Hi, I would like to set the date. I used to set it by date command. It used to work perfectly under my host pc. But it doesn’t work well on my mini2440. I can use the simple date command, but I cannot set the date. So: #date works well but the #date 12:12:12 doesn’t work anyway; the answer is invalid date ’12:12:12’ What is the problem? How can be it solved? Any kind of Linux commands would be good to me. I also would be happy to get any idea to solve the same problem from c as well. Dav
date setting
Hi, Yes, I did so. e.g.: hh:mm[:ss] is a possibly format. So I typed: date -s 12:35 I have got “invalid date” message. (By the way It works on my host pc.) My Linux is: Linux version 2.6.32.2-FriendlyARM (root@russell-work-pc) (gcc version 4.4.3 (ctng-1.6.1) ) #1 Wed Jul 28 14:57:14 CST 2010 Dav
I have solved the problem date --help gave a worse type of format, I think date -s MMDDhhmmYYYY is the good format.
I found that I needed to put quotes around everything after date -s or date --set, which is not in the help.
