Hello, I have been trying to install android 2.3 on tiny210 board, I have followed procedure in user manual, I created a SD card fused superboot and copied images folder to sd card, then done following changes in FriendlyARM.ini #This line cannot be removed. by FriendlyARM(www.arm9.net) CheckOneButton=No Action = Install OS = Android LowFormat = Yes VerifyNandWrite = No LCD-Mode = No LCD-Type = S70 CheckCRC32=No StatusType = Beeper | LED ################### Android #################### #Android-BootLoader = Superboot210.bin #Android-Kernel = Android/zImage #Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc androidboot.console=s3c2410_serial0 #Android-RootFs-InstallImage = Android/rootfs_android.img ################### Android 2.3 #################### Android-BootLoader = Superboot210.bin Android-Kernel = Android2.3/zImage Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc androidboot.console=s3c2410_serial0 Android-RootFs-InstallImage = Android2.3/rootfs_android.img ################### Linux #################### Linux-BootLoader = Superboot210.bin Linux-Kernel = Linux/zImage Linux-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc Linux-RootFs-InstallImage = Linux/rootfs_qtopia_qt4.img I changed boot mode to SDBOOT I did not get any beep sound or any progress info regarding installation procedure on LCD, Any help in this regard will be highly appreciated Thanks.
How to install android2.3 on tiny210
You should burn the bootloader to sd card. see more info: http://minidevs.com/minidevs/info221.html
Yes I have tried same thing, However I think sd-flasher is not fusing superboot to sd card properly, in SD-Flasher GUI I do not get reformat and relayout options enabled. Please suggest me which SD card to try, I have tried with 2GB(SD), 4GB(SDHC) different companies (trasncend, sandisk) but no result, nothing on screen and nothing on serial console :( Thanks
Hi, After few tries I got this message on serial console: Board type: 2 ERROR: Media attach failed Any directions?
I have used 8GB class 2 transcend card and it worked! Don't know why does not it work with other cards. :(
The problem was that I was incorrectly created the directory structure on the sd card. The root directory should be "images". The loader first searches the directory "images", then use the relative path specified in the ini file "Android / zImage" I checked on the sd, sdhc, transcend, kingston, silicon power, 2-4GB. Mode "Install" works, but the "Run" stops at the start of the kernel. I bought tiny210 sdk1, not working usb host, usb mass storage not recognized. I checked on the android 4.03, 2.3, linux. Good electrical contact between the coreboard and usbhost. You bought tiny210 sdk2?
Hello Victor, I tried this too, only run, Does not work, stops at the start of kernel. I have tiny210 SDK2
I had luck with android 2.3.1. from a linux computer ubuntu 11.04 "sudo dd if=path/to/superboot.bin of=path/to/sdcard seek=1" then copy images file to sd card. in your .ini the third and fourth lines (as shown above) should be one line. good luck
Hello Madviking, could you please explain what do you mean by "third and fourth lines"? thank you very much for precise information :)
your .ini should be "Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc androidboot.console=s3c2410_serial0" all in one line. as i type this i realise it may just be the forum's format. did you get android working?
Hi Pratik, I am facing the same problem my Tiny210SDK2 is not booting from TF-Card Which filesystem have you used on SD card FAT16, FAT32, ext3 for pasting images folder please specify I am using 2GB SanDisk SD Card with FAT16, FAT32 filesystem Also tried with "sudo dd if=path/to/superboot.bin of=path/to/sdcard seek=1" but no success Any directions?
Did anyone mention that OS = Android will load Android4. You need OS = Android2.3.1 (or whatever matches the file name in the script). to load Android 2
Hi,Can anybody help me? I completely install android 2.3 on my Tiny210,But after rebooting just shows me a white screen, i try install other android images but all of theme had same problem :( what's wrong?
Sorry, wrong about: "Did anyone mention that OS = Android will load Android4. You need OS = Android2.3.1 (or whatever matches the file name in the script). to load Android 2" Use "Android" for 2.3 or Android4. Comment out the section you do not want. For example, to load Android2.3.1 uncomment (remove # chars) from the lines in the 2.3.1 section and set comments in the Android 4 section. The bootloader will get the right one.
