I am trying to compile freetype for mini2440 for which I have to specify --build option when I run the configure script. Can someone tell me what to specify for --build option for mini2440? What does that option mean? Thanks in advance!
--host defines your Mini2440 (and the compiler to be used) as the target the code should run on and --build the host where the code will be compiled. In PTXdist the autotools based packages are configured on my host with "--host=arm-v4t-linux-gnueabi --build=i686-host-linux-gnu"
