Hello everyone ! I am trying to port linux 3.2.9 to mini2440 with pengutronix BSP. i have successfully compiled the kernel, root-file system and also loaded the kernel image and root-fs image to mini2440. but after booting this gives me following error: uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : mtd->read(0x1faa4 bytes from 0x8055c) returned ECC error uncorrectable error : mtd->read(0x8c68 bytes from 0x97398) returned ECC error VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 124K Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. Backtrace: [<c0012a94>] (dump_backtrace+0x0/0xfc) from [<c03039a0>] (dump_stack+0x18/0x1c) r7:00000013 r6:c0024228 r5:c03f1378 r4:c043fd28 [<c0303988>] (dump_stack+0x0/0x1c) from [<c0303a04>] (panic+0x60/0x194) [<c03039a4>] (panic+0x0/0x194) from [<c00086f0>] (init_post+0xa8/0xcc) r3:00000044 r2:c04f20a8 r1:c04f20a8 r0:c0393399 [<c0008648>] (init_post+0x0/0xcc) from [<c03f1420>] (kernel_init+0xa8/0xcc) r5:c03f1378 r4:c043f900 [<c03f1378>] (kernel_init+0x0/0xcc) from [<c0024228>] (do_exit+0x0/0x29c) i have tried to get init with '/sbin/init' or '/linuxrc' in bootargs.but failed. i have also changed the loading init with upstart but failed. any suggestions ? Thanks in advance.
barebox Kernel panic - not syncing
There is something really broken with your NAND configuration. Did you wrote this JFFS2 rootfile image with the help of Barebox into the NAND? What kind of flash device is on your MIni2440? Did you use the correct PTXdist project NAND layout configuration, with regard to your NAND device (64 MiB NAND versus all other known sizes)? Can show us the full text log beginning with the starting Barebox?
Hello Juergen. yes, i had wrote JFFS2 rootfile to NAND with barebox. my mini2440 has 1GB flash. so ,i selected the 128M configuration. i have checked the barebox configuration in platformconfig. that is also barbox-NAND-128M.config i have checked that my sysroot-target has '/sbin/init' and '/linuxrc' which is link to '/bin/busybox'. so what is problem ?
This is log when i start mini2440. booting kernel of type uimage from /dev/nand0.kernel.bb Verifying Checksum ... OK Image Name: Linux-3.2.9-SLTL Created: 2012-03-12 6:58:12 UTC Image Type: <NULL> <NULL> <NULL> (<NULL>) Data Size: 2158768 Bytes = 2.1 MB Load Address: 30008000 Entry Point: 30008000 OK commandline: console=ttySAC0,115200 mini2440=0tbc ip=192.168.1.230:192.168.1.7:192.168.1.2:255.255.255.0::: root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtd) arch_number: 1999 Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 3.2.9-SLTL (jaydeep@ubuntu) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #1 Mon Mar 12 12:28:08 IST 2012 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 CPU: VIVT data cache, VIVT instruction cache Machine: MINI2440 Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C24XX Clocks, Copyright 2004 Simtec Electronics S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttySAC0,115200 mini2440=0tbc ip=192.168.1.230:192.168.1.7:192.168.1.2:255.255.255.0::: root=/dev/mtdblock3 rootfstype=jffs2 noin) PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60444k/60444k available, 5092k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xc4800000 - 0xf6000000 ( 792 MB) lowmem : 0xc0000000 - 0xc4000000 ( 64 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .text : 0xc0008000 - 0xc03e3000 (3948 kB) .init : 0xc03e3000 - 0xc0403000 ( 128 kB) .data : 0xc0404000 - 0xc0433360 ( 189 kB) .bss : 0xc0433384 - 0xc0462f3c ( 191 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:85 irq: clearing pending ext status 00000080 irq: clearing subpending status 00000003 irq: clearing subpending status 00000002 Console: colour dummy device 80x30 Calibrating delay loop... 201.52 BogoMIPS (lpj=503808) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 MINI2440: Option string mini2440=0tbc MINI2440: 't' ignored, touchscreen not compiled in MINI2440: LCD [0:240x320] 1:800x480 2:1024x768 S3C2440: Initialising architecture S3C2440: IRQ Support S3C244X: Clock Support, DVS off bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c-i2c s3c2440-i2c: slave address 0x10 s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter Advanced Linux Sound Architecture Driver Version 1.0.24. NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (double precision) audit: initializing netlink socket (disabled) type=2000 audit(0.110:1): initialized JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc. msgmni has been set to 118 alg: No test for stdrng (krng) Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) io scheduler noop registered (default) Console: switching to colour frame buffer device 30x20 fb0: s3c2410fb frame buffer device s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440 console [ttySAC0] enabled s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440 loop: module loaded at24 0-0050: 1024 byte 24c08 EEPROM, writable, 16 bytes/write S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns s3c24xx-nand s3c2440-nand: NAND soft ECC NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Creating 4 MTD partitions on "nand": 0x000000000000-0x000000040000 : "u-boot" 0x000000040000-0x000000060000 : "u-boot-env" 0x000000060000-0x000000560000 : "kernel" 0x000000560000-0x000040000000 : "root" dm9000 Ethernet Driver, V1.31 eth0: dm9000e at c486a300,c486c304 IRQ 51 MAC: aa:bb:cc:dd:ee:ff (chip) ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: S3C24XX OHCI usb usb1: Manufacturer: Linux 3.2.9-SLTL ohci_hcd usb usb1: SerialNumber: s3c24xx hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver ums-alauda usbcore: registered new interface driver ums-cypress usbcore: registered new interface driver ums-datafab usbcore: registered new interface driver ums-freecom usbcore: registered new interface driver ums-isd200 usbcore: registered new interface driver ums-jumpshot usbcore: registered new interface driver ums-karma usbcore: registered new interface driver ums-onetouch usbcore: registered new interface driver ums-sddr09 usbcore: registered new interface driver ums-sddr55 usbcore: registered new interface driver ums-usbat mousedev: PS/2 mouse device common for all mice S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c-rtc s3c2410-rtc: rtc disabled, re-enabling s3c-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq disabled s3c-sdi s3c2440-sdi: powered down. s3c-sdi s3c2440-sdi: mmc0 - using pio, sw SDIO IRQ usbcore: registered new interface driver usbhid usbhid: USB HID core driver ALSA device list: No soundcards found. TCP cubic registered NET: Registered protocol family 17 s3c-rtc s3c2410-rtc: setting system clock to 2124-05-16 08:04:11 UTC (576552955) dm9000 dm9000: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1 IP-Config: Complete: device=eth0, addr=192.168.1.230, mask=255.255.255.0, gw=192.168.1.2, host=192.168.1.230, domain=, nis-domain=(none), bootserver=192.168.1.7, rootserver=192.168.1.7, rootpath= Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes empty_blocks 8147, bad_blocks 0, c->nr_blocks 8149 VFS: Cannot open root device "mtdblock3" or unknown-block(31,3) Please append a correct "root=" boot option; here are the available partitions: 1f00 256 mtdblock0 (driver?) 1f01 128 mtdblock1 (driver?) 1f02 5120 mtdblock2 (driver?) 1f03 1043072 mtdblock3 (driver?) Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3) Backtrace: [<c0013208>] (dump_backtrace+0x0/0x10c) from [<c0304ee8>] (dump_stack+0x18/0x1c) r7:00000013 r6:00008000 r5:c3811000 r4:c3823f38 [<c0304ed0>] (dump_stack+0x0/0x1c) from [<c0304f4c>] (panic+0x60/0x1ac) [<c0304eec>] (panic+0x0/0x1ac) from [<c03e3ce0>] (mount_block_root+0x178/0x234) r3:00000000 r2:c3848574 r1:c3823f38 r0:c03848bc [<c03e3b68>] (mount_block_root+0x0/0x234) from [<c03e3e24>] (mount_root+0x88/0x108) [<c03e3d9c>] (mount_root+0x0/0x108) from [<c03e3fa0>] (prepare_namespace+0xfc/0x194) r7:00000013 r6:c0433400 r5:c03fbfec r4:c03fbff8 [<c03e3ea4>] (prepare_namespace+0x0/0x194) from [<c03e32f4>] (kernel_init+0xf0/0x130) r6:c0402000 r5:c0401c94 r4:c0402000 [<c03e3204>] (kernel_init+0x0/0x130) from [<c0024c98>] (do_exit+0x0/0x2a0) r7:00000013 r6:c0024c98 r5:c03e3204 r4:00000000
Did you modify the Barebox's '/env/config' or '/env/bin/boot'? I miss the 'mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(kernel),-(root)' kernel command line parameter. Without this parameter, Barebox and the kernel are using different partition sizes and locations. That is why your kernel fails to mount the root filesystem.
Thanks for reply. i am currently checking it. but i am facing a new problem when i upload kernel to board. tftp communication is ok. but, when i issue 'boot nand' command it shows following, booting kernel of type uimage from /dev/nand0.kernel.bb Verifying Checksum ... Bad Data CRC there is no error in uploading.so where is problem? Thanks.
Seems your whole NAND partitioning is completely messed up. First check, if your /env/config defines a NAND partition layout: mini2440:/ cat /env/config [...] # NAND boot settings # Device name used by the kernel nand_device="nand" # partition definition in the NAND nand_parts="512k(barebox),384k(bareboxenv),2048k(kernel),-(root)" # rootfs's partition number in the NAND rootfs_mtdblock_nand=3 # used when manually booting with "boot nand" command rootfs_mtdblock_type=jffs2nv/config' still defines the [...] This 'nand_parts' partition definition setting must be used by Barebox and the kernel.
Hello Juergen, I am trying to bootup mini2440 with Pengutronix BSP, All images compiled well, barebox loaded perfect, but when I am trying to run kernel it gives 'uncorrectable error :' error. Here is my command line : commandline: console=ttySAC0,115200 mini2440=0tbc ip=none root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(k) I read this thread about the same problem facing by Jaydeep, but there is no solution describe over here. could you please tell where should I look for the error, how can i solve this error? Thanks & Regards, Freqclock.
Hello Juerge, Do i need to make changes in mach-mini2440.c? because there is a definition and declaration for the nand initialization.
Did you really read the thread? I wrote at "2012-03-12 09:22:50" the kernel command line must contain: 'mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(kernel),-(root)' And you report your kernel command line contains: 'mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(k)'. Do you now see the difference?
Juergen, Please check the command line, it is as per the expected. commandline: console=ttySAC0,115200 ip=none root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(kernel),-(root), in previous case it was there but not printing on the console. I am still facing the same problem of 'uncorrectable error : '. Please help me out there. Look forward to hear from you soon. Regards, freqclock
some kernel logs for more information. -- JFFS2 version 2.2. (NAND) (SUMMARY) �੩ 2001-2006 Red Hat, Inc. msgmni has been set to 119 io scheduler noop registered io scheduler deadline registered (default) Console: switching to colour frame buffer device 30x20 fb0: s3c2410fb frame buffer device s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440 console [ttySAC0] enabled s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440 loop: module loaded S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns s3c24xx-nand s3c2440-nand: NAND soft ECC s3c24xx-nand s3c2440-nand: Using flash based BBT NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Creating 4 MTD partitions on "nand": 0x000000000000-0x000000040000 : "u-boot" 0x000000040000-0x000000060000 : "u-boot-env" 0x000000060000-0x000000560000 : "kernel" 0x000000560000-0x000040000000 : "root" dm9000 Ethernet Driver, V1.31 eth0: dm9000e at c4878300,c487a304 IRQ 51 MAC: 70:71:bc:cc:24:91 (chip) ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: S3C24XX OHCI usb usb1: Manufacturer: Linux 3.1.1-ptx-2011.11.0-SLTL ohci_hcd usb usb1: SerialNumber: s3c24xx hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mousedev: PS/2 mouse device common for all mice samsung-ts s3c2440-ts: driver attached, registering input device input: S3C24XX TouchScreen as /devices/virtual/input/input0 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c-rtc s3c2410-rtc: rtc disabled, re-enabling s3c-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled TCP cubic registered NET: Registered protocol family 17 s3c-rtc s3c2410-rtc: setting system clock to 2012-04-02 16:40:49 UTC (1333384849) uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : mtd->read(0x800 bytes from 0x1f800) returned ECC error uncorrectable error : mtd->read(0x100 bytes from 0x0) returned ECC error uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : --
> Please check the command line, it is as per the expected. Sorry, no, it isn't because this list is the built in partition layout. > [...] > Creating 4 MTD partitions on "nand": > 0x000000000000-0x000000040000 : "u-boot" > 0x000000040000-0x000000060000 : "u-boot-env" > 0x000000060000-0x000000560000 : "kernel" > 0x000000560000-0x000040000000 : "root" > [...] It seems your kernel does not receive the correct 'mtdparts' values.
Did you manage to place barebox-image into flash? Maybe, cut and paste what you see when you stop the autoboot and do a /env/config
Juergen, http://www.friendlyarm.net/forum/topic/3916#18886 Please check, I've wrote do i need to make changes in mini2440.c file according to the partition. @Davef, Yes, barebox installed correctly into flash. -- Board: Mini 2440 NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Bad block table found at page 524224, version 0x01 Bad block table found at page 524160, version 0x01 dm9000 i/o: 0x20000300, id: 0x90000a46 eth@eth0: got MAC address from EEPROM: FF:FF:FF:FF:FF:FF refclk: 12000 kHz mpll: 405000 kHz upll: 48000 kHz fclk: 405000 kHz hclk: 101250 kHz pclk: 50625 kHz SDRAM1: CL2@101MHz Malloc space: 0x33a00000 -> 0x33e00000 (size 4 MB) Stack space : 0x339f8000 -> 0x33a00000 (size 32 kB) running /env/bin/init... Hit any key to stop autoboot: 3 mini2440:/ . /env/config mini2440:/ -- here is the cut and paste of what you are saying. @Juergen, I think I need to make changes in mini2440.c file for the partition. can you please confirm the same and if Yes, what value must be there in .c file for correct kernel parameter. Regards, freqclock
@daveg, @juergen, what should i do, so that kernel receive correct partition? Please help me in this case. Regards, Freqclock
@davef, here it is -- #!/bin/sh machine=mini2440 user= # use 'dhcp' to do dhcp in barebox and in kernel # use 'none' if you want to skip kernel ip autoconfiguration ip=none # or set your networking parameters here eth0.ipaddr=192.168.1.230 eth0.netmask=255.255.255.0 eth0.gateway=192.168.1.1 eth0.serverip=192.168.1.232 eth0.ethaddr=70:71:bc:cc:24:91 # autoboot settings # can be either 'tftp', 'nfs', 'nand' or 'mmc' kernel_loc=nand # can be either 'net', 'nand', 'initrd' or 'mmc' rootfs_loc=nand # can be either 'jffs2' or 'ubifs' for flash o rootfs_type=jffs2 rootfsimage=root-${machine}.${rootfs_type} # The image type of the kernel. Can be uimage, zimage, raw, or raw_lzo #kernelimage_type=zimage #kernelimage=zImage-${machine} kernelimage_type=uimage kernelimage=uImage-$machine #kernelimage_type=raw #kernelimage=Image-$machine #kernelimage_type=raw_lzo #kernelimage=Image-$machine.lzo # the name of the barebox image used by the update script bareboximage=barebox-$machine # the name of the barebox default environment used by the update script bareboxenvimage=barebox-default-environment-$machine if [ -n $user ]; then kernelimage="${user}"-"${kernelimage}" nfsroot="${eth0.serverip}:/home/${user}/nfsroot/${machine}" rootfsimage="${user}"-"${rootfsimage}" else nfsroot="/path/to/nfs/root" fi autoboot_timeout=3 # # "mini2440" kernel parameter # 0 .. 9 = screen type # b = backlight enabled # t = touch enabled # c = camera enabled # Note: can be "mini2440= " if nothing of these components are connected # bootargs="console=ttySAC0,115200 " # NAND boot settings # Device name used by the kernel nand_device="nand" # partition definition in the NAND nand_parts="512k(barebox),384k(bareboxenv),2048k(kernel),-(root)" # rootfs's partition number in the NAND rootfs_mtdblock_nand=3 # used when manually booting with "boot nand" command rootfs_mtdblock_type=jffs2 # MMC/SD boot settings # partition number to read the kernel from # (starting with # 0, Barebox's counting scheme) kernel_mmc_part=0 # rootfs's partition number # (starting with # 1, Kernel's counting scheme) rootfs_mmc_part=2 # used when manually booting with "boot mmc" command rootfs_mmc_type=ext2 -- as per juergen, perhaps my kernel is not taking the barebox cmd line argument.
Just heading home to where my env/config file is. bootargs="console=ttySAC0,115200 does not look right. While I am on the bike, why did you change it from the default?
@davef, yes, i changed it, but that is the second thing, with this param kenel and file system must be load perfectly, touch screen is the second things, first i need to boot the kernel and filesystem, I will look into touch screen things later on.
When the kernel starts, it outputs very early a line starting with "Kernel command line: [...]". Can you show us this line for your kernel? Maybe it gives us an idea what is going wrong at your side.
My understanding of the bootargs line is that if you do not want the touchscreen you still have to say: bootargs="console=ttySAC0,115200 mini2440=" Try that. Don't forget: CTRL D (enter) saveenv (enter) boot nand (enter)
The guru should be back on-line in a few hours :) Maybe try "Updating the Persistent Environment" in the BSP manual. Which version of the BSP are you using and which kernel version (default?) Have you changed the default configuration file? What was the size of your barebox image? How did you load the kernel and root filesystem on to the platform? I've run out of ideas. Good luck!
@dave, thank you for all the efforts, well I am using barebox version 'barebox 2011.05.0-mini2440-ptx-2011.11.0' and kernel is linux3.1. Yes I have tried every possibilities, but all try fail. regards, freqclock
@freqclock we need the full boot log, starting with reset, Barebox's messages and then the kernel's messages. *All* lines are useful.
@juergen, Ok, here it is. -- barebox 2011.05.0-mini2440-ptx-2011.11.0 (Mar 30 2012 - 10:08:39) Board: Mini 2440 NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Bad block table found at page 524224, version 0x01 Bad block table found at page 524160, version 0x01 dm9000 i/o: 0x20000300, id: 0x90000a46 eth@eth0: got MAC address from EEPROM: FF:FF:FF:FF:FF:FF refclk: 12000 kHz mpll: 405000 kHz upll: 48000 kHz fclk: 405000 kHz hclk: 101250 kHz pclk: 50625 kHz SDRAM1: CL2@101MHz Malloc space: 0x33a00000 -> 0x33e00000 (size 4 MB) Stack space : 0x339f8000 -> 0x33a00000 (size 32 kB) running /env/bin/init... Hit any key to stop autoboot: 3 mini2440:/ boot nand booting kernel of type uimage from /dev/nand0.kernel.bb Verifying Checksum ... OK Image Name: Linux-3.1.1-ptx-2011.11.0-SLTL Created: 2012-04-03 5:12:42 UTC Image Type: <NULL> <NULL> <NULL> (<NULL>) Data Size: 1876484 Bytes = 1.8 MB Load Address: 30008000 Entry Point: 30008000 OK commandline: console=ttySAC0,115200 mini2440= ip=none root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(kerne) arch_number: 1999 Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 3.1.1-ptx-2011.11.0-SLTL (root@sltl-desktop) (gcc version 4.6.2 (OSELAS.Toolchain-2011.11.0) ) #2 Tue Apr 3 10:42:37 IST 2012 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 CPU: VIVT data cache, VIVT instruction cache Machine: MINI2440 Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C24XX Clocks, Copyright 2004 Simtec Electronics S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttySAC0,115200 mini2440= ip=none root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv),204) PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 61080k/61080k available, 4456k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xc4800000 - 0xf6000000 ( 792 MB) lowmem : 0xc0000000 - 0xc4000000 ( 64 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .text : 0xc0008000 - 0xc0356000 (3384 kB) .init : 0xc0356000 - 0xc0373000 ( 116 kB) .data : 0xc0374000 - 0xc0395200 ( 133 kB) .bss : 0xc0395224 - 0xc03c386c ( 186 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:85 irq: clearing pending ext status 00000080 irq: clearing subpending status 00000003 irq: clearing subpending status 00000002 Console: colour dummy device 80x30 Calibrating delay loop... 201.52 BogoMIPS (lpj=503808) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 MINI2440: Option string mini2440= S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics DMA channel 0 at c4804000, irq 33 DMA channel 1 at c4804040, irq 34 DMA channel 2 at c4804080, irq 35 DMA channel 3 at c48040c0, irq 36 S3C244X: Clock Support, DVS off s3c24xx-pwm s3c24xx-pwm.0: tin at 98876, tdiv at 98876, tin=divclk, base 0 S3C24XX CPU Frequency driver, s3c244x cpu support bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (double precision) s3c-adc s3c24xx-adc: attached adc driver JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. msgmni has been set to 119 io scheduler noop registered io scheduler deadline registered (default) s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440 console [ttySAC0] enabled s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440 loop: module loaded S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns s3c24xx-nand s3c2440-nand: NAND soft ECC s3c24xx-nand s3c2440-nand: Using flash based BBT NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Creating 4 MTD partitions on "nand": 0x000000000000-0x000000040000 : "u-boot" 0x000000040000-0x000000060000 : "u-boot-env" 0x000000060000-0x000000560000 : "kernel" 0x000000560000-0x000040560000 : "root" mtd: partition "root" extends beyond the end of device "nand" -- size truncated to 0x3faa0000 dm9000 Ethernet Driver, V1.31 eth0: dm9000e at c4878300,c487a304 IRQ 51 MAC: 70:71:bc:cc:24:91 (chip) ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: S3C24XX OHCI usb usb1: Manufacturer: Linux 3.1.1-ptx-2011.11.0-SLTL ohci_hcd usb usb1: SerialNumber: s3c24xx hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mousedev: PS/2 mouse device common for all mice S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c-rtc s3c2410-rtc: rtc disabled, re-enabling s3c-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled TCP cubic registered NET: Registered protocol family 17 s3c-rtc s3c2410-rtc: setting system clock to 2012-04-03 12:09:04 UTC (1333454944) uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : mtd->read(0x800 bytes from 0x1f800) returned ECC error uncorrectable error : mtd->read(0x100 bytes from 0x0) returned ECC error uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : --
The command line is still messed up: > [...] > Kernel command line: console=ttySAC0,115200 mini2440= ip=none > root=/dev/mtdblock3 rootfstype=jffs2 noinitrd > mtdparts=nand:512k(barebox),384k(bareboxenv),204) >[...] The last line should be instead: mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(kernel),-(root) Does your serial line lose characters? But it seems this broken string is really forwarded to the kernel. Sorry, no idea what is going wrong at your side. The error you see is, that Barebox uses the defined partitions and aligns the JFFS2 filesystem according to it, but the kernel "sees" a different partition layout and starts to expect the filesystem at an offset where it is not stored to.
@juergen, Yes, problem is with different parameter, can you please tell me do i need to make changes in mach-mini2440.c for the value of partition size? after changing the parameter in /env/config, now i am getting. mini2440:/ boot nand booting kernel of type uimage from /dev/nand0.kernel.bb err -74 could not read: error 74 totally stuck, don't know what to do, heading for the cold coffee and format everything and installing fresh.. :) Thanks for the time and help.
What parameters did you change in 'env/config'? As you list it at 2012-04-03 07:54:20 it seems okay. What did you change this time? After changing the partition layout you must re-program the flash. Like a harddisk: if you change the partition table you also must re-format the partitions. Re-start with the built-in environment in your Barebox: mini2440:/ erase /dev/nand0.bareboxenv.bb mini2440:/ reset Check if the /env/config now contains the correct nand partition description. If not, change it, save it, make it persistent with the "savenenv" command. If you changed something in the partition layout, then you also need a "reset" command again, to make the new partition layout valid. Then re-flash again the kernel and the root filesystem.
Hello Juerge, when i tried to erase root partion, i got, mini2440:/ erase /dev/nand0.root.bb Skipping bad block at 0x3ff80000 Skipping bad block at 0x3ffa0000 Skipping bad block at 0x3ffc0000 Skipping bad block at 0x3ffe0000 I have tried removing mini2440 and 115200 from bootargs and now will be able to exact kernel command line. -- barebox 2011.05.0-mini2440-ptx-2011.11.0 (Mar 30 2012 - 10:08:39) Board: Mini 2440 NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Bad block table found at page 524224, version 0x01 Bad block table found at page 524160, version 0x01 dm9000 i/o: 0x20000300, id: 0x90000a46 eth@eth0: got MAC address from EEPROM: FF:FF:FF:FF:FF:FF refclk: 12000 kHz mpll: 405000 kHz upll: 48000 kHz fclk: 405000 kHz hclk: 101250 kHz pclk: 50625 kHz SDRAM1: CL2@101MHz Malloc space: 0x33a00000 -> 0x33e00000 (size 4 MB) Stack space : 0x339f8000 -> 0x33a00000 (size 32 kB) running /env/bin/init... Hit any key to stop autoboot: 3 mini2440:/ mini2440:/ mini2440:/ boot nand booting kernel of type uimage from /dev/nand0.kernel.bb Verifying Checksum ... OK Image Name: Linux-3.1.1-ptx-2011.11.0-SLTL Created: 2012-04-03 5:12:42 UTC Image Type: <NULL> <NULL> <NULL> (<NULL>) Data Size: 1876484 Bytes = 1.8 MB Load Address: 30008000 Entry Point: 30008000 OK commandline: console=ttySAC0 ip=none root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(kernel),-(root) arch_number: 1999 Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 3.1.1-ptx-2011.11.0-SLTL (root@sltl-desktop) (gcc version 4.6.2 (OSELAS.Toolchain-2011.11.0) ) #2 Tue Apr 3 10:42:37 IST 2012 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 CPU: VIVT data cache, VIVT instruction cache Machine: MINI2440 Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C24XX Clocks, Copyright 2004 Simtec Electronics S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttySAC0 ip=none root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(kernel),-(root) PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 61080k/61080k available, 4456k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xc4800000 - 0xf6000000 ( 792 MB) lowmem : 0xc0000000 - 0xc4000000 ( 64 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .text : 0xc0008000 - 0xc0356000 (3384 kB) .init : 0xc0356000 - 0xc0373000 ( 116 kB) .data : 0xc0374000 - 0xc0395200 ( 133 kB) .bss : 0xc0395224 - 0xc03c386c ( 186 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:85 irq: clearing pending ext status 00000080 irq: clearing subpending status 00000003 irq: clearing subpending status 00000002 Console: colour dummy device 80x30 Calibrating delay loop... 201.52 BogoMIPS (lpj=503808) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 MINI2440: Option string mini2440=0tb MINI2440: LCD [0:240x320] 1:800x480 2:1024x768 3:240x320 4:640x480 5:240x320 6:320x240 7:480x272 S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics DMA channel 0 at c4804000, irq 33 DMA channel 1 at c4804040, irq 34 DMA channel 2 at c4804080, irq 35 DMA channel 3 at c48040c0, irq 36 S3C244X: Clock Support, DVS off s3c24xx-pwm s3c24xx-pwm.0: tin at 98876, tdiv at 98876, tin=divclk, base 0 S3C24XX CPU Frequency driver, s3c244x cpu support bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (double precision) s3c-adc s3c24xx-adc: attached adc driver JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. msgmni has been set to 119 io scheduler noop registered io scheduler deadline registered (default) Console: switching to colour frame buffer device 30x20 fb0: s3c2410fb frame buffer device s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440 console [ttySAC0] enabled s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440 loop: module loaded S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns s3c24xx-nand s3c2440-nand: NAND soft ECC s3c24xx-nand s3c2440-nand: Using flash based BBT NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Creating 4 MTD partitions on "nand": 0x000000000000-0x000000040000 : "u-boot" 0x000000040000-0x000000060000 : "u-boot-env" 0x000000060000-0x000000560000 : "kernel" 0x000000560000-0x000040560000 : "root" mtd: partition "root" extends beyond the end of device "nand" -- size truncated to 0x3faa0000 dm9000 Ethernet Driver, V1.31 eth0: dm9000e at c4878300,c487a304 IRQ 51 MAC: 70:71:bc:cc:24:91 (chip) ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: S3C24XX OHCI usb usb1: Manufacturer: Linux 3.1.1-ptx-2011.11.0-SLTL ohci_hcd usb usb1: SerialNumber: s3c24xx hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mousedev: PS/2 mouse device common for all mice samsung-ts s3c2440-ts: driver attached, registering input device input: S3C24XX TouchScreen as /devices/virtual/input/input0 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c-rtc s3c2410-rtc: rtc disabled, re-enabling s3c-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled TCP cubic registered NET: Registered protocol family 17 s3c-rtc s3c2410-rtc: setting system clock to 2012-04-04 11:14:28 UTC (1333538068) uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : uncorrectable error : mtd->read(0x800 bytes from 0x1f800) returned ECC error uncorrectable error : mtd->read(0x100 bytes from 0x0) returned ECC error -- I am following the exact produce mentioned in the BSP pdf, but don't know what I am doing wrong? please tell me, do i need to make changes in mini2440.c for partition layout? regards, freqclock
@davef, i load barebox, kernel and rootfs reading howto from BSP pdf. totally lost, can you please share the video? Thank you for your time. -- freqclock
It appears to me that you do not have barebox in flash, but still have u-boot in there. At least you managed to get u-boot in there. Which tutorial did you follow to accomplish that? ~ update -t barebox -d nand runs correctly. Could you show us a screen shot of what you see when that finishes?
@davef, No, Barebox is there, please check the log when barebox start. I haven't installed uboot in board -- barebox 2011.05.0-mini2440-ptx-2011.11.0 (Mar 30 2012 - 10:08:39) Board: Mini 2440 NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Bad block table found at page 524224, version 0x01 Bad block table found at page 524160, version 0x01 dm9000 i/o: 0x20000300, id: 0x90000a46 eth@eth0: got MAC address from EEPROM: FF:FF:FF:FF:FF:FF refclk: 12000 kHz mpll: 405000 kHz upll: 48000 kHz fclk: 405000 kHz hclk: 101250 kHz pclk: 50625 kHz SDRAM1: CL2@101MHz Malloc space: 0x33a00000 -> 0x33e00000 (size 4 MB) Stack space : 0x339f8000 -> 0x33a00000 (size 32 kB) running /env/bin/init... Hit any key to stop autoboot: 3 mini2440:/ mini2440:/ mini2440:/ boot nand booting kernel of type uimage from /dev/nand0.kernel.bb Verifying Checksum ... OK Image Name: Linux-3.1.1-ptx-2011.11.0-SLTL Created: 2012-04-03 5:12:42 UTC Image Type: <NULL> <NULL> <NULL> (<NULL>) Data Size: 1876484 Bytes = 1.8 MB Load Address: 30008000 Entry Point: 30008000 OK commandline: console=ttySAC0 ip=none root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(kernel),-(root) arch_number: 1999 Starting kernel ... -- command I am using to update barebox.. mini2440:/ update -t barebox -d nand phy0: Link is up - 100/Full T host 192.168.1.232 is alive erasing partition /dev/nand0.barebox.bb flashing barebox-mini2440 to /dev/nand0.barebox.bb TFTP from server 192.168.X.XXX ('barebox-mini2440' -> '/dev/nand0.barebox.bb') ############################# Thanks & Regards, Freqclock
Creating 4 MTD partitions on "nand": 0x000000000000-0x000000040000 : "u-boot" 0x000000040000-0x000000060000 : "u-boot-env" 0x000000060000-0x000000560000 : "kernel" 0x000000560000-0x000040560000 : "root" Well, I don't understand why you get the correct partition sizes with the labels u-boot and u-boot-env after them. > What was the size of your barebox image? Please answer that question. And it sounds like you haven't tried: update -t bareboxenv -d nand as mentioned earlier. I don't know if it will make any difference, but we are running out of ideas here! I see you have changed the sizes of the partitions: 512k(barebox),384k(bareboxenv),2048k(kernel),-(root) 256k(barebox),64k(bareboxenv),2048k(kernel0,-(root) is enough for me. Why have you changed the first two?
Just a minute here . . . which hardware platform did you select? ptxdist platform configs/platform-friendlyarm-mini2440/platformconfig-NAND-??
> Well, I don't understand why you get the correct partition sizes > with the labels u-boot and u-boot-env after them. I don't think you are even getting the correct partition sizes. x40000 is about 256k and you are trying to set it to 512k in /env/config
@davef, >configs/platform-friendlyarm-mini2440/platformconfig-NAND-?? i selected 128M NAND partition. >I see you have changed the sizes of the partitions: >512k(barebox),384k(bareboxenv),2048k(kernel),-(root) >256k(barebox),64k(bareboxenv),2048k(kernel0,-(root) is enough for me. >Why have you changed the first two? as Juergen replied in one post above. Thanks & Regards, freqclock
@freqclock: from your kernel log everything seems correct. The kernel command line is now correct and also correctly forwarded to the kernel. The only problem is, the "mtdparts" seems to be ignored by your kernel, as it always falls back to the built in partition table. Did you change anything in the kernel configuration? I just started my own Mini2440 and its kernel states: [...] Kernel command line: console=ttySAC0,115200 mini2440=0tbc ip=192.168.1.241:192.168.1.7:192.168.1.1:255.255.255.0::: root=/dev/nfs nfsroot=/home/jb/OSELAS.BSP-Pengutronix-Mini2440/platform-mini2440/root,v3,tcp noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(kernel),-(root) [...] S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns s3c24xx-nand s3c2440-nand: NAND hardware ECC s3c24xx-nand s3c2440-nand: Using flash based BBT NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit) 4 cmdlinepart partitions found on MTD device nand Creating 4 MTD partitions on "nand": 0x000000000000-0x000000080000 : "barebox" 0x000000080000-0x0000000e0000 : "bareboxenv" 0x0000000e0000-0x0000002e0000 : "kernel" 0x0000002e0000-0x000008000000 : "root" s3c24xx-nand s3c2440-nand: clock idle support enabled [...] On the other hand your kernel outputs "3.1.1-ptx-2011.11.0-SLTL". A not modified kernel from my Mini2440-BSP should output "3.1.1-ptx-2011.11.0" instead. What did you change in the kernel you are using compared to the original kernel from my Mini2440 BSP?
>I see you have changed the sizes of the partitions: >512k(barebox),384k(bareboxenv),2048k(kernel),-(root) Sorry, I thought there was a rule about the sizes of the partitions and 384K did not fit the rule, ie powers of 2. I still don't see where he said to change to those specific numbers. I'll go back to my SPI driver. I would be interested to know why one needs such big partitions for barebox and bareboxenv.
@davef The partitions size is all right for the NAND types with 128 kiB erase blocks. To be save you need at least two or better three of these blocks to form one partition. This is for the case one of the blocks is already bad or becomes bad in the future. For the NAND types with 16 kiB erase blocks you should also reserve more than one of them to form a partition. But with four erase blocks you get a barboxenv with 64 kiB in this case, with the 128 kiB erase blocks it would be 512 kiB. And you are right: these partitions are mostly empty. But you always need more than one block. No other way.
@juergen, @davef, Ok, I remove the kernel and compile it fresh, now barebox find the correct partion. --- NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) 4 cmdlinepart partitions found on MTD device nand Creating 4 MTD partitions on "nand": 0x000000000000-0x000000080000 : "barebox" 0x000000080000-0x0000000e0000 : "bareboxenv" 0x0000000e0000-0x0000002e0000 : "kernel" s3c24xx-nand s3c2440-nand: clock idle support enabled dm9000 Ethernet Driver, V1.31 -- but, but now I am getting. --TCP cubic registered NET: Registered protocol family 17 input: gpio-keys as /devices/platform/gpio-keys/input/input2 s3c-rtc s3c2410-rtc: setting system clock to 2012-04-05 12:14:13 UTC (1333628053) Empty flash at 0x00003ffc ends at 0x00004000 Empty flash at 0x00007ffc ends at 0x00008000 Empty flash at 0x0000bffc ends at 0x0000c000 Empty flash at 0x0000fffc ends at 0x00010000 Empty flash at 0x00013ffc ends at 0x00014000 Empty flash at 0x00017ffc ends at 0x00018000 Empty flash at 0x0001bf88 ends at 0x0001c000 Empty flash at 0x00023ffc ends at 0x00024000 Empty flash at 0x00027ffc ends at 0x00028000 -- did u see, my root file size and NAND size is different than yours. -- 0x0000002e0000-0x000040000000 : "root" - my 0x0000002e0000-0x000008000000 : "root" - your, NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit) - Your NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) - My and in barebox selection i enabled 128M configuration. what could be wrong over here..? is barebox support 1Gig NAND size? is it possible? Look forward to hear from you.
My NAND has only 128 MiB, yours 1 GiB. So, why you wonder that your root filesystem is larger than mine? The 64 MiB/128 MiB selection is only required due to different erase block sizes. But I guess, also your 1 GiB NAND has 128 kiB sized erase blocks, like my 128 MiB. Seems to work now your system.
@Juergen, I was hoping the same, but i am not getting Empty flash at 0x00003ffc ends at 0x00004000 at the end of the message, i got prompt and i am able to log in into the system, but don't know why this message appear. Please Help. -- freqclock
:) Ok, Thanks a lot for the Help, support and time. I am still not done with the barebox image mount correctly in my 1Gib NAND mini2440. If you guys can help me out in the situation, that will great help for me. Regards, freqclock
@Juergen, @Dave, Finally done. :) Steps I follow: First of find the nand page size and eraseable size using uboot, after that create filesystem with that page size and eraseable block. build all the image and follow step as per the pdf and DONE. -- Registered led device: led1 Registered led device: led2 Registered led device: led3 Registered led device: led4 Registered led device: backlight usbcore: registered new interface driver usbhid usbhid: USB HID core driver S3C24XX_UDA134X SoC Audio driver UDA134X SoC Audio Codec asoc: uda134x-hifi <-> s3c24xx-iis mapping ok ALSA device list: #0: S3C24XX_UDA134X TCP cubic registered NET: Registered protocol family 17 input: gpio-keys as /devices/platform/gpio-keys/input/input2 s3c-rtc s3c2410-rtc: setting system clock to 2012-04-14 17:16:09 UTC (1334423769) VFS: Mounted root (jffs2 filesystem) on device 31:3. devtmpfs: mounted -- and after i got root prompt. The problem now is I have lcd of size 800x480 and i have given option '1tbc' in mini2440= parameter. but unable to get lcd working, no power, nothing display on the screen. Thanks & Regards, freqclock
> build all the image and follow step as per the pdf and DONE. \o/ > The problem now is I have lcd of size 800x480 and i have given option > '1tbc' in mini2440= parameter. but unable to get lcd working, no power, > nothing display on the screen. What do you mean by "no power"? There is no switch to enable or disable the LCD's power. What did you try to get something to display on the LCD?
@Juergen, > build all the image and follow step as per the pdf and DONE. I have to find the exact page size and erasable block size in order to create jffs2 file system, to find the both the parameter, i installed uboot and using 'nand info' command I found the parameter and using that parater i generate jffs2 file system. Please add this steps to pdf, so that newbie like me won't find it difficult. >>What do you mean by "no power"? There is no switch to enable or disable the LCD's power. I have enable penguine logo in kernel config but there is no logo on display and lcd remain power off. I am using 7" lcd. Thanks & Regards, freqclock
freqclock: To see the logo, you must also enable the "framebuffer console". Or just run "fbtest" or "ts_calibrate" to see, if these tool create a visible output.
@juergen, I found that linux version below 3.1 doesn't see correct linux partition, because my linux 3.1 see correct linux partition, but linux 2.6.33 doesn't see correct partition. I am getting the same error as received by freqclock for 2.6.33 version. Linux version 2.6.33-mini2440 (root@mini2440-desktop) (gcc version 4.6.2 (OSELAS.Toolchain-2011.11.0) ) #22 PREEMPT Sat Oct 6 11:37:51 IST 2012 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 CPU: VIVT data cache, VIVT instruction cache Machine: Mini2440 - ARM9 development board Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C24XX Clocks, Copyright 2004 Simtec Electronics S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttySAC0,115200 mini2440=0tbc ip=none root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv)) PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 61468KB available (2880K code, 337K data, 104K init, 0K highmem) SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:85 irq: clearing pending ext status 00000080 irq: clearing subpending status 00000003 irq: clearing subpending status 00000002 Console: colour dummy device 80x30 console [ttySAC0] enabled Calibrating delay loop... 201.93 BogoMIPS (lpj=504832) Mount-cache hash table entries: 512 Initializing cgroup subsys blkio CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 Mini2440: Features string mini2440=0tbc Mini2440 Buttons: [0: ENTER ] [1: UP ] [2: POWER ] [3: LEFT ] [4: DOWN ] [5: RIGHT ] Mini2440 LCD type: NONE > 0: NL2432HC22 3.5" (240x320) 1: TD035STED4 3.5" (240x320) 2: AT056TN52 5.6" (640x480) 3: AT070TN83 7.0" (800x480) 4: VGA board (1024x768) s3c24xx-adc s3c24xx-adc: attached adc driver S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics DMA channel 0 at c4808000, irq 33 DMA channel 1 at c4808040, irq 34 DMA channel 2 at c4808080, irq 35 DMA channel 3 at c48080c0, irq 36 S3C244X: Clock Support, DVS off bio: create slab <bio-0> at 0 usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c-i2c s3c2440-i2c: slave address 0x10 s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 NTFS driver 2.1.29 [Flags: R/W]. JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. msgmni has been set to 120 alg: No test for stdrng (krng) alg: No test for fips(ansi_cprng) (fips_ansi_cprng) io scheduler noop registered io scheduler cfq registered (default) Console: switching to colour frame buffer device 40x29 fb0: s3c2410fb frame buffer device pwm initialized s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440 brd: module loaded loop: module loaded at24 0-0050: 1024 byte 24c08 EEPROM (writable) S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns s3c24xx-nand s3c2440-nand: NAND hardware ECC NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Creating 4 MTD partitions on "NAND 1GiB 3,3V 8-bit": 0x000000000000-0x000000040000 : "u-boot" 0x000000040000-0x000000060000 : "u-boot-env" 0x000000060000-0x000000560000 : "kernel" 0x000000560000-0x000040000000 : "root" dm9000 Ethernet Driver, V1.31 Now use the MAC address: 1C:F7:1A:3D:89:E3 eth0: dm9000e at c4942300,c4946304 IRQ 51 MAC: 1c:f7:1a:3d:89:e3 (mini2440) ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: S3C24XX OHCI usb usb1: Manufacturer: Linux 2.6.33-mini2440 ohci_hcd usb usb1: SerialNumber: s3c24xx hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected usbcore: registered new interface driver libusual s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes mice: PS/2 mouse device common for all mice s3c24xx-ts s3c2440-ts: driver attached, registering input device input: S3C24XX TouchScreen as /devices/virtual/input/input0 input: OnBoard Buzzer as /devices/platform/buzzer/input/input1 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver cpuidle: using governor ladder Registered led device: led1 Registered led device: led2 Registered led device: led3 Registered led device: led4 Registered led device: backlight TCP cubic registered NET: Registered protocol family 17 s3c2410-rtc s3c2410-rtc: hctosys: invalid date/time eth0: link up, 100Mbps, full-duplex, lpa 0x45E1 IP-Config: Complete: device=eth0, addr=192.168.1.167, mask=255.255.255.0, gw=192.168.1.1, host=192.168.1.167, domain=, nis-domain=(none), bootserver=192.168.1.232, rootserver=192.168.1.232, rootpath= VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 104K Warning: unable to open an initial console. Kernel panic - not syncing: No init found. Try passing init= option to kernel. [<c0028b90>] (unwind_backtrace+0x0/0xcc) from [<c02463ec>] (panic+0x54/0x134) [<c02463ec>] (panic+0x54/0x134) from [<c0246260>] (init_post+0xdc/0x10c) [<c0246260>] (init_post+0xdc/0x10c) from [<c00089d4>] (kernel_init+0x100/0x134) [<c00089d4>] (kernel_init+0x100/0x134) from [<c0023e74>] (kernel_thread_exit+0x0/0x8) can you please tell me why linux version below 3.1 doesn't see correct linux partition. the only reason to port different kernel is, I have written a kernel module , access module from user space with c program using ioctl. Please let me know the solution.
You must extend the kernel command line with the "mtdparts" parameter to let the kernel know your intended NAND flash partitioning. Otherwise it falls back to the compiled in partitioning which does not match your requirements.
@juergen, I also did the same thing, but no luck :(. I have given kernel command line in config file (/env/config). Now the question is, in linux 3.1 I didn't give mtdparts command in config file, its automatically detect by kernel when mounting.
I have also tried linux 2.6.35.9 and still got the same result. Kernel see the right partition size, but unable to init the system. could you please explain me what could be wrong over here... why my kernel can't see right partition size? Please check the below log for linux 2.6.35.9. mini2440:/ boot nand booting kernel of type uimage from /dev/nand0.kernel.bb Verifying Checksum ... OK Image Name: Linux-2.6.35.9-ipipe Created: 2012-10-06 9:44:33 UTC Image Type: <NULL> <NULL> <NULL> (<NULL>) Data Size: 2043876 Bytes = 1.9 MB Load Address: 30008000 Entry Point: 30008000 OK commandline: console=ttySAC0,115200 init=/linuxrc ip=none root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv),2048k(k) arch_number: 1999 Starting kernel ... Uncompressing Linux... done, booting the kernel. Initializing cgroup subsys cpu Linux version 2.6.35.9-ipipe (root@mini2440-desktop) (gcc version 4.6.2 (OSELAS.Toolchain-2011.11.0) ) #36 PREEMPT Sat Oct 6 15:14:30 IST 2012 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 CPU: VIVT data cache, VIVT instruction cache Machine: MINI2440 Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C24XX Clocks, Copyright 2004 Simtec Electronics S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttySAC0,115200 init=/linuxrc ip=none root=/dev/mtdblock3 rootfstype=jffs2 noinitrd mtdparts=nand:512k(barebox),384k(bareboxenv)) PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60888k/60888k available, 4648k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xc4800000 - 0xe0000000 ( 440 MB) lowmem : 0xc0000000 - 0xc4000000 ( 64 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .init : 0xc0008000 - 0xc0023000 ( 108 kB) .text : 0xc0023000 - 0xc0391000 (3512 kB) .data : 0xc0392000 - 0xc03acd80 ( 108 kB) SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Hierarchical RCU implementation. RCU-based detection of stalled CPUs is disabled. Verbose stalled-CPUs detection is disabled. NR_IRQS:85 fiq inited irq: clearing pending ext status 00000080 irq: clearing subpending status 00000003 irq: clearing subpending status 00000002 I-pipe, 8.437 MHz clocksource I-pipe 1.18-01: pipeline enabled. Console: colour dummy device 80x30 console [ttySAC0] enabled Calibrating delay loop... 201.93 BogoMIPS (lpj=504832) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 Initializing cgroup subsys devices CPU: Testing write buffer coherency: ok gpiochip_add: gpios 288..303 (GPIOK) failed to register gpiochip_add: gpios 320..334 (GPIOL) failed to register gpiochip_add: gpios 352..353 (GPIOM) failed to register NET: Registered protocol family 16 MINI2440: Option string mini2440=3tb Setup SPI0 MINI2440: LCD 0:240x320 1:800x480 2:1024x768 [3:320x240] 4:640x480 S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics DMA channel 0 at c4808000, irq 33 DMA channel 1 at c4808040, irq 34 DMA channel 2 at c4808080, irq 35 DMA channel 3 at c48080c0, irq 36 S3C244X: Clock Support, DVS off s3c-adc s3c24xx-adc: attached adc driver S3C24XX CPU Frequency driver, s3c244x cpu support bio: create slab <bio-0> at 0 usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Switching to clocksource ipipe_tsc NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. msgmni has been set to 118 io scheduler noop registered io scheduler cfq registered (default) Console: switching to colour frame buffer device 40x15 fb0: s3c2410fb frame buffer device Hello, Mini2440 module is installed ! pwm initialized s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440 loop: module loaded S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns s3c24xx-nand s3c2440-nand: NAND hardware ECC NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Scanning device for bad blocks Creating 5 MTD partitions on "NAND 1GiB 3,3V 8-bit": 0x000000000000-0x000000040000 : "supervivi" 0x000000040000-0x000000060000 : "param" 0x000000060000-0x000000560000 : "kernel" 0x000000560000-0x000040560000 : "root" mtd: partition "root" extends beyond the end of device "NAND 1GiB 3,3V 8-bit" -- size truncated to 0x3faa0000 0x000000000000-0x000040000000 : "nand" s3c24xx-nand s3c2440-nand: clock idle support enabled dm9000 Ethernet Driver, V1.31 dm9000 dm9000: eth%d: Invalid ethernet MAC address. Please set using ifconfig eth0: dm9000e at c485c300,c4860304 IRQ 51 MAC: ff:ff:ff:ff:ff:ff (chip) ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected mice: PS/2 mouse device common for all mice samsung-ts s3c2440-ts: driver attached, registering input device input: S3C24XX TouchScreen as /devices/virtual/input/input0 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c-rtc s3c2410-rtc: rtc disabled, re-enabling s3c-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman s3c-sdi s3c2440-sdi: powered down. s3c-sdi s3c2440-sdi: mmc0 - using pio, sw SDIO IRQ usbcore: registered new interface driver usbhid usbhid: USB HID core driver TCP cubic registered NET: Registered protocol family 17 s3c-rtc s3c2410-rtc: setting system clock to 2000-01-01 01:06:07 UTC (946688767) Empty flash at 0x0149c2ec ends at 0x0149c800 JFFS2 notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found. VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 108K Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. Backtrace: [<c0027b8c>] (dump_backtrace+0x0/0x10c) from [<c02e3c3c>] (dump_stack+0x18/0x1c) r6:c0042478 r5:c001e520 r4:c03ad810 r3:00000000 [<c02e3c24>] (dump_stack+0x0/0x1c) from [<c02e3ea0>] (panic+0x78/0xe8) [<c02e3e28>] (panic+0x0/0xe8) from [<c02e3bf8>] (init_post+0xb4/0xe0) r3:60000013 r2:00000000 r1:00000000 r0:c034f148 [<c02e3b44>] (init_post+0x0/0xe0) from [<c0008abc>] (kernel_init+0x12c/0x16c) r4:c001e520 r3:c3801080 [<c0008990>] (kernel_init+0x0/0x16c) from [<c0042478>] (do_exit+0x0/0x734) r5:c0008990 r4:00000000
As long as you see a partition table listing "supervivi" something went wrong. Maybe a typo in the kernel command line or the kernel just ignores any "mtdparts" kernel parameter.
Hello Juergen, I don't understand why old kernel can't see mtdparts value. If I try to use other kernel as per above post, kernel can't find the perfect partition. It always find default partition. Can you please tell me the solution, If you have tried porting old kernel in new BSP. Please let me know the possible solution for the same?
Hello, MTD parts barebox commadline is not enough, you must setup also correct partition in your kernel source code under arch/arm/mach-mini(or something similar). Look at the board source code and you will see a defined NAND partition table. Set up correctly this partition table with your images sizes (calculate them to be safe and more self-confident), rebuild your kernel. Reboot your board. Good luck, Imed
