the default website when you plug in the TINY6410 SDK into your ethernet network has an example of blinking the LED lights on the Tiny6410 board using GPKDAT (i think). The leds.html calls the leds.cgi file, which is a batch script. At the end of it, it does this command "/bin/echo $type $period > /tmp/led-control" which runs a C program that tells the period and type of blinking to perform. where is the source code for this C program?
