for CONFIG_USB_S3C2410 and CONFIG_USB_G_HID. I'm going to try and use/install the latest BSP but can you refresh my memory please: 1.) Can I install two different distributions on the same PC? 2.) How do I switch between them? Thank you
Ok, my g_serial is working fine so the g_hid must work too! After TONS of reading and searching I found that I must first register the device from code using "platform_device_register", only then I will be able to probe g_hid. But problems still remain. To use "platform_device_register" I need to include: #include <linux/platform_device.h> #include <linux/usb/g_hid.h> But my compiler gives me an error: fatal error: linux/usb/platform_device.h: No such file or directory fatal error: linux/usb/g_hid.h: No such file or directory These files exist but it seems like they are not available in the user space. What should I do to get access to these files?
No, these header files are reserved for the kernel. Why do you need 'platform_device.h' in user-land????? Register your devices in the platform (e.g. 'arch/arm/mach-s3c2440/mach-mini2440.c').
> 1.) Can I install two different distributions on the same PC? Yes. All PTXdist revisions can live side by side And as PTXdist is project centric, also the projects can live side by side > 2.) How do I switch between them? Create in each project a symbolic link to the correct ptxdist executable. I'm always naming it 'p'. So, I can switch between the project directories and when I'm using 'p' instead of "ptxdist" command I'm always using the matching PTXdist version.
Awesome! That makes sense to register the device in mach-mini2440.c! What do you mean by "link to the correct ptxdist executable"? Which executable? Do you have a link example please. I feel so stupid when I work with linux because it is SO different to what I'm used to!!! (To comfort me I always go and read the first page on your mini2440 quick start guide "Don't Panic")
> What do you mean by "link to the correct ptxdist executable"? my_1st_ptxdist_project$ ln -s /usr/local/bin/ptxdist-2012.04.0 p my_1st_ptxdist_project$ ./p menuconfig my_2nd_ptxdist_project$ ln -s /usr/local/bin/ptxdist-2011.11.0 p my_2nd_ptxdist_project$ ./p menuconfig With this trick you always get the correct PTXdist revision for your project. As I'm working with many projects and PTXdist revisions at the same time you can imagine it can safe life.
