Hello, I am trying to get serial GPS module work with android, and it is mentioned in user manual that serial1 has been configured by adding following line in init.rc setprop ro.kernel.android.gps s3c2410_serial1 but this does not work for me, it shows only gps symbol on screen and nothing happens, however nothing is written about baud rate. anybody got it work?
GPS on tiny210
now I have connected gps module to s3c2410_serial2 at 4800 baud rate. and changed line in init.rc setprop ro.kernel.android.gps s3c2410_serial2 and also changed baud rate of port 4800 no parity stty 4800 cs8 -parenb -F /dev/s3c2410_serial2 but still not working, keeps on showing no GPS satellite found, :(
Hi, 1st let me say I know nothing about your board and device; so what I post here is derived from some experience with a couple of Android tablets ... most Android devices process the file /data/local.prop - so there you can usually add the stuff needed for your gps, f.e.: ro.kernel.android.gps=s3c2410_serial1 gps.device=s3c2410_serial1 gps.baud=9600 gps.accuracy=6 also, after you did set the baudrate with stty, did you test with 'cat' that you can read data from the device? f.e.: cat /dev/s3c2410_serial1 should give you the nmea output of the gps device (with some android devices you may need to use 'busybox cat'). oh, and did you check that the device /dev/s3c2410_serial1 really exists? perhaps you need to load a kernel module 1st?
