Hi all, I've a problem with the mini6410 board and its 7" touchscreen in a system based on Linux Ubuntu 9.10 OS This is my environment: Ubuntu kernel: uzImage_a70 from DVD (Ubuntu Karmic 9.10) Rootfs: generated with Rootstock with this command sudo rootstock --fqdn ubuntu --login ubuntu --password temppwd --kblayout it --dist karmic --mirror http://old-releases.ubuntu.com/ubuntu --seed xorg ts.conf file: module_raw one-wire-ts-input module pthres pmin=1 module variance delta=30 module dejitter delta=10000 module linear The directory usr/lib/ts0 contains the file: one-wire-ts-input.so (that I've compiled) In the directory /usr/lib there are these files: libts-0.0.so.0, libts-0.0.so.0.1.1 At the first boot the system run this code: export PATH=/bin:/sbin:/usr/bin:/usr/sbin mkdir /dev/input 2>/dev/null mknod /dev/input/event1 c 13 64 2>/dev/null mknod /dev/fb0 c 29 0 2>/dev/null mknod /dev/touchscreen c 10 180 2>/dev/null mknod /dev/touchscreen-1wire c 10 181 2>/dev/null mknod /dev/s3c2410_serial3 c 204 67 2>/dev/null export TSLIB_TSDEVICE=/dev/touchscreen-1wire export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/etc/ts.conf export TSLIB_PLUGINDIR=/usr/lib/ts0 export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_CONSOLEDEVICE=none if [ ! -s /etc/pointercal ] ; then ts_cal mv /pointercal /etc fi exec /sbin/init At the first boot the system recognizes correctly the touchscreen: 1Wire touchscreen OK TouchDevice: /dev/touchscreen-1wire xres = 800, yres = 480 and the procedure "ts_cal" is performed correctly (file etc/pointercal created) After this I login into Ubuntu but the touchscreen stops working: a. the command cat /dev/touchscreen-1wire work correctly b. if I call ts_cal or ts_calibrate return errors ts_config: no such file or directory or ts_open: no such file or directory or TouchDevice: (null) I don't understand where is the error, please can anyone help me?
mini6410 + 7" touchscreen
Just a thought. Have you actually configured the links on the LCD to support the 1-wire interface? My LCD came with it configured to connect direct to the ARM touch screen interface. Once the links were swapped it works perfectly and a lot more stable than the ARM interface option. Dave...
Hi, all I tried to run ubuntu 9.10 on mini6410 from SD card, i have burn the image and set up friendlyarm.ini as: CheckOneButton=No Action=run OS=Ubuntu VerifyNandWrite=No StatusType = Beeper| LED #################### Linux ##################### Linux-BootLoader = Linux/u-boot_nand-ram128.bin Linux-Kernel = Linux/zImage_A70 Linux-CommandLine = root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200 Linux-RootFs-InstallImage = linux/rootfs_qtopia_qt4-s.img Linux-RootFs-RunImage = linux/rootfs_qtopia_qt4-s.ext3 ################### WindowsCE6 ################# WindowsCE6-Bootloader= WindowsCE6\NBOOT_A70-RAM128.nb0 WindowsCE6-BootLogo = WindowsCE6\bootlogo.bmp WindowsCE6-InstallImage = WindowsCE6\NK_A70-s.bin WindowsCE6-RunImage = WindowsCE6\NK_A70-s.bin ################### Android #################### Android-BootLoader = Android/u-boot_nand-ram128.bin Android-Kernel = Android/azImage_a70 Android-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 Android-RootFs-InstallImage = Android/rootfs_android-s.ubi Android-RootFs-RunImage = Android/rootfs_android-s.ext3 ################### Ubuntu ##################### Ubuntu-BootLoader = Ubuntu/u-boot_nand-ram128.bin Ubuntu-Kernel = Ubuntu/uzImage_a70 Ubuntu-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 Ubuntu-RootFs-InstallImage = Ubuntu/rootfs_ubuntu-s.ubi Ubuntu-RootFs-RunImage = Ubuntu/rootfs_ubuntu.ext3 ############### UserBin part ################# UserBin-Image=WindowsCE/NK.nb0 userBin-StartAddress=50100000 ,but i dont have LCD modul so i used LCD monitor which is connected to LCD monitor...its work when i run WIN CE, but its run for ubuntu..why it just performed white screen??i have attached on the picture anyone can help me, please?
Hi Ika, Have you used or built the kernel to support you video output? Looking at the info above I see image drivers for the 7" LCD. As I don't know anything about your video to VGA interface, can you tell us more about that so we can try to work out what is wrong. Thanks Dave...
