Bad Nagic number
beginner
Hi, I'm using barebox as bootloader on my mini2440 from Pengutronix
I'm trying to put kernel and file system into MMC card,
I setup the barebox env as necessary and format the MMC into two ext2
partitions boot and fs, in first partition I put the uImage-mini2440 kernel
image but the problem is that when barebox starts it cannot run kernel from
boot partition and it says Bad Magic Number.
How it can be solved ???
Juergen Beisert
The partition with the kernel must be a plain one, e.g. without a
filesystem, to be able to make barebox load it (Barebox does not know the
ext2 fileformat, so it just reads the plain sectors from this partition to
load the kernel). Write the kernel with the command 'dd' to this partition.
Only the partition with root filesystem to be used later on by the kernel
must use a filesystem.
beginner
Thanks a lot !!!
I reprepared the MMC, fisrt partition without filesystem
and then downloaded the kernel image to raw partition by typing in barebox
"tftp uImage-mini2440 dev/disk0.0"
and finally edit the env/bin/init change last line "boot" into
mci0.probe=1
boot mmc root=b302
(because it couldn't find the correct entry for filsystem)
and now it can boot the linux from MMC card !
Rich
I've just had a similar issue booting from the mmc card on Linux 3.7. -
hence finding this post. It turns out the incorrect parameter in barebox
/env/bin/boot was being passed to the kernel.
--- line 65: bootargs="$bootargs rootfstype=$rootfs_type noinitrd"
+++ line 65: bootargs="$bootargs rootfs_mmc_type=$rootfs_type noinitrd"
One question:
- is this required because you are doing something non-standard?
I have been running this /env/bin/boot for about two years without any
problems with 2GB SD cards.
Just curious.
