Hi Guys, I cross compile Qt4.6 (downloaded from friendlyarm website). When I run fluidlauncher example its taking a while for the application to be loaded. Once it is loaded the frame update rate is also very slow. Qt is running very slow on mini2440. I compiled busybox rootfs from friendlyarm. I even tried the configuration mentioned on "http://www.friendlyarm.net/forum/topic/402" ./configure -prefix /usr/local/Qt -fast -pch -no-qt3support -qt-sql-sqlite -no-libtiff -no-libmng -qt-libjpeg -qt-zlib -qt-libpng -qt-freetype -no-openssl -nomake examples -nomake demos -nomake tools -optimized-qmake -no-phonon -no-nis -no-opengl -no-cups -no-xcursor -no-xfixes -no-xrandr -no-xrender -no-xkb -no-sm -no-xinerama -no-xshape -no-separate-debug-info -xplatform qws/linux-arm-g++ -embedded arm -depths 16,32 -no-qvfb -qt-gfx-linuxfb -no-gfx-qvfb -no-kbd-qvfb -no-mouse-qvfb -opensource -confirm-license -qt-mouse-tslib -I<path_to_tslib>/tslib/build/include -L<path_to_tslib>/tslib/build/lib but still the performance is very slow. Can some one please share some inputs on how to increase the performance. I dont mind using some other toolchain and rootfs. thanks tama
Qt running very slow on minic2440
Did you solve your problems? Now I'm starting with QT and mini2440 with default kernel , image and rootfs. I disable Qtopia and port QT application on board for running but the app run gradually slow, about 5 mins, it stand there and I can not interact with app anymore, I have to restart the board. Could you give me some advice? Thanks a lot.
Thank you Juergen Beisert. I've solved my problem. My application continuously received data from a GPS receiver so that it caused memory leak with 100% CPU in some mins. I've used a thread sleep (20ms) in my receiver class and it reduced to 66%.
