hi. Im following this instruction http://www.sasabremec.com/wordpress/arm11-my-friendlyarm/friendlyarm-whe... so, im now make kernel but it makes an error # make zImage The log is: ~/tiny6410/Android/linux-2.6.36-android$ make zImage make: arm-linux-gcc: Command not found CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s /bin/sh: arm-linux-gcc: command not found make[1]: *** [kernel/bounds.s] Error 127 make: *** [prepare0] Error 2 any ideas why i having this error? I tried lots of ways to add arm-linux-gcc but they still recognize this. im using ubuntu 11.10 and tiny6410 board. all resources are copied from the CD
kernel compile error Error 127
Did this work for you:
Check the tool-chain path to see if it is set up correctly or not,
whether it show gcc version 4.5.1
# arm-linux-gcc v
yep, I alreaady did that. And it does not work... I know it must show version but it does not recognize this. I also typed arm- and tab twice, and it does not show arm-linux-gcc. So, they dont recognize stuffs in bin file.
At the command line try: export PATH=/path/to/your/cross-compiler/bin:$PATH and then followed immediately by: # arm-linux-gcc v Actually, when you try to manually find the path to your cross-compiler you will find it is not installed or your bashrc thing didn't work.
sandeep_r@ubuntu:~/linux-2.6.38$ make make: arm-linux-gcc: Command not found CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s /bin/sh: arm-linux-gcc: not found make[1]: *** [kernel/bounds.s] Error 127 make: *** [prepare0] Error 2 I am getting the above error when i try to compile kernel for arm-linux Tiny6410 in ubuntu. I did set the path asbelow sandeep_r@ubuntu:~/linux-2.6.38$ echo $PATH /opt/FriendlyARM/toolschain/4.5.1/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/ usr/bin:/sbin:/bin:/usr/games: checking the version- give below error(no such file or directory) sandeep_r@ubuntu:~/linux-2.6.38$ arm-linux-gcc -v -bash: /usr/bin/arm-linux-gcc: No such file or directory my tool chain is at path "/opt/FriendlyARM/toolschain/4.5.1/bin", I set it up but still it gives me same when I try make. Please could anyone tell me why was the error. Thanks in advance.. Sandeep
Have a look in "/opt/FriendlyARM/toolschain/4.5.1/bin" and see if there really is a "arm-linux-gcc" or a link to one. It might be could something else.
Hi davef, Thanks for the reply. All the arm linux binaries are available in tool chain path only. Have got fix for the problem. This was not recognising the arm binaries due to 64bit compatibility(OS) and our tool chain correspondes to 32 bit binaries. Have installed the library "ia32.libs" for this and able to compile successfully.
Hi davef/Sandeep,
I am also facing same problem.. Please help me..
ia32.libs is already installed in my ubuntu 11.04..
I want to compile kernel 2.6.xx to powerpc405..'
Please help me.
Thanks in advance..
Arun
Hi all I am cross-compiling Linux kernel 3.6 for panda board.I am facing same problem.I am not getting a proper path to debug and solve this error. Thanks in advance.
Hi davef , i am trying to install the android for mini2440 i am getting the follwing error rnd@rnd-VirtualBox:~/usr/local/android/kernel$ make zImage make: arm-linux-gcc: Command not found CHK include/linux/version.h make[1]: `include/asm-arm/mach-types.h' is up to date. CHK include/linux/utsrelease.h CC kernel/bounds.s /bin/sh: arm-linux-gcc: not found make[1]: *** [kernel/bounds.s] Error 127 make: *** [prepare0] Error 2 rnd@rnd-VirtualBox:~/usr/local/android/kernel$ and i have already tried the export PATH=/path/to/your/cross-compiler/bin:$PATH i am using Ubuntu 11.10 please help me.........
Where are you putting export PATH ? Either in a compile script or in EACH terminal session you open. Which cross-compiler are you using? After you have exported the path have you checked that it works, ie: arm-linux-gcc -v (or the "name of the cross-compiler you are using" -v)
hi davef, The following errors i got after trying those two commands rnd@rnd-VirtualBox:~/usr/local/android/kernel$ arm-linux-gcc arm-none-linux-gnueabi-gcc arm-linux-gcc: command not found rnd@rnd-VirtualBox:~/usr/local/android/kernel$ arm-linux-gcc v arm-linux-gcc: command not found rnd@rnd-VirtualBox:~/usr/local/android/kernel$
The -v is missing on the first one. Which cross-compiler do you have on the host machine and where is it located?
If you are entering those commands from a terminal session you have to do: export PATH=/path/to/your/cross-compiler/bin:$PATH before you make the command to see which version you have.
jack, did you read the whole thread? Did you really read the whole thread? I guess the solution you need you can find in one of the upper mails. Hint: do you run a 64 bit system?
Hi, I am keeping it in home/rnd/opt/FriendlyARM/toolschain/4.5.1/bin root@rnd-VirtualBox:/home/rnd/opt/FriendlyARM/toolschain/4.5.1/bin# export PATH=/opt/FriendlyARM/toolschain/4.5.1/bin:$PATH root@rnd-VirtualBox:/home/rnd/opt/FriendlyARM/toolschain/4.5.1/bin# arm-linux-gcc v arm-linux-gcc: command not found root@rnd-VirtualBox:/home/rnd/opt/FriendlyARM/toolschain/4.5.1/bin# i am using 32 bit system only
For me it looks like a PEBCAK:
Enter the directory where the 'arm-linux-gcc' binary is stored to and run
./arm-linux-gcc -v
If you want to know if all dependencies of the 'arm-linux-gcc' binary are
met, run "ldd arm-linux-gcc"
> Which cross-compiler do you have on the host machine Shows us what is in: ..../opt/FriendlyARM/toolschain/4.5.1/bin
bash: export: `/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbi n:/bin:/usr/games:/usr/local/arm/4.3.2/bin': not a valid identifier rnd@rnd-VirtualBox:~$ ls bash: ls: No such file or directory rnd@rnd-VirtualBox:~$ ls after export i am getting like this and its not showing any directory list how can i remove that first two line by default these two line is showing whenever i opened the terminal
Well, it says you have a path to 4.3.2/bin, but no path to the cross-compiler you want. Sorry, don't know anything about VirtualBox
root@coinel-PC:/opt/linux-cortexm-1.4.1/projects/lcdtest# make
cp -f /opt/linux-cortexm-1.4.1/linux/initramfs-list-min.stub \
rm -f /opt/linux-cortexm-1.4.1/linux/usr/initramfs_data.cpio \
/opt/linux-cortexm-1.4.1/linux/usr/initramfs_data.cpio.gz
cp -f lcdtest.kernel.LPC /opt/linux-cortexm-1.4.1/linux/.config
make -C /opt/linux-cortexm-1.4.1/linux vmlinux
make[1]: arm-none-eabi-gcc: Command not found
make[1]: Entering directory `/opt/linux-cortexm-1.4.1/linux'
scripts/kconfig/conf -s arch/arm/Kconfig
make[1]: Leaving directory `/opt/linux-cortexm-1.4.1/linux'
make[2]: `include/generated/mach-types.h' is up to date.
CC kernel/bounds.s
/bin/sh: 1: arm-none-eabi-gcc: not found
make[2]: *** [kernel/bounds.s] Error 127
make[1]: *** [prepare0] Error 2
make: *** [_prepare_modules] Error 2
Can any one help me on this error make[1]: arm-none-eabi-gcc: Command not found /bin/sh: 1: arm-none-eabi-gcc: not found
make zImage scripts/kconfig/conf -s arch/arm/Kconfig CHK include/linux/version.h make[1]: `include/asm-arm/mach-types.h' is up to date. CHK include/linux/utsrelease.h SYMLINK include/asm -> include/asm-arm CALL scripts/checksyscalls.sh HOSTCC scripts/mod/file2alias.o HOSTCC scripts/mod/modpost.o scripts/mod/modpost.c: In function ignore_undef_symbol: scripts/mod/modpost.c:487:6: error: MODULE_SYMBOL_PREFIX undeclared (first use in this function) scripts/mod/modpost.c:487:6: note: each undeclared identifier is reported only once for each function it appears in scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: warning: left-hand operand of comma expression has no effect [-Wunused-value] scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: warning: left-hand operand of comma expression has no effect [-Wunused-value] scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c:487:6: error: expected ) before string constant scripts/mod/modpost.c: In function handle_modversions: scripts/mod/modpost.c:518:23: error: MODULE_SYMBOL_PREFIX undeclared (first use in this function) scripts/mod/modpost.c:518:23: error: expected ) before string constant scripts/mod/modpost.c:518:23: error: too few arguments to function memcmp scripts/mod/modpost.c:520:36: error: expected ) before string constant scripts/mod/modpost.c:562:23: error: expected ) before string constant scripts/mod/modpost.c:562:23: error: too few arguments to function memcmp scripts/mod/modpost.c:563:38: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: warning: left-hand operand of comma expression has no effect [-Wunused-value] scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: warning: left-hand operand of comma expression has no effect [-Wunused-value] scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:566:7: error: expected ) before string constant scripts/mod/modpost.c:568:7: error: expected ) before string constant scripts/mod/modpost.c:568:7: error: expected ) before string constant scripts/mod/modpost.c:568:7: error: expected ) before string constant scripts/mod/modpost.c:568:7: error: expected ) before string constant scripts/mod/modpost.c:568:7: warning: left-hand operand of comma expression has no effect [-Wunused-value] scripts/mod/modpost.c:568:7: error: expected ) before string con
MODULE_SYMBOL_PREFIX undeclared Always tackle the first error message. Suggests to me that a file that declares this value has not been included. I would look in modpost.c and see which .h files are suppose to be included and then ensure they are accessible to your compiler.
I am getting the same error while cross-compiling a kernel object. Toolchain is where it has been specified using export. No problem there. Linux ubuntu 32 bit system yogesh@Yogesh-desktop:~/practice/trial$ sudo make all make ARCH=arm CROSS_COMPILE=arm-cortexa8-linux-gnueabihf- -C /home/yogesh/WEGA/linux-3.2 M=/home/yogesh/practice/trial modules make[1]: arm-cortexa8-linux-gnueabihf-gcc: Command not found make[1]: Entering directory `/home/yogesh/WEGA/linux-3.2' CC [M] /home/yogesh/practice/trial/trial.o /bin/sh: 1: arm-cortexa8-linux-gnueabihf-gcc: not found make[2]: *** [/home/yogesh/practice/trial/trial.o] Error 127 make[1]: *** [_module_/home/yogesh/practice/trial] Error 2 make[1]: Leaving directory `/home/yogesh/WEGA/linux-3.2' make: *** [all] Error 2 yogesh@Yogesh-desktop:~/practice/trial$ Thanks in advance.
make[1]: arm-cortexa8-linux-gnueabihf-gcc: Command not found I suggest you find a solution to the first error message
Hey Guys! Let's put some order here! For starters: If you are at 32 bits Linux and getting this arm-linux-gcc command not found, issue the following command: sudo apt-get install gcc-arm-linux-gnueabi libstdc++6 libncurses5 libncurses5-dev That should do the job. If you are at 64 bits Linux, you should take one of two ways: 1. You are at Ubuntu version 12.04 or lower # issue first the command above, then execute this one: sudo apt-get install is32-bits 2. You have Ubuntu version 14.04 or later # forget about above commands... just issue this: sudo apt-get install gcc-arm-linux-gnueabi lib32ncurses5 lib32stdc++6 lib32z1 lib32bz2-1.0 I think that's it! Renato
ERRATA! it's ia32-libs! # issue first the command above, then execute this one: sudo apt-get install ia32-libs
OS is ubuntu13.10 , 32bit , AMD E-450 APU with Radeon(tm) HD Graphics Χ 2 mark@mark-Presario-CQ43-Notebook-PC:~/fA_new/mini2440/linux-2.6.32.2$ arm-linux-gcc -v Using built-in specs. Target: arm-none-linux-gnueabi Configured with: /opt/FriendlyARM/mini2440/build-toolschain/working/src/gcc-4.4.3/configure --build=i386-build_redhat-linux-gnu --host=i386-build_redhat-linux-gnu --target=arm-none-linux-gnueabi --prefix=/opt/FriendlyARM/toolschain/4.4.3 --with-sysroot=/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi//sys-roo t --enable-languages=c,c++ --disable-multilib --with-arch=armv4t --with-cpu=arm920t --with-tune=arm920t --with-float=soft --with-pkgversion=ctng-1.6.1 --disable-sjlj-exceptions --enable-__cxa_atexit --with-gmp=/opt/FriendlyARM/toolschain/4.4.3 --with-mpfr=/opt/FriendlyARM/toolschain/4.4.3 --with-ppl=/opt/FriendlyARM/toolschain/4.4.3 --with-cloog=/opt/FriendlyARM/toolschain/4.4.3 --with-mpc=/opt/FriendlyARM/toolschain/4.4.3 --with-local-prefix=/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi//sy s-root --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-c99 --enable-long-long --enable-target-optspace Thread model: posix gcc version 4.4.3 (ctng-1.6.1) mark@mark-Presario-CQ43-Notebook-PC:~/fA_new/mini2440/linux-2.6.32.2$ mark@mark-Presario-CQ43-Notebook-PC:~/fA_new/mini2440/linux-2.6.32.2$ echo $PATH /usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin :/bin:/usr/games:/usr/local/games:/opt/FriendlyARM/toolschain/4.4.3/bin //---------------------------------------------------------------- I did Renato's suggestions. sudo apt-get install gcc-arm-linux-gnueabi libstdc++6 libncurses5 libncurses5-dev done! but : mark@mark-Presario-CQ43-Notebook-PC:~/fA_new/mini2440/linux-2.6.32.2$ sudo apt-get install gcc-arm-linux-gnueabi lib32ncurses5 lib32stdc++6 lib32z1 lib32bz2-1.0 Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package lib32ncurses5 E: Unable to locate package lib32stdc++6 E: Couldn't find any package by regex 'lib32stdc++6' E: Unable to locate package lib32z1 E: Unable to locate package lib32bz2-1.0 E: Couldn't find any package by regex 'lib32bz2-1.0' mark@mark-Presario-CQ43-Notebook-PC:~/fA_new/mini2440/linux-2.6.32.2$ mark@mark-Presario-CQ43-Notebook-PC:~/fA_new/mini2440/linux-2.6.32.2$ sudo apt-get install ia32-libs Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package ia32-libs mark@mark-Presario-CQ43-Notebook-PC:~/fA_new/mini2440/linux-2.6.32.2$ neither : mark@mark-Presario-CQ43-Notebook-PC:~/fA_new/mini2440/linux-2.6.32.2$ sudo make [sudo] password for mark: make: arm-linux-gcc: Command not found CHK include/linux/version.h make[1]: `include/asm-arm/mach-types.h' is up to date. CHK include/linux/utsrelease.h SYMLINK include/asm -> include/asm-arm CC kernel/bounds.s /bin/sh: 1: arm-linux-gcc: not found make[1]: *** [kernel/bounds.s] Error 127 make: *** [prepare0] Error 2 mark@mark-Presario-CQ43-Notebook-PC:~/fA_new/mini2440/linux-2.6.32.2$ //---------------------------------------------------------------- Can anyone help? Thanks a lot!
Hi .. i followed the above steps for ubuntu 12.04: 1. sudo apt-get install gcc-arm-linux-gnueabi libstdc++6 libncurses5 libncurses5-dev 2. sudo apt-get install is32-bits still i hav the following error user@user-OptiPlex-7010:~/new/kernel_imx$ export ARCH=arm user@user-OptiPlex-7010:~/new/kernel_imx$ export CROSS_COMPILE=/home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/ linux-x86/arm/arm-eabi-4.6/bin/arm-eabi- user@user-OptiPlex-7010:~/new/kernel_imx$ make wandboard_defconfig # # configuration written to .config # user@user-OptiPlex-7010:~/new/kernel_imx$ make -j4 make: /home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/ arm-eabi-4.6/bin/arm-eabi-gcc: Command not found scripts/kconfig/conf --silentoldconfig Kconfig make: /home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/ arm-eabi-4.6/bin/arm-eabi-gcc: Command not found CHK include/linux/version.h CHK include/generated/utsrelease.h CC scripts/mod/empty.o /bin/sh: 1: /home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/ arm-eabi-4.6/bin/arm-eabi-gcc: not found make[2]: *** [scripts/mod/empty.o] Error 127 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [scripts/mod] Error 2 make: *** [scripts] Error 2 make: *** Waiting for unfinished jobs....
Your environmental abnormal configuration is wrong . First you should download the arm-linux-gcc.4.5.1.tgz , and unzip the file . Then you should add the path in the PATH environment variable, then you can use arm-linux-gcc comment directly . export PATH="$PATH:/opt/FriendlyARM/toolschain/4.5.1/bin After adding the PATH, you have to reboot your PC .
Sorry, but you do not have to reboot your PC after changing the PATH variable.... we do not use w***s here :D
amit_emb@madhu-desktop:~/Desktop/android/geniatech-kernel-master$ export ARCH=arm CROSS_COMPILE=/home/amit_emb/cross_compiler/bin/arm-none-eabi- amit_emb@madhu-desktop:~/Desktop/android/geniatech-kernel-master$ export PATH=/home/amit_emb/cross_compiler/bin/:$PATH amit_emb@madhu-desktop:~/Desktop/android/geniatech-kernel-master$ sudo make exynos4_defconfig *** Default configuration is based on 'exynos4_defconfig' arch/arm/plat-meson/Kconfig:126: note: Open customer/boards/Kconfig arch/arm/plat-meson/Kconfig:133: note: Open customer/drivers/Kconfig drivers/amlogic/Kconfig:113: note: Open drivers/amlogic/ump/Kconfig drivers/amlogic/Kconfig:114: note: Open drivers/amlogic/mali/Kconfig drivers/amlogic/Kconfig:116: warning: Skip ../hardware/arm/gpu/ump/Kconfig drivers/amlogic/Kconfig:117: warning: Skip ../hardware/arm/gpu/mali/Kconfig arch/arm/mach-meson6tv/Kconfig:47:warning: choice value used outside its choice group arch/arm/mach-meson6tv/Kconfig:49:warning: choice value used outside its choice group drivers/amlogic/wifi/broadcm_40181/Kconfig:70:warning: choice value used outside its choice group drivers/amlogic/wifi/AP6xxx/Kconfig:10:warning: choice value used outside its choice group drivers/amlogic/wifi/AP6xxx/Kconfig:11:warning: defaults for choice values not supported drivers/amlogic/wifi/broadcm_40181/Kconfig:31:warning: defaults for choice values not supported drivers/amlogic/wifi/broadcm_40181/Kconfig:75:warning: choice value used outside its choice group drivers/amlogic/wifi/broadcm_40181/Kconfig:76:warning: defaults for choice values not supported drivers/amlogic/wifi/Kconfig:219:warning: choice value used outside its choice group drivers/amlogic/wifi/Kconfig:220:warning: defaults for choice values not supported # # configuration written to .config # amit_emb@madhu-desktop:~/Desktop/android/geniatech-kernel-master$ sudo make make: arm-none-linux-gnueabi-gcc: Command not found scripts/kconfig/conf --silentoldconfig Kconfig arch/arm/plat-meson/Kconfig:126: note: Open customer/boards/Kconfig arch/arm/plat-meson/Kconfig:133: note: Open customer/drivers/Kconfig drivers/amlogic/Kconfig:113: note: Open drivers/amlogic/ump/Kconfig drivers/amlogic/Kconfig:114: note: Open drivers/amlogic/mali/Kconfig drivers/amlogic/Kconfig:116: warning: Skip ../hardware/arm/gpu/ump/Kconfig drivers/amlogic/Kconfig:117: warning: Skip ../hardware/arm/gpu/mali/Kconfig arch/arm/mach-meson6tv/Kconfig:47:warning: choice value used outside its choice group arch/arm/mach-meson6tv/Kconfig:49:warning: choice value used outside its choice group drivers/amlogic/wifi/broadcm_40181/Kconfig:70:warning: choice value used outside its choice group drivers/amlogic/wifi/AP6xxx/Kconfig:10:warning: choice value used outside its choice group drivers/amlogic/wifi/AP6xxx/Kconfig:11:warning: defaults for choice values not supported drivers/amlogic/wifi/broadcm_40181/Kconfig:31:warning: defaults for choice values not supported drivers/amlogic/wifi/broadcm_40181/Kconfig:75:warning: choice value used outside its choice group drivers/amlogic/wifi/broadcm_40181/Kconfig:76:warning: defaults for choice values not supported drivers/amlogic/wifi/Kconfig:219:warning: choice value used outside its choice group drivers/amlogic/wifi/Kconfig:220:warning: defaults for choice values not supported make: arm-none-linux-gnueabi-gcc: Command not found CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s /bin/sh: 1: arm-none-linux-gnueabi-gcc: not found make[1]: *** [kernel/bounds.s] Error 127 make: *** [prepare0] Error 2
> make: arm-none-linux-gnueabi-gcc: Command not found Think you want to sort this first. arm-linux-gcc -v on the command line
I'm using command: sudo make zImage and it error: make: arm-linux-gcc: Command not found CHK include/linux/version.h make[1]: 'include/asm-arm/mach-types.h' is up to date. CHK include/linux/utsrelease.h SYMLINK include/asm -> include/asm-arm CC kernel/bounds.s /bin/sh: 1: arm-linux-gcc: not found /home/pt/Desktop/linux-2.6.32.2/./Kbuild:35: recipe for target 'kernel/bounds.s' failed make[1]: *** [kernel/bounds.s] Error 127 Makefile:982: recipe for target 'prepare0' failed make: *** [prepare0] Error 2 But, i'm using command: make zImage it's ok. build... Kernel: arch/arm/boot/zImage is ready Can you tell me why? :D :?
Hello, I am compiling modules for tiny6410 with make modules and I am getting similar error. I have already installed files as per requirement. 32 bit library also installed. Not sure of what I am missing. Entry from bash file: PATH=$PATH:/opt/FriendlyARM/toolschain/4.5.1/bin arm-linux-gcc -v gives below output. amit@Amit-Dell-System-XPS-L502X:/opt/FriendlyARM/mini6410/linux/linux-2.6.38$ arm-linux-gcc -v Using built-in specs. COLLECT_GCC=arm-linux-gcc COLLECT_LTO_WRAPPER=/opt/FriendlyARM/toolschain/4.5.1/libexec/gcc/arm-none-linux -gnueabi/4.5.1/lto-wrapper Target: arm-none-linux-gnueabi Configured with: /work/toolchain/build/src/gcc-4.5.1/configure --build=i686-build_pc-linux-gnu --host=i686-build_pc-linux-gnu --target=arm-none-linux-gnueabi --prefix=/opt/FriendlyARM/toolschain/4.5.1 --with-sysroot=/opt/FriendlyARM/toolschain/4.5.1/arm-none-linux-gnueabi/sys-root --enable-languages=c,c++ --disable-multilib --with-cpu=arm1176jzf-s --with-tune=arm1176jzf-s --with-fpu=vfp --with-float=softfp --with-pkgversion=ctng-1.8.1-FA --with-bugurl=http://www.arm9.net/ --disable-sjlj-exceptions --enable-__cxa_atexit --disable-libmudflap --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-gmp=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-mpfr=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-ppl=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-cloog=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-mpc=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-libelf=/work/toolchain/build/arm-none-linux-gnueabi/build/static --enable-threads=posix --with-local-prefix=/opt/FriendlyARM/toolschain/4.5.1/arm-none-linux-gnueabi/sys -root --disable-nls --enable-symvers=gnu --enable-c99 --enable-long-long Thread model: posix gcc version 4.5.1 (ctng-1.8.1-FA) amit@Amit-Dell-System-XPS-L502X:/opt/FriendlyARM/mini6410/linux/linux-2.6.38$ sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0 Reading package lists... Done Building dependency tree Reading state information... Done lib32bz2-1.0 is already the newest version. lib32ncurses5 is already the newest version. lib32z1 is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 304 not upgraded. amit@Amit-Dell-System-XPS-L502X:/opt/FriendlyARM/mini6410/linux/linux-2.6.38$ amit@Amit-Dell-System-XPS-L502X:/opt/FriendlyARM/mini6410/linux/linux-2.6.38$ sudo make modules make: arm-linux-gcc: Command not found CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s /bin/sh: 1: arm-linux-gcc: not found make[1]: *** [kernel/bounds.s] Error 127 make: *** [prepare0] Error 2 When I execute same command with super user, I get different error as below root@Amit-Dell-System-XPS-L502X:/opt/FriendlyARM/mini6410/linux/linux-2.6.38# make modules CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CALL scripts/checksyscalls.sh scripts/Makefile.build:254: target `drivers/char/mini6410_hello_module.O' doesn't match the target pattern CC [M] drivers/char/mini6410_hello_module.O arm-linux-gcc: no input files make[2]: *** [drivers/char/mini6410_hello_module.O] Error 1 make[1]: *** [drivers/char] Error 2 make: *** [drivers] Error 2 Please advise what possibly I am missing. Thank you, Amit
1) how bits is your host? 2) doing arm-linux-gcc -v while in this directory amit@Amit-Dell-System-XPS-L502X:/opt/FriendlyARM/mini6410/linux/linux-2.6.38 seems to work Try arm-linux-gcc -v while in your home directory to make sure your EXPORT_PATH is working. When you said "Entry from bash file" do you mean your .bashrc file or .profile file?
1) -> Host machine(laptop) is 64 bit. Linux 14.01(64 bit) is installed. 2) -> arm-linux-gcc -v in home works fine. See below results. amit@Amit-Dell-System-XPS-L502X:~$ arm-linux-gcc -v Using built-in specs. COLLECT_GCC=arm-linux-gcc COLLECT_LTO_WRAPPER=/opt/FriendlyARM/toolschain/4.5.1/libexec/gcc/arm-none-linux -gnueabi/4.5.1/lto-wrapper Target: arm-none-linux-gnueabi Configured with: /work/toolchain/build/src/gcc-4.5.1/configure --build=i686-build_pc-linux-gnu --host=i686-build_pc-linux-gnu --target=arm-none-linux-gnueabi --prefix=/opt/FriendlyARM/toolschain/4.5.1 --with-sysroot=/opt/FriendlyARM/toolschain/4.5.1/arm-none-linux-gnueabi/sys-root --enable-languages=c,c++ --disable-multilib --with-cpu=arm1176jzf-s --with-tune=arm1176jzf-s --with-fpu=vfp --with-float=softfp --with-pkgversion=ctng-1.8.1-FA --with-bugurl=http://www.arm9.net/ --disable-sjlj-exceptions --enable-__cxa_atexit --disable-libmudflap --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-gmp=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-mpfr=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-ppl=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-cloog=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-mpc=/work/toolchain/build/arm-none-linux-gnueabi/build/static --with-libelf=/work/toolchain/build/arm-none-linux-gnueabi/build/static --enable-threads=posix --with-local-prefix=/opt/FriendlyARM/toolschain/4.5.1/arm-none-linux-gnueabi/sys -root --disable-nls --enable-symvers=gnu --enable-c99 --enable-long-long Thread model: posix gcc version 4.5.1 (ctng-1.8.1-FA) 3) -> "Entry from bash file" means .bashrc file.
Thank you davef for help. My issue is resolved now. I did some mistakes while changing Makefile and after correcting it everything is fine
On android kernel compiling i got the following error I tried different tool chains and everything ended with the same error.Am a noob to this kernel compiling and someone please help me to solve this error Using /home/cherian/kernel as source for kernel GEN /home/cherian/kernel/output/Makefile CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h make[2]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s gcc: error: unrecognized argument in option -mabi=aapcs-linux gcc: note: valid arguments to -mabi= are: ms sysv gcc: error: unrecognized command line option -mlittle-endian gcc: error: unrecognized command line option -mno-thumb-interwork make[2]: *** [kernel/bounds.s] Error 1 make[1]: *** [prepare0] Error 2 make: *** [sub-make] Error 2 make: Leaving directory `/home/cherian/kernel'
i wrote a module and add it to kernel,now i want to compile it but i can't :( what should i do? root@ubuntu:/home/me64285/linux-4.6# make make: arm-none-linux-gnueabi-gcc: Command not found scripts/kconfig/conf --silentoldconfig Kconfig make: arm-none-linux-gnueabi-gcc: Command not found CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s /bin/sh: 1: arm-none-linux-gnueabi-gcc: not found make[1]: *** [kernel/bounds.s] Error 127 make: *** [prepare0] Error 2
make: arm-none-linux-gnueabi-gcc: Command not found Search the forum for this error. It appears you haven't got a PATH to your compiler.
