Hello, I want to develop software for the mini6410 with qt. So I installed qt embedded (4.7.0) and Qtcreator on my ubuntu. I can compile and run C programs like: #include <stdio.h> main() { printf("Hello World\n"); } But a (empty) qt-programm doesn't work (hallo.cpp): #include <QtCore/QCoreApplication> int main(int argc, char *argv[]) { QCoreApplication a(argc, argv); return a.exec(); } make works and file says: hallo: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.14, not stripped I copied it to the mini and chmod +x it and then a ./hallo gives me the Segmentation fault:-( What's wrong with my QT? Greetings from Germany Holger
Qt segmentation fault
> Try ./hallo -qws I did. The same error:-( Need I qtopia on the Desktop? Need I a specific version of QTCreator? But I compile it at the console with make not with the Creator.
Run your app with "strace" to get an idea what libraries it tries to load. Then compare the library revisions on your target with the cross compiled ones at your development host (from the libc of your toolchain). If they are not the same, this can be the cause of your segmentation fault.
Do you know http://www.friendlyarm.net/forum/topic/3015 ? Maybe you should start with it to get the root filesystem and its content under your control.
Looks interesting, but no USB support? Than it is useless for me. I need a 3G Modem, GPS mouse, rfid reader. All are usb devices. At the moment I need a working qt. I recompiled it with the Friendlyarm toolchain. But the result is the seg. fault on the mini:-(
Ok, I tested more. C and C++ programms are running but no QT! I tried the hello examplefrom the dvd. Also a segmentation fault. I think something with the qt libs on the mini is incompatible. I will try to compile these new and report.
Also you want to check all your cross-compiled files with: readelf -A <filename> especially your Qt libs as you mentioned.
Ah, ok... for the example in the first posting only libQtCore.so.4.7.0 is needed. On my pc: $ cd /usr/local/Trolltech/QtEmbedded-4.7.0-arm/lib $ readelf -A libQtCore.so.4.7.0 Attribute Section: aeabi File Attributes Tag_CPU_name: "ARM1176JZF-S" Tag_CPU_arch: v6K Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_FP_arch: VFPv3 Tag_Advanced_SIMD_arch: NEONv1 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align_needed: 8-byte Tag_ABI_align_preserved: 8-byte, except leaf SP Tag_ABI_enum_size: int Tag_ABI_HardFP_use: SP and DP Tag_ABI_optimization_goals: Aggressive Speed The same lib from the mini: Attribute Section: aeabi File Attributes Tag_CPU_name: "ARM1176JZF-S" Tag_CPU_arch: v6K Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_FP_arch: VFPv2 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align_needed: 8-byte Tag_ABI_align_preserved: 8-byte, except leaf SP Tag_ABI_enum_size: int Tag_ABI_HardFP_use: SP and DP Tag_ABI_optimization_goals: Aggressive Speed The "Tag_FP_arch" is on the pc VFPv3 and on the mini VFPv2. Is that the problem? If yes, how can I solve this? And what is with the "Tag_Advanced_SIMD_arch" that is not present in the lib from the mini?
To make it work in a reliable way, everything on your target must be made with the same toolchain (compiler, libc, assembler and so on). If not, you will search for phantom bugs until the end of your life.
hmm... so I have to recompile qtopia and qte for the mini with the same FriendlyARM toolchain I compiled it on the Desktop? Thats not a very userfriendly way:-( There is an qt on the mini, so I should be able to use it. It should be work like in Debian for example, I need not to recompile all programs to work on it. Very strange...!
What you need is, the runtime libraries must be the same (or at least built in the same way) way as the development libraries. Think about if your program is linked against revision X of a library and on the target revision Y of this library is available. How should that work in a reliable way? What you need is a development environment that matches the state of the libraries available on your target (this means for example all header files define things that matches the runtime libraries). And a toolchain which builds everything new against this environment. Then your results will work on the target. Maybe this kind of development environment is part of the CD/DVD (I didn't check yet)?.
I solved the problem! It was not a problem with any libs. The problem was the ftp program (filezilla). The following worked on the mini: arm-linux-gcc hello-world.c Transfered the a.out to the mini, chmod +x and worked. arm-linux-gcc -o hello-world hello-world.c does not work. The binary was exact the same. The transfermode in filezilla was set the automatic. After I set it the binary the hello-world works. But now I had problem with an gui example. Only a butten and a inputfield created with QtCreator. Tested it with: ./guitest -qws Transformed: Driver not found Aborted I recompile my qt-lib on the host with -qt-gfx-transformed and will try again. Thanks for your help.
How should re-compiling the Qt lib on your host help? You need the differently configured and built Qt lib on your target.
Yes. I copied the new libs also to the target and get an illegal instruction. The pre-installed examples are working (with the original libs), so I think something with my program is wrong for the mini. The new compiled libs don't work on the Mini but I can compile without errors or warnings with them. I compiled them on a amd64 Gentoo machine with the Friendlyarm toolschain. The toolschain should work correct, because the C and C++ programs I compiled with it are working. So I think the failure is in the tslib or in the qte. Ok, first I will check if a qt console application is working. Or whats a working configure for the qte?
So, the hello example in the arm-qtopia 2.2.0 from the dvd is working. I can open and modify the hello_base.ui with the QtDesigner from the dvd. It is version 1.1!!! Also installed is QtDesigner 4.7.4, but it seems the resulting ui-files ar not compatible. The new designer couldnot open the ui-file and with an new ui-file (from the 4.7.4 designer) the make fails. In the old designer for example changes in font size dont matter:-( Is it able to use the new designer? How can I change font and font size? I make an app for working with finger and the small default font is much to small:-)
GREAT Thanks Holger! I fought two days with same Filezilla problem. Segmentation fault. But now I got this readelf -A procedure to get it just right so it was all for good. It really does not need to be even close to correct for program to run: My out of box compilation (arm-linux-gnueabi-gcc hello.c -o hello) on Debian gives like: Tag_CPU_name: "ARM9TDMI" Tag_CPU_arch: v4T Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align_needed: 8-byte Tag_ABI_align_preserved: 8-byte, except leaf SP Tag_ABI_enum_size: int It runs OK on linux modem! Here is same out of box compilation from Ubuntu: Tag_CPU_name: "5T" Tag_CPU_arch: v5T Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_rounding: Needed Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align_needed: 8-byte Tag_ABI_align_preserved: 8-byte, except leaf SP Tag_ABI_enum_size: int It runs OK. But the most basic library on the modem itself(libc.so.6) gives totally different elf: Tag_CPU_name: "7-A" Tag_CPU_arch: v7 Tag_CPU_arch_profile: Application Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-2 Tag_FP_arch: VFPv3 Tag_Advanced_SIMD_arch: NEONv1 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align_needed: 8-byte Tag_ABI_enum_size: int Tag_ABI_HardFP_use: SP and DP Tag_DIV_use: Not allowed
