i have mini6410 and i try to install linux from sd card the installation process done good but then when i boot from s1 ( nand flash ) the screen open on this pic and still on this screen http://store2.up-00.com/Mar12/xBl52099.jpg what is my problem and how can i solve it ?
mini6410 with h43 touch screen
I'm not sure what you are talking about. If you have some problems with the graphic it's because the h43 is not 100% compatible with the n43 so you need a kernel with h43-support (look here: http://www.friendlyarm.net/forum/topic/3894#lastpost ) If your problem is, that the calibration-application starts during every boot read the short /initrc - script. And try to find out why it starts the calibration-process on every boot. (Maybe you can delete the lines which execute that application)
hi redeagle thanx for your reply i found my bad problem :) the problem was in my knowledge :D i must follow the + on the screen touch to calibrate the touch screen i did not done this :) i thought it is an error but it was bad knowledge from me :) thanx for ur replying redeagle
