Hello, At last I managed to compile tvp5150 driver as module for ANDROID kernel and can run it :). My lsmod shows module. Now I have to add this as a camera interface in mach-mini210.c, static struct i2c_board_info tvp5150_i2c_info = { I2C_BOARD_INFO("tvp5150", 0xb8>>1), .platform_data = &tvp5150_plat, }; static struct tvp5150_platform_data tvp5150_plat = { .default_width = 640, .default_height = 480, .pixelformat = V4L2_PIX_FMT_YUYV, .freq = 14318180,/*On board I have seen 14.31818MHz*/ .is_mipi = 0, }; static struct s3c_platform_camera tvp5150 = { .id = CAMERA_PAR_B, .type = CAM_TYPE_ITU, .fmt = ITU_656_YCBCR422_8BIT, .order422 = CAM_ORDER422_8BIT_YCBYCR, .i2c_busnum = 1, .info = &tvp5150_i2c_info, .pixelformat = V4L2_PIX_FMT_YUYV, .srclk_name = "mout_mpll", .clk_name = "sclk_cam1", .clk_rate = 14318180, .line_length = 720, .width = 720, .height = 480, .window = { .left = 0, .top = 0, .width = 720, .height = 480, }, /* Polarity */ .inv_pclk = 0, .inv_vsync = 1, .inv_href = 0, .inv_hsync = 0, .initialized = 0, }; These things I found on a korean website, I have added these functions and compiled kernel and inserted module in kernel, driver was detected properly [ 268.259731] bus: 'i2c': add driver tvp5150 and then I open camera application, It opened but with blank screen. here is that log: [ 346.031543] device: '1-005c': device_add [ 346.031590] bus: 'i2c': add device 1-005c [ 346.031626] PM: Adding info for i2c:1-005c [ 346.031708] bus: 'i2c': driver_probe_device: matched device 1-005c with driver tvp5150 [ 346.031724] bus: 'i2c': really_probe: probing driver tvp5150 with device 1-005c [ 346.031752] tvp5150 1-005c: chip found @ 0xb8 (s3c2410-i2c) [ 346.031804] driver: '1-005c': driver_bound: bound to device 'tvp5150' [ 346.031815] bus: 'i2c': really_probe: bound device 1-005c to driver tvp5150 So I come to know that camera is initialized but not properly, looking for help... I hope anybody might have worked with tvp5150 with other friendlyarm platforms. Thanks
How to add tvp5150 to board file mach-mini210.c?
Hi After some search I found that I have to make some changes static struct tvp5150_platform_data tvp5150_plat = { .default_width = 720, .default_height = 480, .pixelformat = V4L2_PIX_FMT_YUYV, .freq = 40000000, .is_mipi = 0, }; where I think .freq is frequency of i2c clock, and TVP5150 works on 400Khz. in code I found following value int freq; /* MCLK in KHz */ so little confused with what value shall I use for .freq 400 or 40000000?
Hello, Did you solve your problem? I'm working with a tvp5150 driver and I'm having some problemns too. Best regards,
