Tiny210 Create the SD boot card to make Linux to burn to NAND Flash. Please help me for the following questions: 1) If I burn Linux to NAND Flash, then Tiny210 Android System installed in the factory will be overwritten. Is it correct for my understanding? 2) Are there some methods to make Linux only to burn to Tiny210 SD Card, not to touch the Tiny210 Android System installed in the factory? In this way, I may start the Android System from Tiny210 NAND Flash or I may start the Linux System from Tiny210 SD Card. Thank you very much for your support!
Tiny210 Systen Burn
1. yes 2. check manual.. I dont have tiny210 but if it uses Sd card u can boot the board with sd card just as my 6410 board do. (SO, Data in NAND do not change) If the board uses Nor and NAND and does not use sd card for booting, you need to investigate more. Check your computer. my labtop support sd card so I can put data into my card from my computer and insert it into my board to boot.(WIthout help of nand) kyle
Can i have one more question in this topic? Do you help me,please? If i want to burn my linux image into the nand flash directly without the card sd, how to do it? Thank you very much.
Hi Wiener I have a X210 Evaluation board, but I can't burn any OS on it! Could you please give me some links about burning WinCE and Linux on X210. Thanks
