Hi guys, there is a strange thing going on on my mini2440. Sometimes when I reset it with the reset button or just turn it on with the power switch, mini2440 boots up and after few seconds it suddenly restarts itself, sometimes even a couple of times. What could be the reason? Thanks!
mini2440 self restart
I don't think it is the power supply. I use the 5v / 1,2A power supply and sometimes a 5V / 2A and had the same problem on several minis. Anyone had similar problems?
Hi Andreas, yes, I have the X35 display connected to my mini. So I understand it has something to do with it?
Then the 5V / 1.2A power supply has enough power. Check the cable, connector and measure if there are really 5V on the board.
Hi Weez, I think your problem is about watchdog. Timeout parameter is 60 second default and if your boot time longer than 60, self reset appears. I had same problem and I solved with adding this line to the rcS file; echo -n V > /dev/watchdog It cancels the watchdog, good luck...
Hi Mocugo, your solution seems to be interesting. I checked my boards many times and there was everything ok with the connectors, power supply, the current... I will definitely try this out and I hope it will work! Thanks for your help!
my mini2440 has the same problem, but canceling the watchdog is not useful. Dear Weez did you find the final solution?
Hello Weez, your problem is an weak power supply.I had the same problems as you.If you have connected Network, Sound, Display and SDCard at the same time so you need an power supply with 5 Volts and 2 Ampere current better is more than 2 Ampere.I've take an 5V and 3 Ampere current powersupply and the problem was gone.If the board worked very hard so i've measured 2.4 Ampere at 5V (all components are connected). mfg Guido
