problem touchscreen tiny6410
manh
hi ,all
i want config tslib for tiny6410
follow :
export TSLIB_TSEVENTTYPE=INPUT
export TSLIB_ROOT=/opt/tslib
export TSLIB_TSDEVICE=/dev/input/event0
export LD_LIBRARY_PATH=$TSLIB_ROOT/lib:$LD_LIBRARY_PATH
export TSLIB_FBDEVICE=/dev/fb0
export TSLIB_PLUGINDIR=$TSLIB_ROOT/lib/ts
export TSLIB_CONSOLEDEVICE=none
export TSLIB_CONFFILE=$TSLIB_ROOT/etc/ts.conf
export POINTERCAL_FILE=/etc/pointercal
export QWS_MOUSE_PROTO=TSLIB:/dev/input/event0
when i run ./ts_test in /opt/tslib/bin
it display" selected device is not a touchscreen I understand"
when i call command "cat /dev/input/event0"
i do not see data display lcd of tiny6410
i is diffirent compare mini2440
please help me
thank
Legath
you must use export TSLIB_TSDEVICE=/dev/touchscreen-1wire on mini6410
holger
On my Mini6410 the touchscreen outside qtopia worked with the following in
/etc/init.d/rcS for a standalone qt-app:
QWS_MOUSE_PROTO=TSLIB:/dev/input/ts-if
TSLIB_CONFFILE=/etc/ts.conf
TSLIB_PLUGINDIR=/usr/lib/ts
m44miri
I have a question.
Can you tell me about calibration touch screen in the debian for mini6410?
manh
thank for help me
i try to config as above
but when i run  ./helloqt -qws
display of tiny6410 has show but i couldn't touch to control
you can show me how to do.
thank again one time
Legath
manh,have your qt builded with ts_lib support?
-qt-mouse-tslib option.
do you make ts_calibrate before run?
m44miri
when i running ts_calibration i see this message.can not open ts_open
holger
@manh: Did you run the ./helloqt -qws in the Qtopia? I tried the same and
get the behavior seen in this video:
http://www.youtube.com/watch?v=pDsquszYev0&context=C44ffd4cADvjVQa1P...
(see thread: http://www.friendlyarm.net/forum/topic/4064)
But without Qtopia, the same app work as standalone application. To do
this, you must comment or delete the entry to start qtopia in
/etc/init.d/rcS and run your app instead. Example:
/path/to/app/myApp -qws &
That works for me perfect. I don't want a desktop environment or something.
If you need the qtopia, I think you must compile your app with the same
libs as qtopia on the mini is compiled. So I think the best way is in that
case, that you recompile qtopia (it's very outdate) or qt-extended for the
Mini to run your application in this environment.
Hope this helps a little? :-)
@m44miri: Is "can not open ts_open" the exact error message? Nothing else?
manh
thank!
1. i setup arm-linux-gcc
2 .i follow to hanlde :
dowload Qt_SDK_Lin32_offline_v1_2_en.run on web nokia.con run
"./Qt_SDK_Lin32_offline_v1_2_en.run" after that i have qt creator
3 .complite tslib :touch library
$mkdir tslib
$cd tslib
$apt-get source tslib
$cd tslib-11.0
$./configure --prefix=opt/tslib --host=arm-none-linux-gnueabi
$gedit config.h to edit #define malloc rpl_malloc->//#define malloc
rpl_malloc
$su
$password
#make
#make install
4. setup qt everywhere
dow:qt-everywhere-opensource-src-4.8.1.tar.gz
$tar -vxf qt-everywhere-opensource-src-4.8.1.tar.gz
$cd qt-everywhere-opensource-src-4.8.1/mkspecs/qws/linux-arm-g++
$vi qmake.conf
# qmake configuration for building with arm-linux-g++ #
include(../../common/g++.conf)
include(../../common/linux.conf)
include(../../common/qws.conf)
# modifications to g++.conf
QMAKE_CC  = /opt/toolschain/4.4.3/bin/arm-none-linux-gnueabi-gcc
QMAKE_CXX  = /opt/toolschain/4.4.3/bin/arm-none-linux-gnueabi-g++
QMAKE_LINK  = /opt/toolschain/4.4.3/bin/arm-none-linux-gnueabi-g++
QMAKE_LINK_SHLIB = /opt/toolschain/4.4.3/bin/arm-none-linux-gnueabi-g++
# modifications to qmake.conf
QMAKE_AR  = /opt/toolschain/4.4.3/bin/arm-none-linux-gnueabi-ar cqs
QMAKE_OBJCOPY  = /opt/toolschain/4.4.3/bin/arm-none-linux-gnueabi-objcopy
QMAKE_STRIP  = /opt/toolschain/4.4.3/bin/arm-none-linux-gnueabi-strip
QMAKE_INCDIR  += /opt/tslib/include
QMAKE_LIBDIR  += /opt/tslib/lib
load(qt_config)
$cd /qt-everywhere-opensource-src-4.8.1
$ ./configure -embedded arm -xplatform qws/linux-arm-g++ -prefix /opt/qte
-qt-mouse-tslib -little-endian -no-webkit -no-qt3support -no-cups
-no-largefile -optimized-qmake -no-openssl -nomake tools -qt-sql-sqlite
-nomake demos -nomake examples -no-multimedia -no-javascript-jit
$su
$password
#make
#make install
5 .copy 3 file :
libQtCore.so.4
libQtGui.so.4
libQtNetword.so.4
from opt/qte/tslib
to kit tiny6410 in folder :/opt/qte/lib
the same time copy fonts from pc :opt/qte/tslib to  kit tiny6410
/opt/qte/lib
copy tslib from pc /opt/tslib to kit tiny 6410  :/opt
this do on kit:
to prevent competitive betwin qtopia and myapp
#vi /etc/init.d/rcS  edit /bin/qtopia -> #/bin/qtopia
#vi /opt/tslib/etc/ts.conf edit:# module_raw input->module_raw input
add envriment variable
# vi /etc/profile to add line:
save
-dowload one-wire-ts-input-src-20111026.tar.gz from web
:ftp://friendlyarm.net/src/
from pc :
$tar -vxf one-wire-ts-input-src-20111026.tar.gz
$ cd one-wire-ts-input-src-20111026
$make
after that copy one-wire-ts-input.so to kit tiny6410 on folder :/usr/lib/ts
#vi /etc/ts.conf edit first line: module_raw one-wire-ts-input
#save and reboot
#cd /opt/tslib/bin
#./ts_test
nothing error
has display on lcd of tiny6410 but i don't touch to control it .
how can I made it working?
manh
holger
i see you behavior that
has competitive between qtopia and your app
so that you can change
what kit do you do ?tiny 6410 or other
can you share me how do i do to touchscreen working
cheer!
manh
i config as above this is result:
http://www.youtube.com/watch?v=rz57KcXKTRA
this is helloqt i push to kit tiny6410
http://www.mediafire.com/?1vw7v1joqg218ek
touchscreen do not working ?
what problem when i config ?
thank for your help
holger
I run a Mini6410 and my qt-app is working:-)
I never used the one-wire-ts-input-src-20111026.tar.gz or other.
My /etc/ts.conf is:
module_raw friendlyarm-ts-input
module pthres pmin=1
module variance delta=30
module dejitter delta=10000
module linear
And the exorts in my /etc/init.d/rcS are described above in this thread.
Have you tried the
I also have the following in this file but not shure if the nessesary (your
app is working, so the libs are found):
LD_LIBRARY_PATH=/usr/local/Trolltech/QtEmbedded-4.8.1-arm/lib:/usr/local/lib:
QPEDIR=/usr/local/Trolltech/QtEmbedded-4.8.1-arm
QTDIR=/usr/local/Trolltech/QtEmbedded-4.8.1-arm
I think you should test with the QWS_MOUSE_PROTO=TSLIB:/dev/input/ts-if
or play with all combinations of QWS_MOUSE_PROTO, TSLIB_TSDEVICE and check
all filenames and pathes if the really correct. On my mini no path was like
in the howtows:-)
(certainly, I have all variables exported:-) :
export PATH runlevel prevlevel LD_LIBRARY_PATH QPEDIR QTDIR QWS_MOUSE_PROTO
TSLIB_CALIBFILE TSLIB_CONFFILE TSLIB_FBDEVICE TSLIB_PLUGINDIR
TSLIB_TSDEVICE TSLIB_TSEVENTTYPE
You don't need to restart your mini each time you changed an export. You
can do this at the serial console and start your app with ./helloqt -qws >
/dev/tty1
If is not working ctrl-c ends the app, or if is in background kill <pid>.
This safes lots of time:-)
manh
holger!
final i i did it
thank you very much !
m44miri
Can you get me a link for complete  training for touch screen calibration
in the Debian squeeze ?
i have need for this.
manh
i do as above, but i change something. you do follow me as above. if you
dont do this you can ask me , if i know i will aswer you. cheer
phuc
Dear holger and manh ! i do as above, but my touch screen still not
working. please help me. i don't know where wrong
fatih
dear phuc, i have same problem you. Did you solved your problem?
if you solved, give me your solve.
i tried /dev/touchscreen-1wire, /dev/touchscreen, /dev/input/event0,
/dev/input/event1, /dev/input/ts-if for qws_mouse_proto but it doesn't
work.
i tried cat command, then it works only /dev/touchscreen-1wire with
settings. But standalone apps doesn't work the settings.
qiangmingliu
cat ts.conf
#module_raw  friendlyarm-ts-input
# Uncomment if you wish to use the linux input layer event interface
# Uncomment if you're using a Sharp Zaurus SL-5500/SL-5000d
# module_raw collie
# Uncomment if you're using a Sharp Zaurus SL-C700/C750/C760/C860
# module_raw corgi
# Uncomment if you're using a device with a UCB1200/1300/1400 TS interface
# module_raw ucb1x00
# Uncomment if you're using an HP iPaq h3600 or similar
# module_raw h3600
# Uncomment if you're using a Hitachi Webpad
# module_raw mk712
# Uncomment if you're using an IBM Arctic II
# module_raw arctic2
module linear
./ts_calibrate
Couldnt load module one-wire-ts-input
No raw modules loaded.
while use friendly_ts_input not show coursr
