Mini2440 and arduino
ganesh
Hai,
Can i get a good way to interface arduino with mini2440...i connected
arduino via usb port of mini2440..The FTDI drivers are working fine and am
getting the arduino powered...Can i make a pin say Pin 12 of Arduino high
through the shell of mini2440...can anyone help me out...
Screwface
Hi Ganesh,
Do you really need to use an arduino to have GPIOS? Why don't you use
mini's ones?
Ganesh H
yes i can use mini's GPIO i just want to know about the communication
etween both
I'd search for "talking to your serial port from a sh script" or a bash
script, if you can install that on the mini2440.
I was going to use serial comms to talk to a ATmega32, but from a PHP
script.
Good luck!
NothinRandom
Hi Ganesh,
I would open up serial com port on the mini, and start talking to the
arduino.
Just do the regular stuff for arduino:
Serial.begin(9600);
void loop
if(Serial.available())
//do something here.
If you still need help, I can show you most of these stuff.
ganesh
Hi NothinRandom,
Thanks for the reply i need more help..How could i get serial com port on
mini am using Qtopia OS in it...I want to make a pin of arduino say pin 12
high using mini...
LectricHead
I was scanning through this forum and saw this thread went un-answered.
Here is an answer for others that fall on this thread. It is really easy to
communicate with Arduino from the Mini2440. This is how I ended up doing
it.
http://combustory.com/wiki/index.php/Arduino_Communications_Using_the_ne...
