Hello! I need to compile sqlite3 for ARM arch. and then compile .cpp linking the library. I am using arm-none-linux-gnueabi from CodeSourcery IA32 GNU/Linux TAR file on 32x Ubuntu. After setting command ./configure --host=arm-none-linux-gnueabi --target=arm-none-linux-gnueabi --prefix="PATH" and executing make and make install I get libsqlite3.so.0.8.6 dynamically linked library and 'file' command shows it's based on Interl arch. If anybody had experience or knows the decision, post a message!
CodeSourceryCompiler + sqlite3autoconfig
--prefix=="PATH" What does "PATH" mean? And where do set the PATH? Are you typing these commands or running a script?
You should tell configure you want to cross compile: --host=arm-none-linux-gnueabi --build=i686-host-linux-gnu replace "i686-host-linux-gnu" with the string of your development host. Do not forget to add the cross compiler path to your $PATH variable.
Juergen, I understand that 'host' is a machine on which code must be compiled and 'target' is a machine for which code must be compiled. In 'build' there is set a type of a machine the package will run on. If 'host' is set then it declares that compiler will be built for different type of machine than it's used on at the moment. But what does 'target' stand for then? after execution of 'uname -a' there is Linux razvoj-linux-virtual 2.6.32-38-generic #83-Ubuntu SMP Wed Jan 4 11:13:04 UTC 2012 i686 GNU/Linux on the screen. As I understand, I should set --built==i686-razvoj-linux-virtual-linux-gnu ?
I set ./configure --host=arm-none-linux-gnueabi --build=i686-spica-linux-gnu --prefix='PATH_TO_DIR' But file command on library still shows Intel arch. When ./configure started, there are lines copied here below, there is checking on arm-none-linux-gnueabi-gcc with 'no', that should be a mistake. I set PATH variable and checked compiler on workability. checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes checking for arm-none-linux-gnueabi-strip... no checking for strip... strip configure: WARNING: In the future, Autoconf will not detect cross-tools whose name does not start with the host triplet. If you think this configuration is useful to you, please write to autoconf@gnu.org. checking for style of include used by make... GNU checking for arm-none-linux-gnueabi-gcc... no checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... yes checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking dependency style of gcc... gcc3 checking for special C compiler options needed for large files... no checking for _FILE_OFFSET_BITS value needed for large files... 64 checking for arm-none-linux-gnueabi-gcc... gcc checking whether we are using the GNU C compiler... (cached) yes checking whether gcc accepts -g... (cached) yes checking for gcc option to accept ISO C89... (cached) none needed checking dependency style of gcc... (cached) gcc3 checking for arm-none-linux-gnueabi-ranlib... no checking for ranlib... ranlib checking build system type... i686-spica-linux-gnu checking host system type... arm-none-linux-gnueabi checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... nm checking whether ln -s works... yes checking how to recognise dependent libraries... pass_all checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking for arm-none-linux-gnueabi-g++... no checking for arm-none-linux-gnueabi-c++... no checking for arm-none-linux-gnueabi-gpp... no checking for arm-none-linux-gnueabi-aCC... no checking for arm-none-linux-gnueabi-CC... no checking for arm-none-linux-gnueabi-cxx... no checking for arm-none-linux-gnueabi-cc++... no checking for arm-none-linux-gnueabi-cl.exe... no checking for arm-none-linux-gnueabi-FCC... no checking for arm-none-linux-gnueabi-KCC... no checking for arm-none-linux-gnueabi-RCC... no checking for arm-none-linux-gnueabi-xlC_r... no checking for arm-none-linux-gnueabi-xlC... no checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking dependency style of g++... gcc3 checking how to run the C++ preprocessor... g++ -E checking for arm-none-linux-gnueabi-g77... no checking for arm-none-linux-gnueabi-xlf... no checking for arm-none-linux-gnueabi-f77... no checking for arm-none-linux-gnueabi-frt... no checking for arm-none-linux-gnueabi-pgf77... no checking for arm-none-linux-gnueabi-cf77... no checking for arm-none-linux-gnueabi-fort77... no checking for arm-none-linux-gnueabi-fl32... no checking for arm-none-linux-gnueabi-af77... no checking for arm-none-linux-gnueabi-xlf90... no checking for arm-none-linux-gnueabi-f90... no checking for arm-none-linux-gnueabi-pgf90... no checking for arm-none-linux-gnueabi-pghpf... no checking for arm-none-linux-gnueabi-epcf90... no checking for arm-none-linux-gnueabi-gfortran... no checking for arm-none-linux-gnueabi-g95... no checking for arm-none-linux-gnueabi-xlf95... no checking for arm-none-linux-gnueabi-f95... no checking for arm-none-linux-gnueabi-fort... no checking for arm-none-linux-gnueabi-ifort... no checking for arm-none-linux-gnueabi-ifc... no checking for arm-none-linux-gnueabi-efc... no checking for arm-none-linux-gnueabi-pgf95... no checking for arm-none-linux-gnueabi-lf95... no checking for arm-none-linux-gnueabi-ftn... no checking for g77... no checking for xlf... no checking for f77... no checking for frt... no checking for pgf77... no checking for cf77... no checking for fort77... no checking for fl32... no checking for af77... no checking for xlf90... no checking for f90... no checking for pgf90... no checking for pghpf... no checking for epcf90... no checking for gfortran... no checking for g95... no checking for xlf95... no checking for f95... no checking for fort... no checking for ifort... no checking for ifc... no checking for efc... no checking for pgf95... no checking for lf95... no checking for ftn... no checking whether we are using the GNU Fortran 77 compiler... no checking whether accepts -g... no checking the maximum length of command line arguments... 32768 checking command to parse nm output from gcc object... ok checking for objdir... .libs checking for arm-none-linux-gnueabi-ar... no checking for ar... ar checking for arm-none-linux-gnueabi-ranlib... ranlib checking for arm-none-linux-gnueabi-strip... strip checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC checking if gcc PIC flag -fPIC works... yes checking if gcc static flag -static works... yes checking if gcc supports -c -o file.o... yes checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes configure: creating libtool appending configuration tag "CXX" to libtool checking for ld used by g++... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes checking for g++ option to produce PIC... -fPIC checking if g++ PIC flag -fPIC works... yes checking if g++ static flag -static works... yes checking if g++ supports -c -o file.o... yes checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate appending configuration tag "F77" to libtool checking for fdatasync... yes checking for usleep... yes checking for fullfsync... no checking for localtime_r... yes checking for gmtime_r... yes checking for library containing tgetent... -lcurses checking for library containing readline... no checking for readline... no checking for library containing pthread_create... -lpthread checking for library containing dlopen... -ldl checking for whether to support dynamic extensions... yes configure: creating ./config.status config.status: creating Makefile config.status: creating sqlite3.pc config.status: executing depfiles commands
'configure' cannot find your cross-compiler, that's all: [...] checking for arm-none-linux-gnueabi-strip... no [...] checking for arm-none-linux-gnueabi-gcc... no [...] And due to this it falls back to native compile: [...] checking for gcc... gcc [...] Let 'configure' find your compiler and it will do the correct things.
When I ask which arm-none-linux-gnueabi-g++ or arm-none-linux-gnueabi-gcc it shows a right path and I compiled a programm on it. But what is the reason that configure cannot find it?
Here it looks different. Please compare with your run: [jb@isonoe]> tar xf sqlite-3.6.11.tar.gz [jb@isonoe]> cd sqlite-3.6.11 [jb@isonoe]> export PATH=$PATH:/opt/FriendlyARM/toolschain/4.4.3/bin [jb@isonoe]> which arm-none-linux-gnueabi-gcc /opt/FriendlyARM/toolschain/4.4.3/bin/arm-none-linux-gnueabi-gcc [jb@isonoe]> ./configure -host=arm-none-linux-gnueabi --build=i686-host-linux-gnu --prefix=/usr checking build system type... i686-host-linux-gnu checking host system type... arm-none-linux-gnueabi checking for arm-none-linux-gnueabi-gcc... arm-none-linux-gnueabi-gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... yes checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether arm-none-linux-gnueabi-gcc accepts -g... yes checking for arm-none-linux-gnueabi-gcc option to accept ISO C89... none needed checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for fgrep... /bin/grep -F checking for ld used by arm-none-linux-gnueabi-gcc... /opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi/bin/ld checking if the linker (/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi/bin/ld) is GNU ld... yes checking for BSD- or MS-compatible name lister (nm)... /opt/FriendlyARM/toolschain/4.4.3/bin/arm-none-linux-gnueabi-nm -B checking the name lister (/opt/FriendlyARM/toolschain/4.4.3/bin/arm-none-linux-gnueabi-nm -B) interface... BSD nm checking whether ln -s works... yes checking the maximum length of command line arguments... 1572864 checking whether the shell understands some XSI constructs... yes checking whether the shell understands "+="... yes checking for /opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi/bin/ld option to reload object files... -r checking for arm-none-linux-gnueabi-objdump... arm-none-linux-gnueabi-objdump checking how to recognize dependent libraries... pass_all checking for arm-none-linux-gnueabi-ar... arm-none-linux-gnueabi-ar checking for arm-none-linux-gnueabi-strip... arm-none-linux-gnueabi-strip checking for arm-none-linux-gnueabi-ranlib... arm-none-linux-gnueabi-ranlib checking command to parse /opt/FriendlyARM/toolschain/4.4.3/bin/arm-none-linux-gnueabi-nm -B output from arm-none-linux-gnueabi-gcc object... ok checking how to run the C preprocessor... arm-none-linux-gnueabi-gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking for dlfcn.h... yes checking for objdir... .libs checking if arm-none-linux-gnueabi-gcc supports -fno-rtti -fno-exceptions... no checking for arm-none-linux-gnueabi-gcc option to produce PIC... -fPIC -DPIC checking if arm-none-linux-gnueabi-gcc PIC flag -fPIC -DPIC works... yes checking if arm-none-linux-gnueabi-gcc static flag -static works... yes checking if arm-none-linux-gnueabi-gcc supports -c -o file.o... yes checking if arm-none-linux-gnueabi-gcc supports -c -o file.o... (cached) yes checking whether the arm-none-linux-gnueabi-gcc linker (/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes checking for a BSD-compatible install... /usr/bin/install -c checking for gawk... gawk checking for special C compiler options needed for large files... no checking for _FILE_OFFSET_BITS value needed for large files... 64 checking for int8_t... yes checking for int16_t... yes checking for int32_t... yes checking for int64_t... yes checking for intptr_t... yes checking for uint8_t... yes checking for uint16_t... yes checking for uint32_t... yes checking for uint64_t... yes checking for uintptr_t... yes checking for sys/types.h... (cached) yes checking for stdlib.h... (cached) yes checking for stdint.h... (cached) yes checking for inttypes.h... (cached) yes checking for usleep... yes checking for fdatasync... yes checking for localtime_r... yes checking for gmtime_r... yes checking for localtime_s... no checking for tclsh8.4... no checking for tclsh... tclsh configure: Version set to 3.6 configure: Release set to 3.6.11 configure: Version number set to 3006011 checking for gcc... gcc checking whether to support threadsafe operation... yes checking for library containing pthread_create... -lpthread checking whether to allow connections to be shared across threads... no checking whether threads can override each others locks... no checking whether to support shared library linked as release mode or not... no checking whether to use an in-ram database for temporary tables... no checking if executables have the .exe suffix... unknown checking host system type... (cached) arm-none-linux-gnueabi checking for Tcl configuration... found /usr/lib/tclConfig.sh checking for existence of /usr/lib/tclConfig.sh... loading checking for library containing tgetent... no checking for readline in -lreadline... no checking readline.h usability... no checking readline.h presence... no checking for readline.h... no checking for library containing fdatasync... none required configure: creating ./config.status config.status: creating Makefile config.status: creating sqlite3.pc config.status: creating config.h config.status: executing libtool commands Happy hacking
I just downloaded earlier version of sqlite (3.3.6) and it worked. checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes checking for arm-none-linux-gnueabi-strip... arm-none-linux-gnueabi-strip checking for style of include used by make... GNU checking for arm-none-linux-gnueabi-gcc... arm-none-linux-gnueabi-gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... yes checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether arm-none-linux-gnueabi-gcc accepts -g... yes checking for arm-none-linux-gnueabi-gcc option to accept ISO C89... none needed checking dependency style of arm-none-linux-gnueabi-gcc... gcc3 But after make command I get the next output if /bin/sh ./libtool --tag=CC --mode=compile arm-none-linux-gnueabi-gcc -DPACKAGE_NAME=\"sqlite\" -DPACKAGE_TARNAME=\"sqlite\" -DPACKAGE_VERSION=\"3.6.11\" -DPACKAGE_STRING=\"sqlite\ 3.6.11\" -DPACKAGE_BUGREPORT=\"http://www.sqlite.org\" -DPACKAGE=\"sqlite\" -DVERSION=\"3.6.11\" -D_FILE_OFFSET_BITS=64 -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DHAVE_FDATASYNC=1 -DHAVE_USLEEP=1 -DHAVE_LOCALTIME_R=1 -DHAVE_GMTIME_R=1 -I. -I. -DSQLITE_THREADSAFE=1 -g -O2 -MT sqlite3.lo -MD -MP -MF ".deps/sqlite3.Tpo" -c -o sqlite3.lo sqlite3.c; \ then mv -f ".deps/sqlite3.Tpo" ".deps/sqlite3.Plo"; else rm -f ".deps/sqlite3.Tpo"; exit 1; fi mkdir .libs arm-none-linux-gnueabi-gcc -DPACKAGE_NAME=\"sqlite\" -DPACKAGE_TARNAME=\"sqlite\" -DPACKAGE_VERSION=\"3.6.11\" "-DPACKAGE_STRING=\"sqlite 3.6.11\"" -DPACKAGE_BUGREPORT=\"http://www.sqlite.org\" -DPACKAGE=\"sqlite\" -DVERSION=\"3.6.11\" -D_FILE_OFFSET_BITS=64 -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DHAVE_FDATASYNC=1 -DHAVE_USLEEP=1 -DHAVE_LOCALTIME_R=1 -DHAVE_GMTIME_R=1 -I. -I. -DSQLITE_THREADSAFE=1 -g -O2 -MT sqlite3.lo -MD -MP -MF .deps/sqlite3.Tpo -c sqlite3.c -fPIC -DPIC -o .libs/sqlite3.o ./libtool: line 1311: arm-none-linux-gnueabi-gcc: command not found make: *** [sqlite3.lo] Error 1 It was not able to find compilator. Show me your make output if this is possible.
[jb@isonoe]> cd sqlite-3.6.11 [jb@isonoe]> export PATH=$PATH:/opt/FriendlyARM/toolschain/4.4.3/bin [jb@isonoe]> which arm-none-linux-gnueabi-gcc /opt/FriendlyARM/toolschain/4.4.3/bin/arm-none-linux-gnueabi-gcc [jb@isonoe]> make [...]very long time later[...] /bin/ld: cannot find -ltclstub8.5 collect2: ld returned 1 exit status make: *** [libtclsqlite3.la] Fehler 1 After re-starting with: [jb@isonoe]> make clean [jb@isonoe]> ./configure -host=arm-none-linux-gnueabi --build=i686-host-linux-gnu --prefix=/usr --disable-tcl [jb@isonoe]> make [...]very long time later[...] [jb@isonoe] file .libs/libsqlite3.so.0.8.6 .libs/libsqlite3.so.0.8.6: ELF 32-bit LSB shared object, ARM, version 1 (SYSV), dynamically linked, not stripped
It should start without sudo prepended command before configuration as well as before make and make install. ./libtool has PATH modifications in its script. I suppose that this is the reason why I could not perfrom make command. For static librarie it's used --enable-static=yes(by default also) and --enable-shared=no. configure --help :)
