i'm running the linux kernel and rootfs i built from the pengutronix BSP on a mini6410. i turned on QT support so have all the QT files, along with some demo programs. i have an LCD screen attached to the board. when i try to run the demos, for example typing ./affine -qws, i get this error: LinuxFb: driver not found does anyone know what this is? i assume it has something to do with the framebuffer, but am not sure. i can run fbtest and everything passes.
Qt cannot find its own driver for the framebuffer driver. Build the Qt library with the gfx-linuxfb option (works at least with Qt-4.8.1)
